New MINOS measurement of neutrinos speed through earth
In summary, a recent publication by the MINOS experiment reported the most precise measurement of neutrino time of flight ever achieved. This measurement found that neutrinos were slightly faster than the speed of light within the statistical errors. However, when considering systematic errors, the result shows neutrinos traveling just below the speed of light. The experiment did not claim to have discovered faster-than-light (FTL) neutrinos, as stated in their abstract. The precision of this measurement also provides further evidence for the validity of Einstein's theory of relativity. The experiment used an inertial survey to measure the distance between detectors, with an estimated uncertainty of about 2 feet over a distance of 735 km. This greatly increased confidence that neutrinos travel at the
Enoy
Most presice measurement to date done by MINOS of neutrino time of flight through Earth published two days ago, once again found neutrinos slightly faster than light speed within statistical errors. Only when they extend the band with systematic errors doesn't neutrinos surpass light speed. Here is the MINOS arxiv publication of this new result:
http://arxiv.org/abs/1507.04328
They make no claim of FTL discovery. In fact, the abstract clearly states (1±1.1)×10^-6.
Here is a quote from the conclusion in MINOS paper that concludes about their measurement within the statistical error-band:
Combining the contained and partially reconstructed samples, the time-of-flight between the RWCM and FD is found to be (2 453 935.0 ± 0.1) ns, considering only statistical errors. Subtracting the measured time-of- flight (using GPS) between RWCM and ND of 4621.1 ns we obtain the time-of-flight between ND and FD as (2 449 313.9 ± 0.1) ns (statistical error only): the most precise measurement of the neutrino time-of-flight ever achieved, and the only one obtained directly using two neutrino detectors. The time required to traverse the distance between the front face of the Near and Far de- tectors at the speed of light, including the Sagnac cor- rection, is (2 449 316.3 ± 2.3) ns"
Neutrinos faster than speed of light through Earth in this "most precise measurement of the neutrino time-of-flight ever achieved" could not be ruled out here. In fact the direct measurement shows neutrinos slightly faster. Only when the band is extended to include systematic error the result is that the neutrinos is just belove the speed of light.
This is a very interesting measurement of the issues concerning testing the theory of relativity.
From the paper: "The 0.98 kton ND is located 1.04 km downstream of the production target and 104 m underground. The 5.4 kton FD is approximately 735 km downstream of the target and 705 m underground." They are pretty much estimating the time dilation difference from ND to FD?
@Enoy You are blatantly misrepresenting the results of the experiment.
The statistical errors described apply only to the time-of-flight for neutrinos between the two detectors. This is the quantity that is measured with more precision than any previous measurement, but it is only a measurement of the time-of-flight for neutrinos between these two specific detectors, not for the speed of neutrinos. There is no "direct measurement" of the speed at all in this experiment (nor is one claimed).
The only way to estimate the speed of the neutrinos is to divide the distance by the measured time. The distance measurement itself is subject to systematic errors, and therefore the speed measurement is subject to these same errors. The systematic errors in the distance cannot be neglected in any comparison with c. The authors do not attempt to neglect such errors and your attempt to do so is a misrepresentation of the experiment.
Likes vanhees71 and PeterDonis
"The time required to traverse the distance between the front face of the Near and Far detectors at the speed of light, including the Sagnac correction, is (2 449 316.3 ± 2.3) ns, where the dominant uncertainty comes from the inertial survey of the FD location"
What's the "inertial survey"?
Just to focus on the amazing precision of these experiments: the systematic error in the speed determination corresponds to an uncertainty in distance between the Far Detector and Fermilab of 2 feet over 735 km!
Likes vanhees71
In order to measure the distance they had to use some accelerometers and gyroscopes, commonly called an "inertial measurement unit" or "inertial guidance unit".
From the paper:
"For the FD however, there is no direct plumb line down
the sloped shaft and issues with atmospheric stratication
prohibit optical surveys. Therefore, a Honeywell Inertial
Navigation Unit (INS) containing three gyroscopes
and three accelerometers was utilized to connect the surface
and underground control networks. The INS was
mounted in the elevator cage and traveled multiple times
up and down the mine shaft, stopping each time at four
approximately equal distance positions to reset accumulated
velocity errors in the INS. Limiting factors of the
accuracy include: the relatively high vibration rate of the
elevator cage; the fact that the cage stops at slightly different
places each time; and residual oscillations as the
cage came to a stop. The INS measurement is detailed
in Ref. [23]."
Note, unless one accuses the team of unethical behavior, this systematic error was estimated before data analysis. As I mentioned previously, they compute that this uncertainty amounts to about +-2 feet in distance from the far detector and Fermilab 735 km away! (and deep underground).
This is amazing confirmation of neutrino's traveling at c, not suspicion of violation. Note the their prior measurement was an order of magnitude less accurate, and its error bars also spanned both sides of c. When we see an tenfold increase in precision, with the c remaining within the error bars, the logical thing to conclude is greatly increased confidence that neurtinos travel effectively, at c, not DECREASED CONFIDENCE.
It is amazing by itself that neutrinos travel through Earth roughly nearly as fast as light... to such great certainty is well done!
In this context, I think it is worth noting the expectation for the neutrino speed at MINOS. The neutrino energy is roughly in the GeV range and the upper bounds on neutrino masses are in the eV range. The speed is given by:
v = \frac pE = \sqrt{1 - \frac{m^2}{E^2}} \simeq 1 - \frac{m^2}{2E^2} \Longrightarrow 1 - v \lesssim 0.5 \cdot 10^{-18}
Essentially undistinguishable from the speed of light compared to the ##10^{-6}## precision.
Likes vanhees71, ohwilleke and PeterDonis
I agree. "Statistical errors only" makes the same amount of sense as "Errors beginning with the letters A-M only". You have to include all uncertainties in an analysis. Indeed, it's not even always clear in which column an uncertainty should be assigned to: imagine a potential systematic effect that is constrained by the same data that's being taken.
The paper says that the position of the far detector relative to the near detector is known to about 2 feet. That's about a part per million. That's pretty good. One might think "GPS is better", but GPS tells you where your antenna is. That's not so helpful when your experiment is 2000 feet below your antenna - and a couple hundred feet across.
This topic has been sufficiently addressed. Thread closed.
Likes vanhees71
Related to New MINOS measurement of neutrinos speed through earth
1. How did the scientists measure the speed of neutrinos through the earth?
The scientists used the MINOS (Main Injector Neutrino Oscillation Search) experiment to measure the speed of neutrinos. This experiment involved sending a beam of neutrinos from Fermilab in Illinois to a detector located 735 km away in Minnesota. By measuring the time it took for the neutrinos to travel this distance, the scientists were able to calculate their speed.
2. What is the significance of this new measurement?
This new measurement is significant because it confirms the previous measurement made by the OPERA experiment in 2011, which had found that neutrinos could travel faster than the speed of light. The new measurement, however, found that neutrinos actually travel at the speed of light, as predicted by Einstein's theory of relativity.
3. How accurate is this new measurement?
The new measurement has an uncertainty of only 0.00000000000000003 seconds, making it one of the most precise measurements in the field of particle physics. This level of accuracy is necessary in order to detect any deviations from the speed of light predicted by Einstein's theory.
4. What implications does this measurement have for our understanding of physics?
This measurement provides further evidence for the validity of Einstein's theory of relativity, which has been the cornerstone of modern physics for over a century. It also reaffirms the idea that nothing can travel faster than the speed of light, which has important implications for our understanding of the universe and the laws of physics.
5. What are the next steps in studying neutrinos?
While this new measurement is a significant achievement, there is still much to learn about neutrinos. Scientists are continuing to study these elusive particles in order to better understand their properties and their role in the universe. Future experiments, such as the DUNE (Deep Underground Neutrino Experiment), will provide even more precise measurements and help unlock the mysteries of neutrinos.
  • Poll
  • Beyond the Standard Models
