Neutral intermediate boson to neutrinos are flavor preserving
In summary: The amplitudes to get mass1 or mass2 or mass3 are not the same for electron neutrino and muon neutrino and tauon neutrino So the neutrino that comes out of a W boson interaction is in a superposition of mass states ...But pure mass eigenstates are not what interact with W bosons ...The mass states are NOT the same as the interaction states ...In summary, the conversation discusses the relationship between flavor eigenstates and mass eigenstates in neutrino interactions. It is mentioned that if the couplings of the neutral intermediate boson to neutrinos are flavor preserving, they are also diagonal when expressed in terms of mass eigenstates. The conversation also touches on the concept of unitary change of basis
physciencer
23
Hey guys!
How can this sentence be explained and what does it mean?
If the couplings $$Z\nu_{\alpha}\bar{\nu}_{\beta}$$ of the neutral intermediate boson to neutrinos are flavor preserving, they are also diagonal when expressed in terms of mass eigenstates $$Z\nu_{i}\bar{\nu}_{j}.$$
Welcome to PF;
where did you see this sentence?
But it pretty much means what it says. What's the problem.
Thank you Mr Simon! It is in https://www.amazon.com/dp/0201328321/?tag=pfamazon01-20 this book. But I can't see it mathematically speaking. Mind explaining it in mathematical terms, like if there is a proof that I can read to picture this better? In other words, how does it come about?
Note: the context has to be accessible to me. Presumably you don't expect me to buy the book and skim through 300+ pages just to understand your question?
There's a second motivation in getting you to spell out the context - the act of trying to explain a problem to someone else so they understand it often leads to an insight that solves the problem.
Do you not understand some of the words?
What level of education does the explanation need to be pitched at?
I can't find available pdf online. You said that it says what it says, so I assumed that this is clearly written. So if I want to restate my question, why is it that if the couplings of the neutral intermediate boson to neutrinos are flavor preserving, then they are also diagonal when expressed in terms of mass eigenstates?
Edit: Explanation of whatever you feel comfortable at. Graduate level explanation perhaps?
The sentence, by itself, describes an interaction - it does not say that one of the properties leads to the other one, just that the properties are properties of the interaction that will also be described in the resulting lagrangian.
Basically it means that you get the neutrinos out that you put in, and that the interaction provides a basis in which the M (in ##\phi^\dagger M \phi##) is diagonal.
If it means anything else, that will be in the context.
You have the text, you can tel me what the chapter is about (i.e. neutrino oscillations) and you can reproduce the paragraph that it appears in just by typing it out ... whatever you think best describes the context that the author has in mind. Otherwise it is impossible to go into detail.
So this was written at the end of the chapter and was part of questions the author thought was intuitive to answer because he didn't refer it to any paragraph or section in the book. In other words, nothing was attached to this question. So the Chapter was Electroweak Interactions of Leptons and I guess the author is thinking that one can answer this according to total understanding of the chapter (perhaps). I will list the subtitles of chapter 6 hoping they would clear what is the chapter handling.
An Effective Lagrangian for the weak interactions
Intermediate vector bosons: A first look
The standard electroweak theory of leptons
neutral-current interactions among leptons
The higgs Boson: A first Look
The Higgs boson, Asymptotic behavior, and the 1 TeV scale
Neutrino Mixing and Neutrino Mass
Renormalizability of the theory
I hope this will help in clearing things up.
This is a trivial matter of a basis change. If the interaction is diagonal with the same strength for all flavours, then it is proportional to the unit matrix. Changing basis will not affect the unit matrix. If the strengths are different, this is no longer true.
May you please explain this using mathematical terms and how mass eigenstates practically enter? Why is it if they are flavor preserving they are also diagonal when expressed in terms of mass eigenstates? @Orodruin
Edit: Is there a passage in some books that explains what is going on here because as I mentioned the book I am using does not really explain this or where did it pop up from. If you could suggest a read for me to understand this better?
There really is not much more to understand than the fact that the identity operator is left invariant under a unitary change of basis. This should be in any basic textbook on (complex) linear algebra.
How does this relate to mass eigenstates or mass operator?It is probably this that I can't link? @Orodruin
Because you can make a change in your basis and go from flavor eigenstates to mass eigenstates.
Then why is that when flavors are of the same strength then the matrix should be proportional to identity?
Because the interaction is based on electroweak gauge theory, which is where the coupling strength comes from.
So electroweak theory says if flavors are of the same strength then the representative matrix is identity? If so, why does it say so?
Basically because all of the neutrinos are in the same type of SU(2) multiplet and the coupling strength comes from the covariant derivative.
Likes physciencer
Also if flavor is conserved, can't you think of the interaction Hamiltonian commutes with the mass matrix? so they both can be simultaneously diagonalized?
Please elaborate, was that a question or an answer? If an answer, why would the interaction Hamiltonian commute with the mass matrix if the flavor is conserved. I can't relate.
Not necessarily, it would not be the case if flavour was conserved but different flavours had different coupling strengths. If they have the same coupling strength, then yes, everything commutes with the identity operator.
But you were already talking about strength rather than flavors. I am confused now.. What happened? Is it that conserved flavors make the matrix proportional to identity matrix or is it not? :(
Maybe it would be worthwhile to plod through and define every word...
Neutrinos have mass eigenstates with well defined masses...
But the neutrinos that come out of a Weak Force interaction are NOT in mass eigenstates ... They are in FLAVOR eigenstates ( electron muon tauon ) depending upon the other leptons in said interaction
The flavor eigenstates are superpositions of the mass eigenstates
Note I think the opposite is true as well, if the neutral boson interaction is not diagonal in flavor then it is also not diagonal in mass ?
No, conserved flavours does not imply proportional to unity, conserved flavour along with equal coupling does. My last post was a response to Chris' question.
No, this is not true. You could perfectly well have an interaction which is diagonal in one basis but not in another, just not the normal electroweak gauge interaction, which is proportional to the unit matrix in both bases.
But the problem doesn't talk about equal couplings?
The question was: Why is it if the couplings of the neutral intermediate boson to neutrinos are flavor preserving then ...
They did not say any thing about the "same strength" you mentioned in what I quoted. Did you assume that to make the sentence hold?
If you write a Lagrangian for the couplings of the Flavor-States of the neutrinos to the Z it would be something like :
## L = Z \nu_{i} V^{ij} \bar{\nu}_{j} ##
where V is the coupling-strength constants in matrix form.
if there is NO FLAVOR VIOLATION, meaning the interaction is FLAVOR PRESERVING, then there are NO OFF-DIAGONAL elements of ##V^{ij}##.
If all 3 are the same "Strength" then you can write it as the identity matrix times a constant.
If NOT, then you have a matrix that is like {{a,0,0},{0,b,0},{0,0,c}}
I was going to respond that its trivial to show that under a unitary transformation this leaves the couplings diagonal, but now I am not so sure...
Anyone have a solution?
I really don't think it implies that the mass-eigenstates are diagonal in coupling constants at all. A unitary transformation does not conserve this, and you get flavor-state violation between the mass eigenstates where the off-diagonal elements are proportional to the difference between the strengths of the couplings for each flavor state. Right? (everyone else)
Likes TEFLing
Correct. This is also seen directly for the vacuum Hamiltonian of neutrino oscillations. You then have a Hamiltonian which is diagonal in mass basis, but with off diagonal elements proportional to the differences in flavour basis.
If they did not, then they should have or they made that assumption implicitly, since this is a prediction from electroweak theory (at least at tree level).
Likes physciencer
if you make a unitary transformation to the neutrino : [itex] \nu \rightarrow U \nu [/itex] and [itex] \bar{\nu} \rightarrow \bar{\nu} U^\dagger[/itex]
So
[itex] Z \bar{\nu} V \nu \rightarrow Z \bar{\nu} (U^\dagger V U ) \nu[/itex]
The thing is that [itex]U^\dagger V U [/itex] is still diagonal if V is diagonal...?
FAQ: Neutral intermediate boson to neutrinos are flavor preserving
What is a neutral intermediate boson?
A neutral intermediate boson is a type of elementary particle that mediates the weak interaction between other particles. It is responsible for the exchange of energy and momentum in interactions involving neutrinos and other subatomic particles.
How do neutral intermediate bosons relate to neutrinos?
Neutral intermediate bosons are the carriers of the weak force that affects neutrinos. They allow for the transmission of the weak interaction between neutrinos and other particles, causing changes in the neutrino's flavor.
What does it mean for neutrinos to be "flavor preserving"?
"Flavor preserving" refers to the property of neutrinos to maintain their original flavor as they interact with other particles through the weak force. This means that they do not change into different types, or flavors, of neutrinos during these interactions.
How do scientists study the role of neutral intermediate bosons in flavor preservation?
Scientists study the role of neutral intermediate bosons in flavor preservation by conducting experiments that involve interactions between neutrinos and other particles. By analyzing the results of these experiments, they can determine the extent to which flavor preservation occurs and the role of neutral intermediate bosons in this process.
Why is understanding flavor preservation important for scientists?
Understanding flavor preservation is important for scientists because it helps them to better understand the fundamental properties and interactions of neutrinos. This knowledge can also have broader implications for our understanding of the universe, as neutrinos play a crucial role in many astrophysical processes.
