Neumann boundary with finite differences
In summary, the conversation discusses the use of Laplace equation to solve for steady state temperature over a rectangle with both Neumann and Dirichlet boundary conditions. The speaker is unsure if their approach is correct and is getting different results compared to using Matlab PDE toolbox. They also discuss different discretization methods and the use of relaxation factor to speed up calculations. The summary concludes by mentioning specific code used to calculate for the boundary points with Neumann and Dirichlet boundary conditions.
JohanL
158
I tried to solve laplace equation for the steady state temperature over a rectangle with both neumann and dirichlet boundary conditions.
For the part of the rectangle with neumann boundary condition(normal derivative = 0) i used
U(k,p)=(2*U(k+1,p)+U(k,p+1)+U(k,p-1))/4
Is this correct?
The result i get is different from when i use Matlab PDE toolbox...and i think I am doing something wrong with the neumann boundary condition.
Assuming you used discretisation:
[tex]\frac{1}{h^2}(u_{i+1}-2u_i+u_{i-1})[/tex]
Say your b.c. is at X=0 (T for temp. etc.):
[tex]\frac{\partial T(0,t)}{\partial X}=0[/tex]
For the discretisation, you don't know [tex]u_{i-1}[/tex] but you can rewrite the discretisation as:
[tex]\frac{1}{h}\left(\frac{u_{i+1}-u_i}{h}-\frac{u_i-u_{i-1}}{h}\right)[/tex]
Where the [tex]\frac{u_i-u_{i-1}}{h}[/tex] bit is given by the b.c.
I did it like this
if given homogenous neumann boundary condition for the points (0,j)
Laplace equation gives
4*T(0,j)=T(1,j)+T(-1,j)+T(0,j+1)+T(0,j-1) (*)
then
dT/dx=0 for those boundary points and i used
dT/dx=[T(1,j)-T(-1,j)]/2*h
and (-1,j) is outside the domain so i use
T(-1,j)=T(1,j)-2*h*dT/dx
and substituting this into (*) gives
4*T(0,j)=T(1,j)+T(1,j)-2*h*dT/dx+T(0,j+1)+T(0,j-1)
but dT/dx=0 which gives
4*T(0,j)=2*T(1,j)+T(0,j+1)+T(0,j-1)
______________________________________
in the code i have T=U and (i,j)=(k,p). The neumann boundary is for k=1 or Nx and 12<p<20 and otherwise dirichlet boundary conditions.
Nmax=500; eps=10^(-3); n=0; delta=1; % parametrar
while abs(delta)>eps & n<Nmax
n=n+1
for k=2:Nx-1
for p=2:Ny-1
if (k==1) & (12<p<20)
dU(k,p)=(2*U(k+1,p)+U(k,p+1)+U(k,p-1))/4 ...
-U(k,p);
U(k,p)=U(k,p)+om*dU(k,p);
elseif k==Nx & 12<p<20
dU(k,p)=(2*U(k-1,p)+U(k,p+1)+U(k,p-1))/4 ...
-U(k,p);
elseif (k~=1) | (k~=Nx)
dU(k,p)=(U(k+1,p)+U(k-1,p)+U(k,p+1)+U(k,p-1))/4 ...
-U(k,p);
else
U(k,p)=U(k,p)
end
end
end
delta=max(max(dU)); disp(delta);
end
I would rather leave interior domain points to Laplace discretization, and in the Neumman boundary I would chose either a 2nd order central derivative approx centered just on the boundary point and applying an image point at -1, or a one-sided 2nd order derivative in which you obtain the boundary point value as a function only of the inner points.
Clausius2 said:
I would rather leave interior domain points to Laplace discretization, and in the Neumman boundary I would chose either a 2nd order central derivative approx centered just on the boundary point and applying an image point at -1.
Isnt that what I am doing? (if you by image point mean phantom point?)
Or is it something wrong with my approach?
In the code its of course is
for
k=1:Nx
First i calculate for the points on the boundary which have a neumann boundary condition:
-U(k,p);
elseif k==Nx & (12<p<20)
-U(k,p);
where om is a relaxation factor to speed up the calculations.
Then i calculate for the interior points
-U(k,p);
and finally
else
U(k,p)=U(k,p)
for those boundary points with dirichlet boundary conditions
Nx = 36; Ny = 32;
U=zeros(Nx,Ny);
U(1:Nx,Ny)=100;
U(1:Nx,1)=20;
U(1,20:32)=100;
U(Nx,20:32)=100
U(1,1:12)=20;
U(Nx,1:12)=20;
FAQ: Neumann boundary with finite differences
What is a Neumann boundary condition in finite difference method?
A Neumann boundary condition in finite difference method is a type of boundary condition where the derivative of the dependent variable is specified at the boundary instead of the value of the variable itself.
How is a Neumann boundary condition applied in finite difference method?
A Neumann boundary condition is applied by using a finite difference approximation to the derivative at the boundary and including it in the overall set of equations to be solved.
What is the purpose of using a Neumann boundary condition in finite difference method?
The purpose of using a Neumann boundary condition is to accurately model physical systems that have a flux of some quantity (such as heat or fluid flow) at the boundary instead of a fixed value.
How does a Neumann boundary condition affect the overall accuracy of a finite difference solution?
A Neumann boundary condition can affect the overall accuracy of a finite difference solution by introducing truncation errors at the boundary due to the approximation of the derivative. However, with appropriate grid refinement and numerical methods, this effect can be minimized.
Are there any alternative methods for handling Neumann boundary conditions in numerical simulations?
Yes, there are alternative methods such as the finite element method and the spectral method that can handle Neumann boundary conditions more accurately and efficiently than finite difference method in certain cases.
