NetBeans:Sending multiple Messages: Erroneous sym type: Soc
In summary, the conversation is about creating a program using NetBeans to send a message from a server to a client on the same machine. The code used for the button handler is shown and it is mentioned that it worked but when the button was pressed again to send another message, an error occurred. To handle this error, two methods were created - createConnection() and closeConnection(). However, another error is shown when the code is compiled, specifically with the Sockect class. The full server code is also shown.
zak100
462
Hi,
I made a program to send a message from a Server to a client on the same machine in NetBeans on a Button click. I used the following code in the button handler:
Java:
private void sendMsgButtonActionPerformed(java.awt.event.ActionEvent evt) {
  // TODO add your handling code here:
  try{
  ServerSocket sSocket=new ServerSocket(800);
  System.out.println("Server Started");
  Socket cSocket=sSocket.accept();  PrintWriter writer=new PrintWriter(cSocket.getOutputStream());
  writer.println("Hello I am the Server");  writer.flush();
  writer.close();  Thread.currentThread().sleep(2000);
  cSocket.close();
  sSocket.close();
  }catch(SocketTimeoutException s)
  System.out.println("Socket timed out!");
   break;
  catch(IOException e) {
  e.printStackTrace();
It worked but when i pressed the button again to send another message , i got following error:
java.net.BindException: Address already in use: JVM_Bind
at java.net.DualStackPlainSocketImpl.bind0(Native Method)
at java.net.DualStackPlainSocketImpl.socketBind(DualStackPlainSocketImpl.java:106)
at java.net.AbstractPlainSocketImpl.bind(AbstractPlainSocketImpl.java:387)
at java.net.PlainSocketImpl.bind(PlainSocketImpl.java:190)
at java.net.ServerSocket.bind(ServerSocket.java:375)
at java.net.ServerSocket.<init>(ServerSocket.java:237)
at java.net.ServerSocket.<init>(ServerSocket.java:128)
at ServerFrame.sendMsgButtonActionPerformed(ServerFrame.java:83)
at ServerFrame.access$000(ServerFrame.java:13)
at ServerFrame$1.actionPerformed(ServerFrame.java:39)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252)
at java.awt.Component.processMouseEvent(Component.java:6535)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3324)
at java.awt.Component.processEvent(Component.java:6300)
at java.awt.Container.processEvent(Container.java:2236)
at java.awt.Component.dispatchEventImpl(Component.java:4891)
at java.awt.Container.dispatchEventImpl(Container.java:2294)
at java.awt.Component.dispatchEvent(Component.java:4713)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4888)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4525)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4466)
at java.awt.Container.dispatchEventImpl(Container.java:2280)
at java.awt.Window.dispatchEventImpl(Window.java:2750)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:76)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:86)
at java.awt.EventQueue$4.run(EventQueue.java:731)
at java.awt.EventQueue$4.run(EventQueue.java:729)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:728)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
To handle this error, i created two methods: createConnection( ) & closeConnection( ) but now i am getting following error:
Exception in thread "main" java.lang.RuntimeException: Uncompilable source code - Erroneous sym type: Sockect.close
at Server2JFrame.closeConnection(Server2JFrame.java:44)
at Server2JFrame.main(Server2JFrame.java:153)
Exception in thread "AWT-EventQueue-0" java.lang.RuntimeException: Uncompilable source code - cannot find symbol
symbol: class Sockect
at Server2JFrame.<init>(Server2JFrame.java:24)
at Server2JFrame$2.run(Server2JFrame.java:150)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:756)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:726)
C:\Users\HP\AppData\Local\NetBeans\Cache\8.1\executor-snippets\run.xml:53: Java returned: 1
BUILD FAILED (total time: 2 seconds)
My complete server code is:
Java:
import java.io.IOException;
import java.io.PrintWriter;
import java.net.ServerSocket;
import java.net.Socket;
import java.net.SocketTimeoutException;
* To change this license header, choose License Headers in Project Properties.
* To change this template file, choose Tools | Templates
* and open the template in the editor.
* @author HP
public class Server2JFrame extends javax.swing.JFrame {
     * Creates new form Server2JFrame
    ServerSocket sSocket;
    Sockect cSocket;
    PrintWriter writer;
    public void createConnection( ){
         try{
            break;
    public static void closeConnection(){
        cSocket.close();
        sSocket.close();
    public Server2JFrame() {
        createConnection( );
        initComponents();
     * This method is called from within the constructor to initialize the form.
     * WARNING: Do NOT modify this code. The content of this method is always
     * regenerated by the Form Editor.
    @SuppressWarnings("unchecked")
    // <editor-fold defaultstate="collapsed" desc="Generated Code">
    private void initComponents() {
        jPanel1 = new javax.swing.JPanel();
        sendMesgButton = new javax.swing.JButton();
        setDefaultCloseOperation(javax.swing.WindowConstants.EXIT_ON_CLOSE);
        sendMesgButton.setText("Send Multiple Message");
        sendMesgButton.addActionListener(new java.awt.event.ActionListener() {
            public void actionPerformed(java.awt.event.ActionEvent evt) {
                sendMesgButtonActionPerformed(evt);
        javax.swing.GroupLayout jPanel1Layout = new javax.swing.GroupLayout(jPanel1);
        jPanel1.setLayout(jPanel1Layout);
        jPanel1Layout.setHorizontalGroup(
            jPanel1Layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING)
            .addGroup(jPanel1Layout.createSequentialGroup()
                .addGap(65, 65, 65)
                .addComponent(sendMesgButton)
                .addContainerGap(82, Short.MAX_VALUE))
        jPanel1Layout.setVerticalGroup(
            .addGroup(javax.swing.GroupLayout.Alignment.TRAILING, jPanel1Layout.createSequentialGroup()
                .addContainerGap(42, Short.MAX_VALUE)
                .addGap(35, 35, 35))
        javax.swing.GroupLayout layout = new javax.swing.GroupLayout(getContentPane());
        getContentPane().setLayout(layout);
        layout.setHorizontalGroup(
            layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING)
            .addGroup(layout.createSequentialGroup()
                .addGap(87, 87, 87)
                .addComponent(jPanel1, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE)
                .addContainerGap(25, Short.MAX_VALUE))
        layout.setVerticalGroup(
                .addGap(79, 79, 79)
                .addContainerGap(121, Short.MAX_VALUE))
        pack();
    }// </editor-fold>
    private void sendMesgButtonActionPerformed(java.awt.event.ActionEvent evt) {
        writer.flush();
        writer.close();
     * @param args the command line arguments
    public static void main(String args[]) {
        /* Set the Nimbus look and feel */
        //<editor-fold defaultstate="collapsed" desc=" Look and feel setting code (optional) ">
        /* If Nimbus (introduced in Java SE 6) is not available, stay with the default look and feel.
         * For details see http://download.oracle.com/javase/tutorial/uiswing/lookandfeel/plaf.html
        try {
            for (javax.swing.UIManager.LookAndFeelInfo info : javax.swing.UIManager.getInstalledLookAndFeels()) {
                if ("Nimbus".equals(info.getName())) {
                    javax.swing.UIManager.setLookAndFeel(info.getClassName());
                    break;
        } catch (ClassNotFoundException ex) {
            java.util.logging.Logger.getLogger(Server2JFrame.class.getName()).log(java.util.logging.Level.SEVERE, null, ex);
        } catch (InstantiationException ex) {
        } catch (IllegalAccessException ex) {
        } catch (javax.swing.UnsupportedLookAndFeelException ex) {
        //</editor-fold>
        /* Create and display the form */
        java.awt.EventQueue.invokeLater(new Runnable() {
            public void run() {
                new Server2JFrame().setVisible(true);
        closeConnection( );
    // Variables declaration - do not modify
    private javax.swing.JPanel jPanel1;
    private javax.swing.JButton sendMesgButton;
    // End of variables declaration
and the client code is:
Java:
import java.net.*;
import java.io.*;
public class NewJFrame extends javax.swing.JFrame {
     * Creates new form NewJFrame
    public NewJFrame() {
        initComponents();
        recvMesgButton = new javax.swing.JButton();
        recvMesgButton.setText("Received Client Message");
        recvMesgButton.addActionListener(new java.awt.event.ActionListener() {
                recvMesgButtonActionPerformed(evt);
                .addContainerGap(37, Short.MAX_VALUE)
                .addComponent(recvMesgButton)
                .addGap(34, 34, 34))
                .addGap(66, 66, 66)
                .addContainerGap(71, Short.MAX_VALUE))
                .addGap(104, 104, 104)
                .addContainerGap(87, Short.MAX_VALUE))
                .addGap(55, 55, 55)
                .addContainerGap(85, Short.MAX_VALUE))
        pack();
    }// </editor-fold>
    private void recvMesgButtonActionPerformed(java.awt.event.ActionEvent evt) {
       try{
       Socket toServer=new Socket(InetAddress.getLocalHost(),800);
       BufferedReader bufr=new BufferedReader(new InputStreamReader(toServer.getInputStream()));
       System.out.println(bufr.readLine());
       bufr.close();
       toServer.close();
       }catch(IOException e){
            break;
        try {
                    break;
            java.util.logging.Logger.getLogger(NewJFrame.class.getName()).log(java.util.logging.Level.SEVERE, null, ex);
        //</editor-fold>
            public void run() {
                new NewJFrame().setVisible(true);
    private javax.swing.JButton recvMesgButton;
Some body please guide me how to get around with this problem.
Zulfi.
Technology news on Phys.org
The first thing I do is to check for examples:
http://cs.lmu.edu/~ray/notes/javanetexamples/
and then see if my code is missing something.
It looks like your code isn't closing the socket or terminating correctly (ie maybe its still running the first version). Netbeans has an indicator at the bottom right that shows what processes are running. Sometimes though it gets confused and a process that you launched is running but it thinks it has ended.
Basically you need to still clean up stuff when you get an exception. What happens is when the exception is thrown everything that would normally be executed is skipped until your program has caught the exception then it gets back on track.
It looks to me as if you are trying to start a server at port 800 every time you push the button. That is not allowed, and that is why you get the error messages. Try to check if the server is already started and do not create a new one if it is.
Hi,
I am now getting address already Bind. I have created separate methods for createConnection( ) & closeConnection( ). I have checked that i am not invoking these methods repeatedly. I am closing the conncections in the exception handling code.
Java:
* @author HP
    static ServerSocket sSocket;
    static Socket cSocket;
    static PrintWriter writer;
    public static void createConnection( ){
         try{
        //Thread.currentThread().sleep(2000);
            closeConnection();
            break;
//            closeConnection();
        try{
        cSocket.close();
        sSocket.close();
        }catch(IOException e) {
        initComponents();
                .addGap(65, 65, 65)
                .addGap(87, 87, 87)
                .addGap(79, 79, 79)
        pack();
    }// </editor-fold>
        writer.flush();
        writer.close();
        try {
                    break;
        //</editor-fold>
            public void run() {
        closeConnection( );
& the errors are:
at Server2JFrame.createConnection(Server2JFrame.java:29)
at Server2JFrame.main(Server2JFrame.java:152)
Exception in thread "main" java.lang.NullPointerException
at Server2JFrame.closeConnection(Server2JFrame.java:47)
at Server2JFrame.main(Server2JFrame.java:159)
BUILD SUCCESSFUL (total time: 7 seconds)
Somebody please guide me.
Zulfi.
Did you look at the examples link I posted earlier? Surely there's something that will help you.
You either have something running on your machine that is using port 800 or one your earlier runs is still running.
If you reboot does the program still say that its in use already if o then some other process on your machine is using that port and depending on your OS you can check to see who is via the command. Here's the Linux one:
http://askubuntu.com/questions/538208/how-to-check-opened-closed-port-on-my-computer
I am no Java expert, but I do know something about networking. When tracing through the error messages it ends up in "Address already in use". As already commented:
I shall only add that port numbers below 1024 are so-called "well-known ports" and should not be used for anything but the "well-known applications". From rfc 1700:
The assigned ports use a small portion of the possible port numbers. For many years the assigned ports were in the range 0-255. Recently, the range for assigned ports managed by the IANA has been expanded to the range 0-1023.
Port Assignments:
Keyword Decimal Description References
mdbs_daemon 800/tcp
mdbs_daemon 800/udp
Likes jedishrfu
Hi,
Thanks my friends for your guidance.
<Did you look at the examples link I posted earlier? >
I have tried to change my code according to the first example in the document. But now I m not getting the "Bind error" but its not showing the Button.
It prints the message server started.
I tried to use debugger but now run to Cursor option has grayed. So i can't use it.
My code is:
Code:
* @author HP
         try{
         sSocket=new ServerSocket(9090);
            closeConnection();
        try{
        cSocket.close();
        sSocket.close();
        initComponents();
                .addGap(65, 65, 65)
                .addGap(87, 87, 87)
                .addGap(79, 79, 79)
        pack();
    }// </editor-fold>
        try{
        writer=new PrintWriter(cSocket.getOutputStream(),true);
        writer.flush();
        writer.close();
            try {
            cSocket.close();
            }catch(IOException ee){
        try {
                    break;
        //</editor-fold>
            public void run() {
        closeConnection( );
Some body please guide me why i am not seeing the button.
Zulfi.
Related to NetBeans:Sending multiple Messages: Erroneous sym type: Soc
1. What does the error "Erroneous sym type: Soc" mean in NetBeans?
The error "Erroneous sym type: Soc" in NetBeans means that there is a problem with the syntax or type of the variable or method named "Soc". This could be due to a misspelling, missing import statement, or incorrect data type.
2. How can I fix the "Erroneous sym type: Soc" error in NetBeans?
To fix the "Erroneous sym type: Soc" error in NetBeans, you will need to carefully check the syntax and data types of the variable or method named "Soc". Make sure it is correctly spelled and that all necessary import statements are included. You may also need to check for any other coding errors that could be causing the issue.
3. Why am I getting the "Erroneous sym type: Soc" error when sending multiple messages in NetBeans?
The most common reason for getting the "Erroneous sym type: Soc" error when sending multiple messages in NetBeans is because of a coding error in the variable or method named "Soc". It is important to double check the syntax and data types to ensure they are correct.
4. Can a missing import statement cause the "Erroneous sym type: Soc" error in NetBeans?
Yes, a missing import statement can cause the "Erroneous sym type: Soc" error in NetBeans. If the variable or method named "Soc" is from a different package or class, you will need to include the appropriate import statement to use it in your code.
5. Is there a way to prevent the "Erroneous sym type: Soc" error from occurring in NetBeans?
To prevent the "Erroneous sym type: Soc" error from occurring in NetBeans, it is important to carefully check your code for any syntax or data type errors. Make sure all variables and methods are correctly spelled and that all necessary import statements are included. It is also helpful to test your code frequently during the development process to catch and fix any errors early on.
23K
11K
11K
