BeRiemann
- 15
An E-field is given as [itex]\vec{E}[/itex]y = b[itex]\sqrt{y}[/itex][itex]\hat{j}[/itex] V/m. Find the net flux through a cube with vertex at (0, a, 0) and side lengths a. (A picture is attached, but it is essentially the cube that would typically be at the origin, shifted along the y-axis by a units) (You can use the divergence theorem or evaluate the flux directly)
I would like to know both methods, as the next few questions specify.
Net Flux = (charge)/([itex]\epsilon[/itex]0) = integral(Divergence dot E-field)dV
The dot of divergence and E-field yields (b/2)(y^(-1/2)). This is where I'm lost, as I'm not sure how to integrate with respect to volume if the field is only along the y-axis. I've played around with it a little bit and got the answer ((b*a^3)/2)((1/sqrt(a)) - (1/sqrt(2a))) but I do not think this is correct. Any help or hints is appreciated.
