Negative permeability of split ring resonators(SRR)
In summary: However, if we just focus on the resonances of the SRR then we can neglect the surrounding nonlinear dielectric and still obtain a valid eigenfrequency.
Sana5643
Negative permeability of split ring resonators(SRR) is obtained between the resonant frequency and the Plasma frequency of the SRRs, then what is the meaning 'eigenfrequency' of split ring resonator(SRR).
Is eigenfrequncy is that 'frequency' at what negative permeability occur ??
I 'm not sure i fully understand your question but the eigenfrequency of a SRR depends on the polarization of the field: you can excite the LC resonance at the gap, or the SPP resonance at the SRR's branches (or even both). Each one of these is an eigenfrequency of the SRR. [I am referring to the case of normal incidence; the situation becomes complicated for oblique incidence.]
im asking about eigenfrequency of SRR when it is embedded in dielectric whose permitivitty is non linear.Also permeability is nonlinear. both permitivitty and permeability are incident field intensity dependent.
I doesn't matter. When they are talking about eigenfrequencies, they mean the frequencies of the modes, resonant modes, of the structure. It may not necessarily accord to the frequencies where the permeability and/or permittivity are negative. Of course it shouldn't since the resonance means a change in sign in the real/imaginary part and a peak in the imaginary/real part of the parameter (this can be verified via the Kramers-Kronig relation). So at the resonance the permittivity or permeability is generally ill-defined (in an ideal resonance, in reality it's just going to be very small) since it is changing sign. We do not want to operate at the resonance mostly because it corresponds to a peak in the loss (imaginary part). What you generally do is design the SRR so that the resonance is a bit off from the operating frequency so that you can not only be in the small area where the parameter is negative but also try to compromise on the amount of loss.
EDIT: Normally though we do not consider the surrounding dielectric (if there is one) to be nonlinear. As pipe-squeezed-angle_bracket explained, the resonances of the SRR are dependent upon the incident field. If we permeate a volume or surface with our SRR and consider the bulk behavior of this volume/surface so that it has an effective permeability/permittivity then we find that it is non-linear (for the reasons why the physics of the SRR are dependent upon the incident wave).
The eigenfrequency of a split ring resonator (SRR) refers to the resonant frequency at which the SRR exhibits a strong response to an external electromagnetic field. This response is characterized by a negative permeability, which means that the SRR behaves as a metamaterial with unique electromagnetic properties. The eigenfrequency is therefore a crucial parameter in understanding the behavior of SRRs and their potential applications in areas such as electromagnetic wave manipulation and sensing. It is not necessarily the frequency at which negative permeability occurs, as this can vary depending on the specific design and operating conditions of the SRR. However, the eigenfrequency can be seen as a critical point at which the SRR exhibits its most interesting and useful properties.
Related to Negative permeability of split ring resonators(SRR)
1. What is negative permeability and how does it relate to split ring resonators (SRR)?
Negative permeability is a property of materials that allows them to exhibit a negative magnetic response to an applied magnetic field. This means that the magnetic field generated by the material is in the opposite direction of the external field. Split ring resonators are a type of metamaterial that can exhibit negative permeability due to their unique geometry.
2. How do split ring resonators achieve negative permeability?
Split ring resonators consist of two concentric rings with a small gap between them. When an electromagnetic wave passes through the gap, it induces an electric current in the rings. This current creates a magnetic field that is opposite to the direction of the external magnetic field, resulting in negative permeability.
3. What are the applications of negative permeability in split ring resonators?
One of the main applications of negative permeability in split ring resonators is in the development of metamaterials with unique electromagnetic properties. These materials have potential uses in various fields such as telecommunications, imaging, and sensing.
4. Can split ring resonators exhibit negative permeability at all frequencies?
No, split ring resonators can only exhibit negative permeability at certain frequencies, known as the resonant frequencies. These frequencies are determined by the size and geometry of the SRR, as well as the type of material it is made of.
5. Are there any limitations to the use of split ring resonators with negative permeability?
One limitation of using split ring resonators with negative permeability is that they only exhibit this property within a limited range of frequencies. Additionally, the fabrication of SRRs can be complex and expensive, making it challenging to scale up their production. However, ongoing research and advancements in technology are constantly expanding the potential uses of SRRs with negative permeability.
  • Classical Physics
  • Electrical Engineering
  • Classical Physics
  • Classical Physics
9K
