Neutron Beam Width after localization via a slit in a sheet (QM)
In summary, a parallel beam of neutrons with speed 200m/s is incident on an absorbing sheet with a slit of width 0.01mm. Using the uncertainty principle, the width of the beam 10m behind the slit can be calculated by finding the associated uncertainty in momentum and using it to estimate the momentum and velocity of the neutrons. The distance traveled in 1/20th of a second can then be calculated, resulting in a beam width of approximately 2mm.
LowBathWater
A parallel beam of neutrons with speed 200m/s is incident on an absorbing sheet with a slit of width 0.01mm. Calculate the width of the beam 10m behind the slit.
Hint The slit localizes the neutrons transversely (y) to their propagation direction x. The resulting ΔPy gives a range of sideways motions, associated with the y uncertainty, superimposed on the x motion.
neutron mass: 1.67x10-27kg
Momentum: P
1) Tn=(h/2pi)2n2/2ma2 explicit kinetic energy calculation for given excitation state n
2) Δy2=a2[(1/3)-(1/2pi2n2)] mean square of positional variance
3) T=mv2/2 kinetic energy
4) T≥(h/2pi)/2m(Δy)2 kinetic energy of confinement demonstrated by uncertainty principle
5) ΔyΔPy≥(h/2pi)/2 uncertainty principle
where n=excitation state, m=mass, a=width of potential well (slit width), v= velocity, T= kinetic energy, Δy=uncertainty in y (y=position in y dimension)
i'm currently working through a quantum mechanics primer text and have come to an exercise where I am a little uncertain (no pun to be inferred) whether my reasoning is leading me anywhere close to the general direction of the solution since no solutions are given in the text or online support materiel. The text so far has taken the wave function approach introducing the time-independent Schrodinger equation in one dimension as a postulate then studying its consequences for an infinite square well potential.
Workings
Ty=(h/2pi)2pi2/2(1.67x10-27)(0.01x10-3)2
Ty=mvy2/2
vy=√2Ty/m
=√(h/2pi)2pi2/(1.67x10-27)2(0.01x10-3)2
=(h/2)√1/(1.67x10-27)2(0.01x10-3)2
t=10/200-1/20
d=vy/20
w=2d+0.01(10-3)
=[vy/10]+(0.01x10-3)
=[(h/20)√1/(1.67x10-27)2(0.01x10-3)2]+(0.01x10-3)
=1.99502994x10-3m
≈2mm
EXPLANATION
My initial approach was to model the slit as an infinite potential localizing the particles in the y plane then calculate the kinetic energy of confinement for the ground state via formula 1 in the y direction (I assumed that the wave function would be in its ground state as no excitation, only localization, had occurred). From this I then calculated the potential speed in the y direction via rearranging formula 3. I then calculated that it would take a neutron 1/20th of a second to travel 10 meters. Using this value I calculated the distance d a neutron could travel in the y direction given the previously calculated speed. I reasoned that a neutron could "exit" the slit at either side owing to the nature of the wave function inside the slit and that the associated uncertainty in momentum meant that said particle could have a positive or negative velocity (travelling left or right) of previously calculated magnitude. Therefore particles could travel d either in the positive or negative y direction giving a beam width at ten meters of 2d+0.01mm. Using this method I got a value of approximately 2mm.
I am very uncomfortable with this method as it felt very botched when I came up with it. Firstly I am unsure what happens when the neutrons enter and exit the slit. I assumed their wave functions acted akin to the wave function in a potential well in the y dimension. The phrase, "The resulting ΔPy gives a range of sideways motions, associated with the uncertainty in y" gives me the feeling that that I was supposed to use equation 2 at some point, especially as it was derived in the immediately preceding exercise, because my method doesn't explicitly involve a range of motions. considering inequalities 4 and 5 I can appreciate that if I made and explicit calculation of Δy2 for n=1 I could have a potential range of motions.
The neutrons are not trapped in any potential well. Those energy states are not relevant (even if I think you can get a similar numerical value with the ground state).
Just use the slit width (or half of it, usually a factor of 2 does not matter here) as position uncertainty, and calculate the corresponding momentum uncertainty. The remaining calculations are classical physics.
Alternatively, you can use the de-Broglie wavelength of those neutrons.
Ok thank you. So I use the uncertainty inequality to calculate the associated uncertainty in momentum then I take that value as an estimate for the momentum calculate from that the velocity then find the distance traveled in 1/20th of a second? I should mention at this point that I'm an AS UK student so may be missing a few things in terms of mechanics. I've self taught the M1 syllabus now covering the M2 materiel, looking over the A2 physics syllabus too. However I have already covered the whole A level maths syllabus so there's a lot of the maths behind the quantum that I'm fine with. Just needed to put my difficulties into context. It's riveting!
Right.
I have no idea what those abbreviations mean, but I guess it is not important.
mfb said:
Right.
Sorry, forgot this is not a UK forum. They're just maths modules I've taken M for mechanics etc...
Not really important, just stating I'm a bit Naive about things.
Again cheers.
Related to Neutron Beam Width after localization via a slit in a sheet (QM)
1. What is a neutron beam width?
A neutron beam width refers to the size or diameter of a beam of neutrons, which is a type of subatomic particle. It is typically measured in units of length, such as millimeters or micrometers.
2. How is the neutron beam width affected by localization via a slit in a sheet?
When a neutron beam passes through a narrow slit in a sheet, it undergoes a process called localization, which means that its position becomes more precise. This also causes the beam width to become narrower, as the neutrons are confined to a smaller space.
3. What is the role of quantum mechanics (QM) in determining the neutron beam width after localization?
Quantum mechanics (QM) is the branch of physics that describes the behavior and interactions of subatomic particles, such as neutrons. In the case of localization via a slit in a sheet, QM principles dictate that the position and momentum of the neutrons become more precise, resulting in a narrower beam width.
4. Can the neutron beam width be controlled or adjusted after localization via a slit in a sheet?
Yes, the neutron beam width can be controlled by adjusting the size of the slit in the sheet. A narrower slit will result in a narrower beam width, while a wider slit will result in a wider beam width.
5. How does the neutron beam width after localization via a slit in a sheet impact experiments and applications?
The neutron beam width plays a crucial role in experiments and applications that use neutron beams. A narrower beam width allows for more precise measurements and interactions with materials, while a wider beam width may be more suitable for certain experiments that require a larger coverage area.
