Net force on a Submarine Window?
In summary: For example, when the submarine dives, the pressure within the window area will increase as the water outside the window is compressed.
colcol500
A submarine is 100 m below the surface of the water, which has a density of 1000 kg/m^3. Compare the force of the water outside the submarine and the air inside (1.0 atm) on a .1 m x .2 m window.
Apply the relationship P= P0+rho*g*h and any other principles needed to determine the net force that the air inside and the water outside exert on the window.
I have no idea, I honestly thought that the net force would be zero since the submarine window isn't moving...yikes
Likes Delta2
The window will be held in place by its support at the edge, that is not part of this problem.
You are given a formula where you know all parameters or can find them - just plug them into find the water pressure outside.
You are correct. There is also the force from the hull which counteracts the forces from the air and water.
I think the problem is asking you to compare these forces [individually].
There's a lot of information missing here! For example, the submarine is 100 m below the surface but the submarine is not a single horizontal line! What is the depth of the top of the window? I am going to assume that the top of the window is 100 m below the surface.
Also you say the window is "0.1m by 0.2 m" but don't say which measurement is horizontal and with is vertical. That's important to the answer! I am going to assume that the 0.1 m measurement is horizontal and the 0.2 m measurement is vertical.
Imagine dividing the window into n horizontal strips, each of thickness 0.2/n meters. Taking n sufficiently large, each strip will be narrow enough that we can treat it as a single depth. Taking x= 0 at the top of the window, x= 0.2i/n for the ith strip and it is 100+ 0.2i/n m below the surface. We can think of that as a narrow "stack" of water of length 0.1 m, width 0.2/n m, and height 100+ 0.2i/n m. That is a volume of 0.02(100+ 0.2i/n)= 2+ 0.002i/n cubic meters. Since the density of water is 1000 kg/m^3, the weight of that water is 2000+ 2i/n kg. That is, of course, downward but water, or any liquid, has the property that it exerts the same force in all directions. So that strip has a force of 2000+ 2i/n kg on it. To get the total force on the window, add all of those strips: [tex]\sum_{i=0}^n (2000+ 2i/n)[/tex]. That is a "Riemann sum". Taking the limit as n goes to infinity gives the integral [tex]\int_0^{0.2} (2000+ 2x) dx[/tex].
Likes Delta2
It is unimportant at the level of precision suggested by the "100 m" depth, the "1.0 atm" inside pressure or the "0.1 by 0.2m" window dimensions. For all we know, both window dimensions might be horizontal.
Likes Chestermiller and DEvens
Urm... Umm... o0) Trying to picture a window that is 0.1 m wide, and 0.2 m wide. LOL.
Think glass bottom boat.
Likes Bystander
@HallsofIvy: I'm certain OP is expected to neglect pressure variations within the window area.
Likes Delta2
Related to Net force on a Submarine Window?
1. What is the definition of "net force" on a submarine window?
The net force on a submarine window is the sum of all forces acting on the window in a given direction. It takes into account both the magnitude and direction of the forces.
2. What are the main factors that contribute to the net force on a submarine window?
The main factors that contribute to the net force on a submarine window are the water pressure, buoyancy, and drag. The pressure of the water on the window creates a force pushing on the window, while the buoyancy of the submarine creates an upward force. Drag, caused by the movement of the water, also adds to the net force on the window.
3. How does the shape of a submarine window affect the net force on it?
The shape of a submarine window can affect the net force on it by altering the way the water pressure and drag act on the window. A more streamlined shape can reduce drag and therefore decrease the net force, while a larger surface area can increase the net force due to increased water pressure.
4. Can the net force on a submarine window be controlled or altered?
Yes, the net force on a submarine window can be controlled and altered by adjusting the position and angle of the submarine, as well as the shape and size of the window. By changing these factors, the net force can be reduced or increased as needed.
5. How does the net force on a submarine window affect its structural integrity?
The net force on a submarine window can greatly affect its structural integrity. If the net force becomes too great, it can cause the window to crack or shatter, compromising the integrity of the submarine and putting the occupants at risk. It is important to carefully consider and manage the net force on submarine windows to ensure their safety and functionality.
