Net Force of 60 kg Person in Elevator: Up/Down
  • Thread starter barthayn
  • Tags
    Elevator
In summary, the net force on a 60 kg person in an elevator accelerating at 5 m/s/s upwards is 888 N and downwards is 288 N, taking into consideration both the normal force and gravitational force. The normal force must exceed the gravitational force in order to achieve a net acceleration of 5 m/s/s for both the person and elevator.
barthayn
87
What is the net force of a 60 kg person, in Newtons, in an elevator accelerating at 5 m/s/s;
a) upwards?
b) downwards?
F = ma
a) F = 60 (5+9.8)
F = 60 * 14.8
F = 888 N [up]
b) F = 60 (-5+9.8)
F = 60 * 4.8
F = 288 N
Are my answers correct? If they are it is because you have to use vectors and do the change in acceleration to get the acceleration correct?
Net force on the person or the normal force on the person by the elevator?
Net force on the person. The normal force would just be mass multiplied by the acceleration due to gravity correct?
Actually no. If you consider that the forces on the person are just the normal force of the elevator on the person and the gravitational force, in order to have a net acceleration of 5m/s2 of both the person and elevator, your normal force has to exceed the gravitational force.
At least that's how I read the problem. I see elevator problems and they usually ask for the normal force, since given a net acceleration and gravitational force, the normal force is what is unknown.
So is my answers for the net force of the person correct? Which are:
a) F = 60 (5+9.8)
F = 60 * 14.8
F = 888 N [up]
b) F = 60 (-5+9.8)
F = 60 * 4.8
F = 288 N [down]
FAQ: Net Force of 60 kg Person in Elevator: Up/Down
What is the net force experienced by a 60 kg person in an elevator going up?
The net force experienced by a 60 kg person in an elevator going up is equal to their weight (60 kg x 9.8 m/s²) plus the force exerted by the elevator. This force is typically greater than their weight and is what causes the person to accelerate upwards.
What is the net force experienced by a 60 kg person in an elevator going down?
The net force experienced by a 60 kg person in an elevator going down is equal to their weight (60 kg x 9.8 m/s²) minus the force exerted by the elevator. This force is typically less than their weight and is what causes the person to accelerate downwards.
Why does the net force change when the elevator changes direction?
The net force changes when the elevator changes direction because the direction of the force exerted by the elevator changes. When the elevator is going up, the force exerted by the elevator is upwards, making the net force greater than the person's weight. When the elevator is going down, the force exerted by the elevator is downwards, making the net force less than the person's weight.
How does the net force affect the person's acceleration?
The net force directly affects the person's acceleration. If the net force is greater than their weight, they will accelerate upwards. If the net force is less than their weight, they will accelerate downwards. If the net force is equal to their weight, they will have no acceleration (constant velocity).
What other factors can affect the net force experienced by a person in an elevator?
The other factors that can affect the net force experienced by a person in an elevator include the mass of the person (heavier individuals will experience a greater force), the speed of the elevator (faster elevators will exert a greater force), and any external forces acting on the person (such as wind or other objects in the elevator).
