Net force on a charge - Coulomb's law
In summary, the net force on the 1 nC charge at the bottom is in the upward direction. The calculations involve splitting up the net force into separate vectors and using Coulomb's law to calculate the individual forces. After simplification and correcting for a possible arithmetic error, the final answer is a positive value.
rms5643
What is the force F on the 1 nC charge at the bottom?
Figure: http://session.masteringphysics.com/problemAsset/1384340/5/pic1.jpg
Coulomb's law - k*qq/r^2
1) After splitting up the net force into their respective vectors, I assume that the X vectors from the two 2.0 nC charges cancel out. As a result, I believe this problem only involves computation of the Y direction.
2) -6 nC on the 1.0 nC:
8.99*10^-9 * (6.6*10^-9) * (1.0^-9) / (5*10^-2)^2
* Pulls upwards, thus positive force
3) 2.0 nc on the 1.0 nC (Y component):
(8.99*106-9 * (2.0*10^-9) * (1.0*10^-9) / (5.10^-2)^2 ) * cos(45) * 2 (<-- Since there are two 2.0 nC charges contributing to the net Y force)
* Pulls downwards, thus negative force
4) Net X = 0
Net Y = (8.99*10^-9 * (6.6*10^-9) * (1.0^-9) / (5*10^-2)^2) - ((8.99*106-9 * (2.0*10^-9) * (1.0*10^-9) / (5.10^-2)^2 ) * cos(45) * 2)
Net Y = -0.000029 (Rounded to two sig figs)
This answer is incorrect. Where did I go wrong?
Welcome to Physics Forums.
Your method is correct, so it looks like there is an arithmetic error. A negative final answer doesn't make sense: each +2 nC charge exerts less then half of the force exerted by the -6 nC charge -- plus there is the cos(45) factor for the +2 nC charges. So the net force must be in the same direction as that due to the -6 nC charge, hence upward.
Is the "6.6" just a typo in your post, or did you really calculate using that number?
I would take out the common factor of [itex]8.99 \cdot 10^{+9} \cdot \frac{10^{-9} \cdot 10^{-9}}{(5 \cdot 10^{-2})^2}[/itex], then calculate the [itex]6\cdot 1 - 2\cdot 1 \cdot \cos(45) \cdot 2[/itex] part next.
Related to Net force on a charge - Coulomb's law
1. What is Coulomb's law?
Coulomb's law is a fundamental law in physics that describes the electrostatic interaction between two electrically charged particles. It states that the force between two charges is directly proportional to the product of their charges and inversely proportional to the square of the distance between them.
2. How is Coulomb's law related to net force on a charge?
Coulomb's law is used to calculate the net force on a charge in an electric field. It states that the net force on a charge is equal to the sum of the individual forces exerted by all other charges in the field, taking into account their magnitudes and distances.
3. What is the formula for calculating the net force on a charge using Coulomb's law?
The formula for calculating the net force on a charge using Coulomb's law is F = k(q1q2/r^2), where F is the force in Newtons, k is the Coulomb's constant, q1 and q2 are the charges in Coulombs, and r is the distance between the charges in meters.
4. How does distance affect the net force on a charge in Coulomb's law?
The net force on a charge is inversely proportional to the square of the distance between the charges. This means that as the distance between charges increases, the net force decreases and vice versa.
5. What unit is used to measure the charges in Coulomb's law?
The unit used to measure charges in Coulomb's law is Coulomb (C), named after the French physicist Charles-Augustin de Coulomb who first studied the electrostatic interaction between charges.
