Calculate Net Calorific Value at 25°C
  • Thread starter GeorgeP1
  • Tags
    Net Value
That's the total you already determined.so per kmol is 40.89 mols / 3.1804 = 0.013 Mj / Kmoldoes this make sense??Yes, that's the total net CV of the gas mixture per kmol of mixture. You don't need to divide by the number of moles of gas in the mixture.
GeorgeP1
A fuel gas consists of 75% butane (C4H10), 10% propane (C3H8) and 15% butene (C4H8) by volume.
It is to be fed to the combustion chamber in 10% excess air at 25°C, where it is completely burnt to carbon dioxide and water. The flue gases produced are to be used to generate 5 bar steam from water at 90°C
Net calorific value (MJ m–3) at 25°C of:
Butane (C4H10) = 111.7 MJ m^3
Butene (C4H8) = 105.2 MJ m^3
Propane (C3H8) = 85.8 MJ m^3
I need help on how to calculate: -
the net calorific value (CV) per m^3 of the fuel/air mix at 25°C ?
the net calorific value (CV) per kmol of the fuel/air mix at 25°C ?
[/B]
[/B]
Net cv per m3 = 58.65 mJ / m^3
Net cv per kmol = 1466.25 mJ / kmol
These attempts are incorrect but I don't know where I have gone wrong. any help is much appreciated.
thanks in advance
Presumably, the flue gas is at 1 bar. How many moles of flue gas are there in 1 m^3 of the gas at 25 C? How many moles of butane, propane, and butene are there?
Hi chestermiller
yes flue gas is 1 bar.
I make it a total of 35.35 moles with 10% excess air.
GeorgeP1 said:
Hi chestermiller
I meant to ask how many moles each of butane, propane, butene, oxygen, and nitrogen are in 1 cubic meter of the air/fuel mixture.
I make it :
butane - 0.75mol
propane - 0.1mol
butene - 0.15mol
oxygen - 6.3mol
10% excess air = 0.63 + 6.3 = 6.93mol
nitrogen = 6.93 x 3.76 = 26.07mol
is this correct?
GeorgeP1 said:
I make it :
butane - 0.75mol
propane - 0.1mol
butene - 0.15mol
oxygen - 6.3mol
is this correct?
That's the correct number of moles in the mixture, if you start with 1 mole of pure fuel. What is the total number of moles here, and, using the ideal gas law, what volume does this total number of moles of gas occupy?
Likes evoke1l1
total number of moles is 34 moles.
n = pV / RT
n = no. of moles
p = pressure
v = volume
R = constant (8.314)
T = temperature
n = (101300 x 1) / (8.314 x 298)
n = 40.89 moles
n = pV / RT
n = no. of moles
p = pressure
v = volume
T = temperature
n = 40.89 moles
So, if 1 m^3 of the gas contains 40.9 moles, and the total volume you calculated for the case of 1 mole of pure fuel is 34 m^3, how many moles of each species in the fuel mixture is present in 1 m^3 of mixture?
V = (n/p)RT
The volume in the ideal gas equation for 34 moles of gas is 0.83 M^3
GeorgeP1 said:
V = (n/p)RT
So, I ask again, how many moles of each species in the fuel mixture is present in 1 m^3 of the mixture?
Is it 1.203 moles
GeorgeP1 said:
Is it 1.203 moles
Yes, but I want each species individually, including the oxygen and nitrogen.
butane - 0.902 mol
propane - 0.12 mol
butene - 0.181 mol
O2 - 8.33 mol
N2 - 31.36 mol
GeorgeP1 said:
butane - 0.902 mol
propane - 0.12 mol
butene - 0.181 mol
O2 - 8.33 mol
N2 - 31.36 mol
This agrees with what I got.
Now, I assume that those net caloric values that they give you is for burning 1 m^3 of each of the pure three species (i.e., for burning the number of moles of each species that occupy 1 m^3 at 25 C and 1 bar). Is that correct?
great...
yes the net cv is for 1 m^3 of each gas.
If 40.89 moles of any gas would occupy 1 m^3 under these conditions, how many m^3 would 0.902 moles of pure butane occupy? What would be net caloric value of burning this amount of butane?
I make it 0.02206 M^3 for butane
does that make the net CV for butane 2.46 Mj / M^3
OK. What about the other two species, and what about their combined net CV?
propane = 0.003 m^3
= 0.2574 MJ /M^3
Butene = 0.0044 M^3
= 0.463 Mj / M^3
Total = 3.1804 Mj /M^3
GeorgeP1 said:
propane = 0.003 m^3
= 0.2574 MJ /M^3
Butene = 0.0044 M^3
= 0.463 Mj / M^3
Well, If we did the arithmetic correctly, I think we have our answer.
Excellent. Thanks chestermiller
My previous attempt was a country mile out then.
what about the net calorific value (CV) per kmol of the fuel/air mix at 25°C ?
Any ideas?
Any ideas?
Related to Calculate Net Calorific Value at 25°C
1. What is the definition of Net Calorific Value?
The Net Calorific Value (NCV) is a measure of the amount of energy released when a substance is burned completely at a constant pressure and under standard conditions of temperature and pressure (25°C and 1 atm).
2. How is Net Calorific Value calculated?
The Net Calorific Value is calculated by subtracting the heat of vaporization of the water vapor produced during combustion from the Gross Calorific Value (GCV).
3. What is the difference between NCV and GCV?
GCV includes the heat of vaporization of the water vapor produced during combustion, while NCV does not. Therefore, NCV is a more accurate measure of the available energy for practical use.
4. Why is NCV measured at 25°C?
The standard temperature for measuring NCV is 25°C because it is considered the average temperature for most environments and is used as a reference point for comparison purposes.
5. What units are used to express NCV?
NCV is typically expressed in units of megajoules per kilogram (MJ/kg) or kilocalories per kilogram (kcal/kg).
