Neuron parts identification question
In summary, a cell culture is shown with bright areas that are phase positive and areas that are phase negative. These areas represent the outgoing and incoming traffic of a neuron. The cell bodies are not always in the center of the array of neurites and growth cones.
Biology news on Phys.org
It is a view through either a phase contrast or maybe a differential interference contrast microscope.
The bright areas are "phase positive" where the interference is positive (making it very bright) rather than negative (darker than background).
This is a cell culture so it is not easy to tell if the "string-looking-like parts" are axons (outgoing signal path from the neuron) or dendrites (incoming signal path). They are usually called neurites in cultured cells. Cultured cells are usually grown on a flat surface, which makes it easy to visualize all their parts at one time.
It is a time-lapse movie which is why things are moving fast.
I am guessing they are some kind of vesicles (membrane enclosed structures).
They are moving fast because they are being "transported" probably along microtubules (pulled by little protein motors that latch on to the vesicle and move along the microtubule).
Can't tell what their contents are, but that might have something to do with their brightness (due to how they interact with the light). Cells in culture are not always "normal" or an obvious member of a well defined cell type.
The cell bodies (third paragraph) would usually be at the center of an array of neurites. Flat grey areas at the distal end of neurites are growth cones which put out a lot of small fine processes that "sense" their local environment and direct which way the neurite will be further extended. Growth cones and their fine processes contain a lot of actin. Actin can also move things around, but not so much in the neurites.
Likes Psinter
Points of electrical activity?
Probably not.
Here and here are a couple of examples of electrical activity in neurons that is visualized with voltage sensitive dyes.
The first one also shows two traces, one of the light intensity and the other an electrode measured voltage potential, but it does not indicate where in the picture the electrode is.
BillTre said:
Probably not.
Phase contrast, you were right.
Likes BillTre
Thanks.
The Physics Forums Way...
We Value Productivity
• Honest recognition of own weaknesses
I guess this question was too advanced for me :sorry:. But there's an answer I hope others can understand.
What I understood:
  • Neurons have two different physical paths: one for incoming traffic and one for outgoing traffic.
  • There are sacks called vesicles. That is the little rounded thing containing the little glowing things in the image.
  • Because this is a culture, it may not represent reality accurately.
What I didn't understood:
  • Protein motors?
  • Actin? I looked at the Wikipedia article, but this is... this is too advanced.
Psinter said:
Protein motors
There are many kinds of protein motors.
They are encoded by genes and act as nanomachines that can move around in some way. They provide the physical motive forces in cells.
Protein motors, in this case dynenin, move along the microtubules (which act like railroad tracks), dragging the vesicles along with them.
Actin forms filaments in muscle, which myosin also moves along. This is what powers muscle contraction. There are of actin and myosin any varieties in vertebrates which are turned on in different cells and do additional other things.
Likes Psinter
Did anyone ever trace this video back to the originators or source of publication? I didn't find them when I tried.
Likes Psinter
What video?
Psinter said:
What video?
That the OP is questioning.
The original video is a pretty standard looking thing.
There are many equivalent videos to that.
Oh. That video. Lemme check... Loading...
Aha, found it! If you hadn't asked I wouldn't have thought about tracing its origins. It's:
In the description of the video is a description that says that the bright spot is a nucleus. Now I'm glad I asked this question :biggrin:. I mean, it didn't cross my mind to look for the original. Thanks.
Edit: Although the video description is not using a certain tone. I felt the tone of the description like that of someone assuming. That's my perception.
Likes BillTre
If all those bright spots are nuclei there would have to be a lot of small cells around.
Guess its possible.
BillTre said:
If all those bright spots are nuclei they would have to be a lot of small cells around.
Guess its possible.
Since phase contrast was used, I'm not sure if we could even visually pinloint what was nuclei or not! It would be different if the visual markers of "bright spots" had been altered with dyes to begin with, but I'm not sure after realizing it was phase constrast. Finding the original study and the methods used other than phase constrast might clue us on to what is happening in the video!
Likes BillTre
There is an impression of dyes being used, to me at least.
Related to Neuron parts identification question
1. What is a neuron?
A neuron is a specialized cell that transmits information throughout the body. It is the basic unit of the nervous system and is responsible for carrying out all the functions of the brain, spinal cord, and nerves.
2. What are the main parts of a neuron?
The main parts of a neuron are the cell body, dendrites, axon, and axon terminals. The cell body contains the nucleus and other organelles, while the dendrites receive signals from other neurons. The axon is responsible for transmitting signals to other neurons, and the axon terminals release neurotransmitters to communicate with other cells.
3. How do you identify the different parts of a neuron?
The cell body is usually the largest part of the neuron and can be easily identified by its round shape and presence of organelles. Dendrites are smaller branches that extend from the cell body, while the axon is a long and thin structure that extends from the cell body. Axon terminals can be identified as small bulges at the end of the axon.
4. What is the function of the dendrites?
The main function of dendrites is to receive signals from other neurons and transmit them to the cell body. They contain specialized receptors that bind to neurotransmitters released by other neurons, triggering a response within the cell.
5. How do axons transmit signals?
Axons transmit signals through a process called action potential. When a signal reaches the axon, it causes a change in the electrical charge inside the cell, which triggers the release of neurotransmitters from the axon terminals. The neurotransmitters then travel across the synapse and bind to receptors on the dendrites of the next neuron, continuing the transmission of the signal.
  • Biology and Medical
  • Materials and Chemical Engineering
  • General Discussion
18K
  • Quantum Physics
  • Feedback and Announcements
  • Astronomy and Astrophysics
