Negative Time: A Puzzling Physics Problem
In summary, the time taken for the stone to reach the ground after being dropped from a balloon going up with a uniform velocity of 5.0 m/s is approximately 3.7 seconds. The quadratic equation in 't' yields two solutions, one positive and one negative, with the negative solution representing an unreal situation where the stone was going up instead of falling. This negative time can have physical significance depending on the context of the problem and the chosen event to mark t=0. However, in this specific problem, the stone was only dropped at t=0, so the negative solution does not correspond to the actual situation. This highlights the difference between mathematics and physics, where math has its own limits and physics has additional restrictions that
vissh
82
Q.)A stone is dropped from a balloon going up with a uniform velocity of 5.0 m/s . If the balloon was 50m high when the stone was dropped, find the time after which the stone will be at ground.
Ans)On solving this, we can get a quadratic equation in 't'[time]. The 2 values of t was then found to be (1 +(41)1/2)/2 and (1 -(41)1/2)/2 i.e. t = 3.7s , -2.7s.
The time can't be negative as i thought And book also has 3.7s as answer .
...The thing over which i was wondering is that its written in book " Negative t has no significance in this problem ". Can in any case the -ve value to time can have physical significance ?
Was just curious abt it :)
Mathematics is not physics; that's why we have experiments.
Or to put in mathematical terms, you often develop restrictions such as x cannot equal zero (where division by x occurs) that is carried on in solving an equation. In physics there are restrictions that are not always apparent in the math. You have one that, at least, is recognized.
Math is not the real world. It is a way of dealing with the real world but has its own limits.
Hehe thanks for reply :)
Got it :)
So, in physics -ve time got no physical significance .
Well, no, actually it can have a physical significance. In any physical situation, you have to pick (or be given) some event to mark time 0. Positive values of t describe events that happen after that "zero mark," and negative values of t describe events that happen before the "zero mark." So in any case where something happens before the event that you chose to mark t=0, its time will be negative.
For example, look at your problem. It tells you that the stone was dropped at time 0, but the equation doesn't "know" that. The only information that you plug into the equation is that, at t=0, the stone was 50 m high and was moving upwards at 5 m/s. Now, if that's all the information you had (50 m high, moving up at 5 m/s), you wouldn't know whether the stone was dropped or had been thrown up from the ground earlier. Same with the equation. So it gives you both possibilities: a positive solution to indicate when the stone will hit the ground after t=0, and a negative solution to indicate when the stone would have been on the ground before t=0 (if it had been thrown). Of course, it's up to you to read the problem and see that the stone only starting falling at t=0, so the t=-2.7s solution doesn't correspond to what really happened.
It is valid (in the mathematical sense) to say that the fall of the stone can be modeled on an axis of time as a parbola, the second solution being the UNREAL situation being when it was going up.
If you use enough of these unreal solutions, you end up with the Hawking universe(s).
Thanks Ac and diazona >:D
FAQ: Negative Time: A Puzzling Physics Problem
What is negative time?
Negative time is a concept that goes against our usual understanding of time as a linear progression from the past to the future. It suggests that time can run backwards, with events occurring before the cause that led to them.
Is negative time possible?
There is currently no scientific evidence to support the existence of negative time. It is purely a theoretical concept that has been proposed in some physics theories. However, it is a subject of ongoing research and debate among scientists.
How does negative time relate to time travel?
Negative time is often associated with time travel because it suggests the possibility of traveling back in time. However, even if negative time were to exist, it does not necessarily mean that time travel is possible. The laws of physics, such as the law of causality, would still need to be taken into account.
What are some proposed explanations for negative time?
Some physicists have suggested that negative time could be a result of certain conditions in the universe, such as a negative curvature of space-time. Others propose that it could be a consequence of the symmetries in the laws of physics.
How does negative time impact our understanding of the universe?
The concept of negative time challenges our traditional understanding of the universe and opens up new possibilities for scientific exploration. It could potentially help us better understand phenomena such as black holes and the origins of the universe, but more research is needed to fully understand its implications.
