Net efficiency of a cascaded Carnot Engine and Fridge
The discussion focuses on the net efficiency of a cascaded Carnot engine and fridge, exploring the relationship between heat transfer and work output. The engine operates between temperatures T_h and T_l, with work output expressed as W_out = Q_h(1 - T_r/T_h). The fridge's work consumption is defined as W_r = Q_in,fridge(T_l/T_r - 1), where Q_in,fridge is questioned. Participants agree that assuming Q_in,fridge = Q_l aligns with energy conservation principles, allowing the cold reservoir to maintain a steady temperature. This assumption leads to significant insights regarding the available work ratio, W^available/Q_h.
baseballfan_ny
The efficiency of a heat engine is to be improved by lowering the temperature of its low temperature reservoir to a value ##T_r##, below the environmental temperature ##T_l## by means of a refrigerator. The refrigerator consumes part of the work produced by the heat engine. Assume that both the heat engine and the refrigerator operate reversibly. Calculate the ratio of the net (available) work to the heat ##Q_h## supplied by the heat equation at temperature ##T_h##. Is it possible to obtain a higher net conversion energy efficiency this way?
$$ S_{in} = \frac { Q_{in} } { T_{in} } = S_{out} = \frac { Q_{out} } { T_{out} } $$
$$W_{engine} = Q_{in} - Q_{out}$$
$$W_{fridge} = Q_{out} - Q_{in}$$
Here is a diagram of my interpretation of the problem:
Where I'm thinking that the engine originally takes heat from ##T_h## to ##T_l##, in which case ## \frac { Q_{h} } { T_{h} } = \frac { Q_{l} } { T_{l} } ## and ## W_{out} = Q_{in} - Q_{out} = Q_h \left( 1 - \frac {T_l} {T_h} \right) ##.
Then I suppose that because ##T_l## is cooled to ##T_r##, I get ## W_{out} = Q_h \left( 1 - \frac {T_r} {T_h} \right) ##.
The fridge itself consumes a certain amount of work ## W_r = Q_{out, fridge} - Q_{in, fridge} ##. And because ## \frac { Q_{in, fridge} } { T_{r} } = \frac { Q_{out, fridge} } { T_{l} } ## so I can write ##W_r = Q_{in, fridge} \left( \frac {T_l} {T_r} - 1 \right) ##.
And now just trying to get $$ \frac {W^{available} } {Q_h} = \frac {W_{out} - W_r } {Q_h} = \frac { Q_h \left(1 - \frac {T_r} {T_h} \right) - Q_{in, fridge} \left( \frac {T_l} {T_r} - 1 \right) } {Q_h}$$.
But my problem is that I don't know what ##Q_{in, fridge}## is. An optimistic guess I have is that ##Q_{in, fridge} = Q_l ## by sort of applying energy conservation to the reservoir the same way we did to the engines and fridges to get the work delivered or work consumed, but I'm not sure that works that easily in the case of a reservoir? Thanks in advance for the feedback.
So far, your work looks good to me. And I also interpret the problem as implying that we should assume ##Q_{in, fridge} = Q_l##. That way, whatever heat is dumped into the cold reservoir at temperature ##T_r## by the heat engine is removed from the cold reservoir by the fridge and dumped into the environment. So, the cold reservoir can maintain a steady temperature even if the cold reservoir is not huge. Also, the assumption that ##Q_{in, fridge} = Q_l## leads to an interesting result for ##\large \frac{W^{available}}{Q_h}##.
Likes baseballfan_ny
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
