Negative permittivity of metals – light-trapping and plasmon
In summary, the conversation discusses the relationship between negative permittivity in metals and the effect of light-trapping through plasmonics. Negative permittivity occurs when an incident wave below the plasma frequency strikes a bulk metal, causing the wave to be reflected. However, when the incident wave is above the plasma frequency, the permittivity is positive and the wave can penetrate the metal. The concept of light-trapping using plasmons is criticized due to the negative permittivity of metals, but there is research on trapping electromagnetic radiation in meta materials with negative permittivity. It is uncertain if a homogenous piece of ordinary metal also acts as a meta material at frequencies below the plasmon resonance.
shishi
Negative permittivity of metals – The effect of light-trapping via plasmonics
I’m trying to understand the effect of light-trapping by plasmonics (for example - Localized Surface Plasmon Resonance, Surface Plasmon Polariton, Scattered Plasmons), and how negative permittivity related to that?
To the best of my knowledge, negative permittivity (ε) occurs when incident wave below the plasma frequencyp) strikes a bulk metal. In this case, the free electrons can move in a way that cancel the incident wave, and the wave will reflected from the metal (mirror-like). If the frequency of the incident wave will be above the plasma frequency, the permittivity will be positive and the electrons cannot move in a way that cancel the incident wave, and the wave will penetrate to the metal.
ε=ε0(1-ω2p2)
When people speaking about light-trapping (antenna-like) using plasmons, one of the critics is negative permittivity and I don’t understand how the light can be trapped (because it should we reflected, mirror-like)?
Any input on this matter will be highly appreciated :)
Science news on Phys.org
I wonder if you have seen the following paper:-
http://www.frdint.com/physics_of_electrostatic_resonance.pdf
It is about the trapping of EM radiation in meta materials with negative permittivity. But I am not sure if a homogenous piece of ordinary metal also behaves as a meta material at frequencies below the plasmon resonance.
FAQ: Negative permittivity of metals – light-trapping and plasmon
1. What is negative permittivity of metals?
Negative permittivity of metals is a property that describes how a metal responds to an external electric field. It is a measure of the ease with which charges can move through a material in response to an applied electric field.
2. How does negative permittivity contribute to light-trapping?
Negative permittivity in metals allows for the phenomenon of plasmon resonance, where light is confined and trapped within a metal structure. This results in enhanced light-matter interactions, making it useful for applications such as solar cells and sensors.
3. Can negative permittivity be artificially engineered in metals?
Yes, it is possible to engineer negative permittivity in metals by creating nanostructures or using metamaterials. These structures can manipulate the behavior of light and enhance plasmon resonance, leading to better light-trapping and other applications.
4. What are the potential applications of light-trapping and plasmon in metals?
Light-trapping and plasmon in metals have various potential applications in fields such as solar energy, sensing, and nanophotonics. It can also be used for improving the efficiency of optoelectronic devices and enhancing the sensitivity and resolution of imaging techniques.
5. Are there any limitations to utilizing negative permittivity in metals for light-trapping?
One limitation is that negative permittivity is typically observed in the visible to near-infrared range, so it may not be applicable for longer-wavelength light. Additionally, the fabrication of complex metal nanostructures can be challenging and expensive, limiting its widespread use in certain applications.
