Neutron flux in coolant and fuel pin in PWR
In summary, PWR reactors use fast neutrons produced from fission in fuel, which are then moderated into thermal neutrons by collisions with the coolant (H2O). This results in a difference in the multi-group neutron flux between the coolant and fuel pin, with the fuel pin having a higher concentration of fast neutrons and the coolant having a higher concentration of thermal neutrons. Data on the comparison of multi-group neutron flux in coolant and fuel pin can be obtained using lattice codes such as CASMO or WIMS, with MCNP also being an option. These codes use a small number of groups that are collapsed from a larger number, and the neutron energy spectrum is usually not reported. The meshing of the lattice is important and finer
Pengtaofu
23
In PWR, fast neutron produced from fission in fuel has been moderated into thermal neutron by the a series of collisiion with coolant,i.e. H2O. So the multi-group neutron flux in coolant and fuel pin has much diffenrce, e.g. the relative higher fast neutron in fuel pin and relative higher thermal neutron in coolant as to the uniform.
Are there specific data about comparision of multi-group neutron flux in coolant and fuel pin in PWR, if it don't need to use MCNP to simulate it ? Thank you very much.
I'm not sure about the question, but one would ordinarily use a lattice code, e.g., CASMO or WIMS, in conjunction with a core simulator, e.g., SIMULATE or PANTHER, respectively, to calculate the neutron flux and fission density. Using MCNP is also an option.
WIMS Physical models :
explicit water gap;
grids homogenisation;
WIMS Numerical models :
condensed to 6 groups for pin by pin calculation;
2D XY diffusion theory (GOG);
DMOD option (local transport theory correction for neighbouring rods of perturbing cells such as guide tubes or Gd burnable absorber rods)
http://www.answerssoftwareservice.com/resource/pdfs/139.pdf
http://www.jofamericanscience.org/journals/am-sci/am1002/019_23211am100214_125_131.pdf
In general, one would use a small number of groups, e.g., 2 or 4, which are collapsed from a larger number of groups. The WIMS paper mentions 69 groups, but newer versions (WIMS 9 or 10) use more groups. The group neutron spectrum is usually not reported since that would be a tremendous volume of data over time/burnup for even 1/8 or 1/4 of an assembly. Usually, there is a numerically processed mean or smeared value.
Meshing the lattice is also important, and finer meshes are more often used now, because we have access to faster processors and greater memory capacity.
Normally, one does not look at the neutron energy spectrum in the coolant or fuel, unless one is digging into the details of a calculation, e.g., looking at specific cross-sections, or effects of specific nuclides/isotopes. The codes process the multigroup data and collapse into two, three or four groups, depending on the code system, and the flux is smeared over the fuel, cladding and coolant.
OK. Thank you very much for providing the general introduction and the papers .
Related to Neutron flux in coolant and fuel pin in PWR
1. What is neutron flux in a PWR?
Neutron flux is the measure of the number of neutrons passing through a specific area in a nuclear reactor, such as a pressurized water reactor (PWR). It is an important factor in controlling the rate of nuclear reactions and determining the power output of the reactor.
2. What is the role of coolant in neutron flux?
Coolant, typically water, is used to transfer heat generated by nuclear reactions in the fuel pins to the steam generators in a PWR. It also serves as a moderator, slowing down neutrons to increase their chances of causing fission in the fuel pins and maintaining a continuous chain reaction.
3. How does neutron flux affect the fuel pins in a PWR?
Neutron flux can cause damage to the fuel pins in a PWR due to the high energy and heat produced by the nuclear reactions. This can lead to swelling, distortion, and even failure of the fuel pins, which can impact the overall performance and safety of the reactor.
4. How is neutron flux controlled in a PWR?
Neutron flux is carefully monitored and controlled in a PWR through a combination of control rods, which absorb neutrons to regulate the rate of reactions, and the addition or removal of coolant to adjust the temperature and density of the reactor core.
5. What are the potential consequences of high neutron flux in a PWR?
High neutron flux in a PWR can lead to overheating and damage to the fuel pins, which can result in a loss of power output and potential release of radioactive materials. It is important to carefully monitor and control neutron flux in order to maintain safe and efficient operation of the reactor.
  • Nuclear Engineering
