Net force and position of objects in space
The discussion revolves around calculating the net force and position of objects in space using gravitational formulas. Users are struggling with obtaining consistent answers for net force calculations, specifically when applying the formula Fnet = Gm1m2 / d^2 with unit vectors. There is a suggestion to post each problem separately for clarity and to include all working steps rather than just numerical answers. Additionally, participants are advised to estimate answers before calculating and to clarify units, particularly when dealing with large masses. The conversation emphasizes the importance of understanding the constancy of forces over time intervals in these calculations.
dayspassingby
Q1) t = 493 s after midnight, a spacecraft of mass 2800 kg is located at position <9 × 105, 8 × 105, -3 × 105> m, and at that time an asteroid whose mass is 9 × 1015 kg is located at position <6 × 105, -9 × 105, -14 × 105 > m. There are no other objects nearby.
a) Calculate the (vector) force acting on the spacecraft.
b) At 493 s the spacecraft's momentum was , and at the later time 500 s its momentum was . Calculate the (vector) change of momentum .
Q2) A star of mass 3 × 1030 kg is located at <8 × 1012, 5 × 1012, 0> m. A planet of mass 6 × 1024 kg is located at <4 × 1012, 9 × 1012, 0> m and is moving with a velocity of <0.6 × 104, 1.1 × 104, 0> m/s.
a) During a time interval of 1 × 106 seconds, what is the change in the planet's velocity?\
b) During this time interval of 1 × 106 seconds, what is the change in the planet's position?
Q3) A planet of mass 7 × 1024 kg is at location <-2 × 1011, 5 × 1011, 0> m. A star of mass 4 × 1030 kg is at location <2 × 1011, -2 × 1011, 0> m. What is the force exerted on the planet by the star? (It will probably be helpful to draw a diagram, including the relevant vectors.)
Fnet = Gm1m2 / d^2 *unit vector
Q1a)
- My current wrong answer is <-5.9e7, -3.3e8, -2.17e8> I used the Fnet = Gm1m2 / d^2 <unit vector> But i keep getting a dif answer each time
Q2a) - I thought i could find net force and then divide it by the mass, and multiply it by the time interval. However I got the answer <-4.5, 4.5, 0> which is wrong
Q3)
I subtracted the planet by the star vector. Then, I used Gm1m2 / d^2 times the unit vector. But that just gave me <-1.43e21, 2.495e21, 0> Which is wrong
It is preferred that you post each problem as a separate thread.
In each case, please post all your working.
In 2a, will the force be sufficiently constant over that period to treat it as such?
Hello @dayspassingby
:welcome: ##\qquad## !​
Please don't give the numerical answers you get but post the steps you take to get them.
And have pity on us: you don't mean 9135 kg when you write 9 x 1015 kg. So write 9 x 1015 kg using the superscript button
or learn a little ##\TeX## with the
to get ##9\times 10^{15} ## kg
https://www.physicsforums.com/threads/homework-help-guidelines-for-students-and-helpers.686781/
Tip: estimate the answer (coarsely) before using a calculator. In this case, do you really expect forces to the tune of ##10^8## N ? ##\ ##
