New basis for atoms of spatial geometry (intertwiners)
In summary, Freidel and Hnybida's paper discusses the use of intertwiners in quantum geometry and the need for a set of basis vectors for the Hilbert space. They propose a third set of basis vectors that have advantages over the previously proposed sets and reveal a Regge limit. This concept is related to the use of intertwiners in both Loop Quantum Gravity and spin foam models. The paper focuses on 4-valent intertwiners but also mentions the potential for extension to the n-valent case.
marcus
Dearly Missed
24,775
792
Here's the introduction of the paper by Freidel and Hnybida. Quantum geometry is built up of chunks of geometry that contain information relating to volume, areas, angles made with neighbor chunks, etc. The Hilbert space that these chunks (called intertwiners) live in needs a set of basis vectors. The two sets of basis vectors proposed so far have drawbacks. Freidel and Hnybida have discovered a third set of basis vectors that will be better to work with and reveals a Regge limit.
==quote http://arxiv.org/abs/1305.3326 page 1==
It has been observed long ago that the compositions of quantum states of angular momentum are related to geometrical objects [1–3]. The simplest example is the Clebsch-Gordan coefficients which vanish unless the spins satisfy the so called triangle relations. A less trivial example is the Wigner 6j symbol which vanishes unless the spins can represent the edge lengths of a tetrahedron. This insight was one of the motivations which led Ponzano and Regge to use the 6j symbol as the building block for a theory of quantum gravity in three dimensions [4, 5], together with the fact that the asymptotic limit of the 6j symbol is related to the discretized version of the Einstein-Hilbert action. In higher dimensions this line of thought led to the idea of spin foam models which are a generalization of Ponzano and Regge’s idea to a four dimensional model of quantum General Relativity. For a review see [6].
Following a canonical approach, Loop Quantum Gravity came to the same conclusion: Geometrical quantities such area and volume are quantized [7]. In fact there are many remarkable similarities between LQG and spin foam models. For instance, the building blocks of both models are SU(2) intertwiners which represent quanta of space [8–10]. An intertwiner is simply an invariant tensor on the group. In other words if we denote by Vj the 2j + 1 dimensional vector space representing spin j then an intertwiner is an element of the SU(2) invariant subspace of this tensor product which we will denote
Hj1,...,jn ≡InvSU(2)[Vj1 ⊗···⊗Vjn].
The vectors in this Hilbert space will be referred to as n-valent intertwiners since they are represented graphically by an n-valent node. The legs of this node carry the spins ji which can be interpreted as the areas of the faces of a polyhedron [11–14] which is a consequence of the celebrated Guillemin-Sternberg theorem [15]. In this paper we will be focused on 4-valent intertwiners but many of the methods developed here can be extended to the n-valent case.
==endquote==
It's sort of boring that there aren't any spare structures "chunk of geometry" free to braid into specific structures that can yield specific fields, like string theory does.
Related to New basis for atoms of spatial geometry (intertwiners)
1. How is the concept of "intertwiners" different from the traditional understanding of atoms in spatial geometry?
The traditional understanding of atoms in spatial geometry is based on the idea of indivisible, point-like particles that make up matter. In contrast, the concept of "intertwiners" proposes that atoms are actually made up of smaller, interconnected units that give rise to their properties and behavior.
2. What evidence supports the idea of "intertwiners" as the basis for atoms?
There is not yet enough evidence to definitively prove the concept of "intertwiners" as the basis for atoms. However, some theoretical models, such as loop quantum gravity and spin networks, suggest that space itself may be made up of interconnected units, which could support the idea of "intertwiners" as the building blocks of matter.
3. How does the concept of "intertwiners" impact our understanding of the structure of matter?
If the concept of "intertwiners" is proven to be accurate, it would significantly change our understanding of the structure of matter. It would mean that atoms are not the smallest units of matter, and that there are smaller, interconnected building blocks that make up everything we see in the universe.
4. Can "intertwiners" explain the behavior of subatomic particles?
The concept of "intertwiners" is still in the early stages of development and there is not enough evidence to definitively say whether it can explain the behavior of subatomic particles. However, some researchers suggest that the interconnected nature of "intertwiners" could potentially explain certain phenomena, such as entanglement and quantum tunneling.
5. How could the concept of "intertwiners" impact future research and technology?
If the concept of "intertwiners" is proven to be accurate, it could open up new avenues for research and technology. It could potentially lead to a deeper understanding of the fundamental nature of matter and help us develop new technologies based on the principles of interconnectedness and interdependence.
  • Quantum Physics
  • Beyond the Standard Models
  • Poll
