Neutralize chloramines in tap water
  • Thread starter Thread starter watersplit
    Neutralize Water
The discussion centers on the removal of chloramines from tap water using ascorbic acid. It is noted that ascorbic acid can neutralize chloramines, but questions arise regarding the by-products formed during this process and the time required for neutralization. One participant mentions a source stating it takes 1-2 days for the reaction but lacks clarity on the volume of water involved. Concerns are raised about the necessity of knowing the initial chloramine concentration to determine the appropriate amount of ascorbic acid needed for effective treatment. Additionally, there is skepticism about the need for such treatment, given that municipal water systems are designed to ensure safety and manage chloramine levels effectively. The conversation highlights the importance of understanding water quality before attempting any treatment.
watersplit
Hi
I want to remove chloramines from tap water and I read it's possible to do by adding ascorbic acid in the water. Here is the source: https://en.wikipedia.org/wiki/Chloramination#Removing_monochloramine_from_water
So I was wondering what substances are the chloramines being changed into (the by-products) during the process?
And how long time would it take to neutralize 1L of water (adding maximum 100mg ascorbic acid, which is more than enough)? The page of the provided address says it takes 1-2 days but it doesn't say how much water. Perhaps the amount of water doesn't matter?
Chemistry news on Phys.org
Have you checked that you have chloramines in water, or are you still chasing things you don't understand?
Likes russ_watters
I have not performed any analysis on the water, but it is described in the website of the municipal water treatment plant that a small amount of chloramine is added.
How are you going to calculate how much neutralizer you need if you don't know how much is in it?
How do you know this is even something worth doing if you don't know how much is in it?
The page of the provided address says it takes 1-2 days.
That isn't what it says.
More info:
https://www.fs.fed.us/t-d/pubs/html/05231301/05231301.html
And you assume they don't know what they doing?
From your IP it seems like you live in one of the countries with safest drinkable water in the world. Traces are there to keep the water safe and to kill pathogens, and their levels are selected low so that the dose is not dangerous for people. I told you earlier: you won't make your water better than people that trained for many years do it for you.
Likes DaveE, berkeman, BillTre and 1 other person
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
