Network, 2 loads, find complex power
In summary: Homework Statement In summary, the apparent power of the source is 12,000 VA. The voltage is 240 V and the power factor is 0.7. The current through the load is 119 A.
  • #36
Well, thanks for the heads up. Doing that again I got this:
Irms = (119 ∠ 45.5)A = (83.408 + 84.87j) = for the 0.7 leading power factor and
Irms = (50 ∠ 25.8)A = (45.01 + 21.761j) for the 0.9 lagging power factor
then Irms = (50 ∠ -25.8)A = (45.01 - 21.761j) for the 0.9 lagging power factor just for lagging
Itotrms = (128.4 + 63j)A = (143.02 ∠ 26.135)A
Series Z is still (0.05 + 0.2j)Ω = (0.2061 ∠ 75.963)Ω
Vdrop = (0.2061 ∠ 75.963)Ω * (143.02 ∠ 26.135)A
Vdrop = (29.476 ∠ 102.098)V = (-6.177 + 28.821j)V
Vtot = (233.823 + 28.821j)V = (235.59 ∠ 7.0268)V
Apparent power = (143.02A)*(235.59V) = 33.694kVA
I know it makes a difference, although still not exactly what you have.
Now then
The total impedance is Z = V/I
Ztot = (235.59 ∠ 7.0268)V/(143.02 ∠ 26.135)A
Ztot = (1.647 ∠ 33.161)Ω = (1.3787 + 0.9j)Ω
Would the power factor of the source be cos(total impedance angle) ?
ie cos(33.161) = 0.837 ?
Would Vs(t) just be Vtot in max value form? I should probably also say that on the paper with this problem there is no "Vs(t)" (but just Vs) on the diagram even though it asks to find Vs(t). It's supposed to be that way though right?
ie Vs(t) = (235.59 ∠ 7.0268)V*√2 = (333.17 ∠ 7.0268)V max ?
Is the complex power also 33.697kVA? How do you understand the difference between complex / apparent power better?
  • #37
Now then
Careful. When dividing complex numbers in polar form you subtract the angle of the denominator from the angle of the numerator...
I suppose that would be it. To me it's a bit of an odd way to describe a source (as having a power factor rather than phase angle). Get your impedance angle correct first!
What's Vtot ?
By "max value form" I presume you mean the time-domain peak value expression for supply voltage? If so then you'd find the peak value from the RMS value that you've calculated, determine the phase angle from the "power factor" above, then write it out:
##V(t) = V_m cos(ω t + \phi)##
Is the complex power also 33.697kVA? How do you understand the difference?
33.697kVA is the apparent power. It's the magnitude of the complex power phasor. There's a real power and reactive power (imaginary) component. Look up "power triangle".
  • #38
Okay, my mistake again
Ztot = 1.647 ∠ -19.108
then the power factor (of the source) would be
cos(-19.108) = 0.94
But the angle for calculating any power factor is always from the impedance angle though right? The impedance angle always means it's the phase?
Thanks again.
So for that equation
Vm = (235.59 ∠ 7.0268)V*√2
Vm = (333.17 ∠ 7.0268)V max
ω = 0.0166
Vs(t) = 333.17*cos(0.0166t - 19.108°)
This is what was really meant by Vs(t)? It seems more like a fixed equation than any value, but I understand, it just seems strange and there are lots of formulas with time domain and I couldn't figure out which one was which. It's fine though I guess.
For fun now the real power of the source is 33.697*cos(-19.108) = 31.84W
and the reactive power = 33.697 * sin(-19.108) = -11.03 VARS?
  • #39
cos(-19.108) = 0.94
That looks okay.
The load is not the source. The question asked for the power factor of the source, which I find a bit odd. Interpreting it as simply the cosine of the phase angle attributed to the source seems like the best interpretation to me.
Thanks again.
ω = 0.0166
Yup. Looks okay, if you really need the expression for the peak voltage.
For sinusoidal voltage supplies the peak and RMS values are always related by a factor of √2. The phasor representation simply omits the ωt information of the time domain formula, since ωt is a common component of all the phasors (current, voltage) throughout the circuit.
In power systems RMS values are almost always intended or implied. Unless otherwise specifically instructed or indicated, always assume that RMS values are given. For example, a typical North American domestic 110 V power outlet means 110V RMS.
Sure. Once again, I suggest that you investigate the Power Triangle to relate these values graphically.
  • #40
Color_of_Cyan said:
ω = 1/f = 0.0166
##ω = 2 \pi f##
  • #41
Ok, thanks for catching that. I thought there was something different between period and ω but couldn't remember.
ω = 376.9
