New technique for residual stress measurement NDT
In summary: This makes it a valuable tool for understanding the effects of loads and treatments on the surface of a material.The technique works by analyzing elastic oscillations or vibrations in the material, which are caused by reactions from the elemental masses in the material. These waves propagate at a constant speed and can be measured using an accelerometer mounted on the surface of the material. The results are displayed in N/mm², making it a quick and simple way to measure residual stress.One important aspect to note is that the accuracy of the test depends on the quality of the surface, as it needs to be smooth and free
Residual stress measurement
  • Portable residual stress NDE
    Votes: 0 0.0%
  • Measurement stresses in metals
    Votes: 1 50.0%
  • metals stress measure ndt
    Votes: 1 50.0%
  • New technique measure residual stress
    Votes: 0 0.0%
  • Total voters
ennio curto
NEW TECHNIQUE FOR RESIDUAL STRESS MEASUREMENT NDT
Introduction
Internal stresses are to be considered as the following: 1) Operational strains referring to loads that the material is subject and calculated 2) Residual stresses in the material caused by heat treatments or stresses caused by welding, forging, casting, etc. The new technique is able to measure the applied load and residual stress that are balanced on the surface of the material, and in a relatively large volume, at times even the same size as the entire structures. This stress is part of the metal’s elasticity field and has a three axis spatial orientation.
Description
Elastic oscillations (also called vibrations) of an elastic material consisting of elementary masses alternately moving around their respective balance positions; these movements cause a transformation of the potential energy into kinetic energy. This phenomenon takes place due to reactions (elastic forces) that the aforementioned masses produce in opposition to elastic movements; these reactions are proportional according to Hooke’s Law to the same movements. The elastic waves that are produced propagate according to a fixed speed that depends on how rapidly the elemental masses begin to oscillate.
Elastic waves of this type are called “permanently progressive”, and they propagate at a constant speed which is absolutely independent of the speed with which the elemental masses move during the oscillating motion, and therefore also their respective oscillations. It is easy to verify that the elastic oscillations, from a material point P (in which the elemental mass m is supposedly concentrated) are harmonic. In reality, due to the fact that in any moment the elastic force that is applied to P is proportional to the distance x of the point from its position of balance 0, P acceleration (caused by the proportionality between the forces and the corresponding accelerations) is also proportional to x; this is demonstrated in the harmonic movement. The impulse creates in the metallic mass a harmonic oscillation (vibration) which is characterized by a specific frequency ω² and by a width equal to dx (movement of the relative mass). If a constant impulse is produced in the metallic material, the elastic oscillation generated in the P point will also produce a sinusoidal wave with specific width, acceleration, speed and period values. This wave is longitudinal when the direction of the vibration is equal to the P point movement, or is transversal, and in both cases the values of the results are identical; the only difference is the ¼ delay of the phase.
Impact with the metallic surface results an elastic deformation energy.
Fig. 1
Ed = Ei – ( Ek + Ep )
Ei = Impact energy Ek = Kinetic energy
Ed = elastic deformation energy Ep = plastic deformation energy + lost energy
Ed = ½ K dx² = ½ m ω² dx² K = constant elastic material (stiffness)
Behaviour elastic metals, due to new discovery.
Fig. 2
The system works through the accelerometer mounted with a magnetic base to generate the acceleration value of the vibrations created by the device impacting on the metal surface. The acceleration value, in combination with other parameters, permits obtaining the exact value of the residual stress or load applied in the desired point. This value will appear on the display directly in N / mm ². For non-magnetic metals, wax or gel will be used to mount the accelerometer.
The system doesn’t recognize the compressive from tensile stress.
Fig. 3
Quality of surface
The test method requires smooth surfaces free of oxides, paint, lubricants, oil. The indentation deep and the accurately of the test depend from the roughness of the surface. For the preparation of the surface, is necessary, must be careful not to alter the surface over certain values of heating or hardening. More practical results can be realized by using a high-speed grinder (> 12000 rpm).
Conclusion
Application of this type of non-destructive method NDT provides the possibility to measure residual stress and the effect of the service load in a very rapid and simple way on any point of the metallic surface.
The testing method requires smooth surfaces free of oxides, paint, lubricants and oil. Precision depends on the roughness of the surface.
This technology has demonstrated its validity over years of mechanical experimentation and has confirmed its theoretical basis.
About residual stress
The residual stress in a metal doesn’t depend on its hardness, but from the elasticity module or Young module and from its chemical composition.
The hardness of a metal indicates its ability to absorb elastic or plastic energy, but through it not possible to determine the value of residual stress. In a metal with the same hardness we will have different values of this stress. .
The residual stresses tend to equilibrate themselves in the surface of the material.
The measurement made with all the major methods, X-ray, string gauge (destructive), optical etc. the residual stress is determined between the measuring the displacement of the equilibrium point the reticule crystalline.
The method discovered analyzes the value of frequency and vibratory acceleration generated by an impulse with the subsequent reaction elastic (elastic field) from the metal.
You will realize the convenience of this technique.
1) Portable system easy to use and very swift.
2) NDT non-destructive test.
3) Repeatable in unlimited number of points.
4) All metals type (a-magnetic)
5) Don’t expensive. Effective for welding, hardened treatments, vessels control, bridges, pipes line, aeronautics, NDT inspection for every metal types.
p.i. Ennio Curto.
Dear Ennio Curto,
Thank you for sharing about this new technique for residual stress measurement in the NDT forum. I find this technology to be very interesting and potentially useful in various industries such as welding, aeronautics, and materials testing.
One of the key benefits of this method is its non-destructive nature, which allows for repeated testing in multiple points without causing any damage to the material. This is especially important in industries where the integrity of the material is crucial, such as in the aerospace or medical fields. The ability to measure residual stress on different types of metals is also a significant advantage, as it allows for a wide range of applications.
I also appreciate the emphasis on the smoothness and cleanliness of the surface for accurate results. This shows attention to detail and a thorough understanding of the testing process. I believe this new technique has the potential to provide more precise and reliable results compared to traditional methods.
I am curious to know more about the specific parameters and calculations used to determine the residual stress and load applied in a given point. Additionally, I would be interested in seeing some real-world examples or case studies where this technique has been successfully applied.
Overall, I believe this new technique has the potential to greatly benefit the NDT industry and I look forward to seeing its development and implementation in the future. Thank you for sharing your research and findings with the forum.
Related to New technique for residual stress measurement NDT
1. What is residual stress measurement NDT?
Residual stress measurement NDT (Non-Destructive Testing) is a technique used to determine the internal stresses present in a material or structure without causing any damage to it. It is a non-invasive method that allows for the assessment of residual stresses that may lead to material failure.
2. How does the new technique for residual stress measurement NDT work?
The new technique for residual stress measurement NDT utilizes X-ray diffraction to measure the internal stresses in a material. This involves directing an X-ray beam onto the material and measuring the resulting diffraction pattern. By analyzing the changes in the diffraction pattern, the residual stress can be calculated.
3. What are the advantages of using this new technique for residual stress measurement NDT?
This new technique offers several advantages over traditional methods of residual stress measurement. It is non-destructive, meaning it does not cause any damage to the material being tested. It is also highly accurate and can provide quantitative measurements of residual stress. Additionally, it is a relatively quick and cost-effective method.
4. What types of materials can be tested using this new technique for residual stress measurement NDT?
This technique can be used to measure residual stress in a wide range of materials, including metals, ceramics, polymers, and composites. It is particularly useful for materials that are difficult to test using traditional methods, such as thin films and complex structures.
5. Are there any limitations to this new technique for residual stress measurement NDT?
Like any other measurement technique, there are limitations to this new method for residual stress measurement NDT. It is important to ensure that the X-ray beam is directed at the correct location to get an accurate measurement. The technique is also not suitable for measuring residual stresses on the surface of a material, as it only provides measurements of internal stresses.
29K
