Negative Moment of Inertia from Atwood Machine Experiment?
In summary, the experiment involved varying the weights between the sides and timing how long M1 takes to hit the ground from being dropped from a height where m2 is just hovering above the ground. The experiment yielded a negative moment of inertia.
firefox
I'm currently completing an Atwood Machine Experiment with two 100g weights on either side of the pulley, with a variance in weight created by attaching dimes and pennies to either side of the weights. The point of the experiment is to validate:
(m1 – m2)g = (m1 + m2 + I/R2)
The experiment involved varying the weights between the sides and timing how long M1 takes to hit the ground from being dropped from a height where m2 is just hovering above the ground. This was my data.
http://puu.sh/nYt7k/cef6642fe9.png
n represents the number of dimes attached to the bottom of m2. As the number decreases, the dimes removed are added to the m1 side.
height from pulley to ground: 0.31m
pulley radius: 0.025m
m1g - T1 = m1 a
T2 - m2 g = m2 a
(T1-T2) R = Iα
From this system:
(m1 - m2)*g = (m1 + m2 + I/R2 )*a
To graph the results, we can use:
y= (m1-m2)g
mx = (m1 + m2 + I/R2 )*a
http://puu.sh/nYtGJ/5ebdb6e1a8.png
Trendline equation for (m1-m2)g vs a: y= 194.179672x + 47.74182125
Moment of Inertia was calculated using: slope = (m1 + m2 + I/R2 )
when solving for inertia by using the slope of the graph created by the a as the independent axis and (m1-m2)g as the dependent axis, I get a negative number. I'm quite lost at this point and I'm not sure how to proceed. It doesn't make sense to me that inertia is negative. Could this be because I'm not accounting for the fact that the y intercept isn't 0 in our combined inertia equation?
Thanks in advance for the help,
Firefox
firefox said:
(T1 T2) R = I
What are you trying to express with with equation?
Sorry about that, I'm not used to the formatting here yet!
It should read:
(T1-T2) R = Iα
What do you think your dependent and independent variables are for you data analysis?
I think (m1-m2)g is my dependent variable and my independent is a (acceleration).
But don't you vary the masses and measure the acceleration? that implies to me that the variation in the masses is the independent variable. An that is a problem since the equation not only depends on the difference of the masses but also on their sum which are independent of one another.
You make a good point, I'll admit, I didn't critically think about this point; I was following instructions from my lab manual. I've switched the variables around to see if it yields a different result, and alas, it seems I am still getting a negative inertia.
http://puu.sh/nYDQv/d35faf1af2.png
The equation that relates a to the difference is not linear. It should be of the form (I think)
a = g⋅Δ/(2M +I/R2 - Δ) Where Δ is the mass difference and M is the sum of the two masses which is kept constant so we have only one independent variable.
Oops Just noticed that a should = g⋅Δ/(2M +I/R2 + Δ)
I'm not quire sure how you arrived at that equation. Do you mind explaining further?
a the measured acceleration is the y- axis and Δ the difference in the masses of the weights is the x-axis. M is the sum of the two masses and is kept constant. You will be fitting a function of the form
y = gx/( k + x) where k= 2M + I/R2 : k clearly should be a positive number.
of course you just need to put in a value for a, Δ , and M to find I.
Is the pulley height that of the center of the pulley? The bottom? Something else?
You don't specify the starting height of the descending mass specifically. Can you clarify?
It seems to me that if your total distance for the mass movement was less than about 26 cm then your calculated moment of inertia value would be positive.
Likes TSny and firefox
Wow ! Thank you! I've been staring at my data, and you have made realized this blunder. my h value is from the center of the pulley to the ground, which now I realize, is not the height in which the weight begins to fall from. Cheers! Mystery solved.
Also, thanks to gleem for the help as well!
I'm still quite new, is there a rep system where I can click for you guys?
I'm glad it worked out. I couldn't see any obvious issues with the mechanics of your analysis so it occurred to me to look for what might be missing in the data.
As for a "rep system", you can "like" individual posts, and once per year there's a member appreciation vote for various categories. There's also the Feedback and Announcements forum in the PF Lounge area where members can express their opinions on their experiences here at Physics Forums.
Good luck with your lab report!
Related to Negative Moment of Inertia from Atwood Machine Experiment?
1. What is negative moment of inertia?
Negative moment of inertia refers to the rotational inertia of an object that is moving in the opposite direction of the applied torque. This can occur when the object is moving in the clockwise direction while the torque is applied in the counterclockwise direction, or vice versa.
2. How is negative moment of inertia measured?
Negative moment of inertia can be measured using an Atwood machine experiment. This involves suspending a pulley with two masses on either side of it and measuring the acceleration of the system as the masses move. The negative moment of inertia can be calculated from the difference between the theoretical and experimental accelerations.
3. What factors affect the negative moment of inertia in an Atwood machine experiment?
The negative moment of inertia in an Atwood machine experiment can be affected by several factors, including the mass and distribution of the masses on either side of the pulley, the radius of the pulley, and the friction in the pulley system.
4. What is the significance of negative moment of inertia in physics?
Negative moment of inertia is significant in physics because it demonstrates the concept of rotational inertia and how it can be affected by external forces. It also has practical applications in engineering and mechanics, such as in designing and optimizing pulley systems.
5. How can negative moment of inertia be minimized in an Atwood machine experiment?
To minimize negative moment of inertia in an Atwood machine experiment, the masses on either side of the pulley should be equal and evenly distributed, the pulley should have a large radius, and the friction in the pulley system should be minimized. Additionally, conducting the experiment in a vacuum can reduce air resistance and improve the accuracy of the measurements.
14K
9K
