zak100
- 462
- 11
Hi,
I am trying to access a database using netBeans.I am using the 'select' query. I have got only one record. I am displaying its only two fields in the jTextField. I have a button (next) component. I have written its handler which is used to traverse the resultset. In the constructor i am connecting with the DB. When i am pressing the 'next' button first time, its displaying the two fields of db in the jTextfield. But when i am pressing the 'next' button again, i am getting the error, "Operation not allowed after ResultSet Closed".
I am getting following errors:
Some body please guide me. I am trying to view the contents of Table by clicking a button next.Zulfi.--
Java:
package jdb1;
import java.sql.*;
* @author HP
public class Javadb1 extends javax.swing.JFrame {
private static final String JDBC_DRIVER = "com.mysql.jdbc.Driver";
private static final String DB_URL = "jdbc:mysql://localhost/test";
// Database credentials
private static final String USER = "root";
private static final String PASS = "z";
private Connection conn = null;
private Statement stmt = null;
String sql="";
ResultSet rs= null;
* Creates new form Javadb1
*/ public Javadb1() {
try{
//STEP 2: Register JDBC driver
Class.forName("com.mysql.jdbc.Driver");
//STEP 3: Open a connection
System.out.println("Connecting to database...");
conn = DriverManager.getConnection(DB_URL,USER,PASS);
//STEP 4: Execute a query
System.out.println("Creating statement...");
stmt = conn.createStatement();
sql = "SELECT name, owner FROM pet";
rs = stmt.executeQuery(sql);
}catch(SQLException se){
//Handle errors for JDBC
se.printStackTrace();
}catch(Exception e){
//Handle errors for Class.forName
System.out.println("Goodbye!");
initComponents();
* This method is called from within the constructor to initialize the form.
* WARNING: Do NOT modify this code. The content of this method is always
* regenerated by the Form Editor.
@SuppressWarnings("unchecked")
// <editor-fold defaultstate="collapsed" desc="Generated Code">
private void initComponents() {
jPanel1 = new javax.swing.JPanel();
jNext = new javax.swing.JButton();
jName = new javax.swing.JTextField();
jOwner = new javax.swing.JTextField();
jSex = new javax.swing.JTextField();
jBirth = new javax.swing.JTextField();
setDefaultCloseOperation(javax.swing.WindowConstants.EXIT_ON_CLOSE);
jNext.setText("Next");
jNext.addActionListener(new java.awt.event.ActionListener() {
public void actionPerformed(java.awt.event.ActionEvent evt) {
jNextActionPerformed(evt);
javax.swing.GroupLayout jPanel1Layout = new javax.swing.GroupLayout(jPanel1);
jPanel1.setLayout(jPanel1Layout);
jPanel1Layout.setHorizontalGroup(
jPanel1Layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING)
.addGroup(javax.swing.GroupLayout.Alignment.TRAILING, jPanel1Layout.createSequentialGroup()
.addContainerGap(155, Short.MAX_VALUE)
.addComponent(jNext)
.addContainerGap())
.addGroup(jPanel1Layout.createSequentialGroup()
.addGap(28, 28, 28)
.addGroup(jPanel1Layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING, false)
.addComponent(jName)
.addComponent(jOwner)
.addComponent(jSex)
.addComponent(jBirth, javax.swing.GroupLayout.DEFAULT_SIZE, 94, Short.MAX_VALUE))
.addContainerGap(javax.swing.GroupLayout.DEFAULT_SIZE, Short.MAX_VALUE))
jPanel1Layout.setVerticalGroup(
.addGap(21, 21, 21)
.addPreferredGap(javax.swing.LayoutStyle.ComponentPlacement.UNRELATED)
.addComponent(jName, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE)
.addComponent(jOwner, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE)
.addComponent(jSex, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE)
.addPreferredGap(javax.swing.LayoutStyle.ComponentPlacement.RELATED)
.addComponent(jBirth, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE)
.addContainerGap(40, Short.MAX_VALUE))
javax.swing.GroupLayout layout = new javax.swing.GroupLayout(getContentPane());
getContentPane().setLayout(layout);
layout.setHorizontalGroup(
layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING)
.addGroup(layout.createSequentialGroup()
.addGap(67, 67, 67)
.addComponent(jPanel1, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE)
.addContainerGap(113, Short.MAX_VALUE))
layout.setVerticalGroup(
.addGap(48, 48, 48)
.addContainerGap(49, Short.MAX_VALUE))
pack();
}// </editor-fold>
private void jNextActionPerformed(java.awt.event.ActionEvent evt) {
// TODO add your handling code here:
try{
if(rs.next()){
String name = rs.getString("name");
String owner = rs.getString("owner");
jName.setText(name);
jOwner.setText(owner);
else {
rs.close();
stmt.close();
conn.close();
finally{
//finally block used to close resources
try{
if(stmt!=null)
stmt.close();
}catch(SQLException se2){
}// nothing we can do
try{
if(conn!=null)
conn.close();
}//end finally try
try{
if(rs!=null)
rs.close();
}//end fina*/
//end try
* @param args the command line arguments
public static void main(String args[]) {
/* Set the Nimbus look and feel */
//<editor-fold defaultstate="collapsed" desc=" Look and feel setting code (optional) ">
/* If Nimbus (introduced in Java SE 6) is not available, stay with the default look and feel.
* For details see http://download.oracle.com/javase/tutorial/uiswing/lookandfeel/plaf.html
try {
for (javax.swing.UIManager.LookAndFeelInfo info : javax.swing.UIManager.getInstalledLookAndFeels()) {
if ("Nimbus".equals(info.getName())) {
javax.swing.UIManager.setLookAndFeel(info.getClassName());
break;
} catch (ClassNotFoundException ex) {
java.util.logging.Logger.getLogger(Javadb1.class.getName()).log(java.util.logging.Level.SEVERE, null, ex);
} catch (InstantiationException ex) {
} catch (IllegalAccessException ex) {
} catch (javax.swing.UnsupportedLookAndFeelException ex) {
//</editor-fold>
/* Create and display the form */
java.awt.EventQueue.invokeLater(new Runnable() {
public void run() {
new Javadb1().setVisible(true);
// Variables declaration - do not modify
private javax.swing.JTextField jBirth;
private javax.swing.JTextField jName;
private javax.swing.JButton jNext;
private javax.swing.JTextField jOwner;
private javax.swing.JPanel jPanel1;
private javax.swing.JTextField jSex;
// End of variables declaration
Code:
java.sql.SQLException: Operation not allowed after ResultSet closed
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:910)
at com.mysql.jdbc.ResultSet.checkClosed(ResultSet.java:666)
at com.mysql.jdbc.ResultSet.next(ResultSet.java:7274)
at jdb1.Javadb1.jNextActionPerformed(Javadb1.java:149)
at jdb1.Javadb1.access$000(Javadb1.java:12)
at jdb1.Javadb1$1.actionPerformed(Javadb1.java:88)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252)
at java.awt.Component.processMouseEvent(Component.java:6535)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3324)
at java.awt.Component.processEvent(Component.java:6300)
at java.awt.Container.processEvent(Container.java:2236)
at java.awt.Component.dispatchEventImpl(Component.java:4891)
at java.awt.Container.dispatchEventImpl(Container.java:2294)
at java.awt.Component.dispatchEvent(Component.java:4713)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4888)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4525)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4466)
at java.awt.Container.dispatchEventImpl(Container.java:2280)
at java.awt.Window.dispatchEventImpl(Window.java:2750)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:76)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:86)
at java.awt.EventQueue$4.run(EventQueue.java:731)
at java.awt.EventQueue$4.run(EventQueue.java:729)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:728)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
