Net force acting on positive charge
In summary, the conversation discusses the equation F=(k*q*Q)/r^2 and how the answer key gives the answer as D, while the person thought it was C. They also question the need for Q1 to have a greater magnitude than Q2, since Q2 is closer to P. The conversation also mentions that the electric force falls off with distance and that if Q1 is farther away from P but still has an equal force on P as Q2, then Q1 must have a greater magnitude to compensate for the greater distance.
ardour
F= (k*q*Q)/r^2
The answer key gives the answer as D. I thought it was C. If the net electric force acting on P is zero, doesn't that mean that the force between Q1 and P and the force between Q2 and P need to cancel each other out? If you added them together, one would have to be positive, and the other would have to be negative to cancel out. Also, why should Q1 have a magnitude greater than Q2? Since Q2 is closer to P, I would have thought that it would have had a greater charge than Q1.
if one ##Q## was positive, the other negative, let's just say ##Q_1## positive and ##Q_2## negative, then the force of ##Q_1## on ##P## would push ##P## to the right and the force of ##Q_2## on ##P## would pull it to the right. So both forces would act in the same direction and the net force on ##P## cannot be zero. That means the charges cannot have opposite signs.
Electric force falls off with distance with ##\frac{1}{r^2}##. So if ##Q_1## is farther away from ##P## but still acts with an equal force on ##P## as ##Q_2## does then the magnitude of ##Q_1## must be greater than the magnitude of ##Q_2## to compensate for the greater distance.
Related to Net force acting on positive charge
1. What is net force?
Net force is the overall force acting on an object, taking into account all of the individual forces acting on that object.
2. How is net force calculated?
Net force is calculated by adding together all of the individual forces acting on an object, taking into account their magnitudes and directions.
3. What is the difference between net force and individual forces?
Individual forces refer to the specific forces acting on an object, while net force takes into account the combined effect of all of those forces.
4. What is the net force acting on a positive charge?
The net force acting on a positive charge is the total force acting on the charge, taking into account the direction and magnitude of all electric forces acting on it.
5. How does the net force affect the motion of a positive charge?
The net force acting on a positive charge determines its acceleration and therefore affects its motion. If the net force is zero, the charge will remain at rest or continue moving at a constant velocity. If the net force is non-zero, the charge will accelerate in the direction of the net force.
