New Theory: from Superfluids to Higgs mechanism
In summary: It sounds like they are saying that their theorem is valid for systems that are spatially and rotationally invariant. However, they do not mention anything about material design. In summary, the theorem unifies superfluids and other weird materials.
Naty1
5,606
40
Theorem unifies superfluids and other weird materials
http://newscenter.berkeley.edu/2012/06/08/theorem-unifies-superfluids-and-other-weird-materials/
Nambu Goldstone bosons...of the Higgs Mechanism!..and phonons...from Cosmology to materials design.
“Surprisingly, the implications of spontaneous symmetry breaking on the low energy spectrum had not been worked out, in general, until the paper by Watanabe and Murayama,”
Thoughts? Insights?? Sounds BIG to this observer.
I came across this while trying to learn more about the Higgs mechanism for 'creating' mass during the Big Bang. Very unexpected to find this!
While this is interesting (I attended a seminar recently that covered the same type of topic), it is not surprising. Note that Anderson's work on broken symmetry greatly influenced the subsequent formulation of the Higgs mechanism, so that came directly out of condensed matter.
This is just one of the numerous examples where condensed matter formulations are being applied in areas that are considered to be "fundamental physics".
Zz.
Laughlin and Pines also ranted a bit on the same line, in their article "The theory of everything" (PNAS 97 28 (2000)):
http://www.ncbi.nlm.nih.gov/pmc/articles/PMC26610/
For example, they also point the relationship between the Higgs mechanism and conventional superconductivity; and that ultimately such links exist because in general low-energy phenomena do not depend on the details of the microscopic systems and are universal in some sense. The theorem this press release applies to (http://prl.aps.org/abstract/PRL/v108/i25/e251602) does a contribution to shed some more light on the "in some sense" part. It is not a new theory, just a theorem in a context which is known to be relevant in many areas of physics. I cannot judge how important this particular insight is, but maybe some other person might.
At this moment this looks to me like a standard press release which... let's say... might transport a somewhat overoptimistic view of the impact of a particular publication of the same institution. I've seen the same kind of press release applied for other articles in my own field, to articles which really did nothing extraordinary. You need to be careful with such things. It's advertisement by a university for itself.
The article is available at arxiv:
http://arxiv.org/abs/1203.0609
It is about counting the number of Goldstone bosons in ron-relativistic systems. This is quite interesting as for example there are no Goldstone bosons for broken rotational symmetry.
An easy theory when we have to count with Goldstone bosons would be quite useful.
Glancing briefly at the paper, it's not clear to me that their result is consistent with your statement.
For example, suppose rotational symmetry is broken e.g. down to rotations about the z-axis. Then we have two broken generators, Jx and Jy, but even if <Jz> is non-zero, there is no way 2 - 0 = (1/2)*rank since the rank is <= 3. Of course, their counting is consistent with the single gb in a ferromagnet.
What gives?
More generally, its not clear how general their result is. Does it work for spacetime symmetries (a classic question even in the relativistic context)? What if the system is on a lattice and doesn't have rotational invariance at all?
At the moment I can't tell if its more than just a formalization of the old fact that ferromagnets have one gb while antiferromagnets have two, but then i wonder if their formula is really so much better than just writing down the effective theory? Nevertheless, I don't want to downplay their formula too much as it is an interesting achievement.
Also, in my opinion you should ignore the hype about material design and so forth. It's a neat result in an old field (which makes it more impressive), but at the end of the day its still information contained in the low energy theory which we understand very well (for goldstone bosons).
"We assume spatial translational invariance
and rotational invariance at sufficiently long distances in
the continuum limit, while we can still discuss their SSB."
I am not quite sure what they mean here.
FAQ: New Theory: from Superfluids to Higgs mechanism
1. What is the Higgs mechanism?
The Higgs mechanism is a theory in particle physics that explains how particles acquire mass. It proposes the existence of a Higgs field that permeates the entire universe and interacts with particles, giving them mass.
2. How does the Higgs mechanism relate to superfluids?
The Higgs mechanism is based on the concept of spontaneous symmetry breaking, which is also observed in superfluids. In superfluids, the symmetry of the system is broken at low temperatures, resulting in the particles behaving as if they have no mass, similar to the effect of the Higgs field on particles in particle physics.
3. What evidence supports the Higgs mechanism?
The existence of the Higgs boson, a particle predicted by the Higgs mechanism, was confirmed in 2012 by experiments at the Large Hadron Collider (LHC). Additionally, the Higgs mechanism is able to explain several phenomena in particle physics, such as the weak nuclear force and the mass of fundamental particles.
4. Can the Higgs mechanism be tested and potentially disproven?
Yes, the Higgs mechanism can be tested through experiments at particle accelerators like the LHC. If the Higgs boson was not observed or if its properties were found to be significantly different than predicted by the theory, it could potentially disprove the Higgs mechanism.
5. How does the Higgs mechanism contribute to our understanding of the universe?
The Higgs mechanism is a crucial part of the Standard Model of particle physics, which is our current best explanation of how the universe works at a fundamental level. It helps us understand the origin of mass and the interactions between particles, providing a more complete picture of the universe and its fundamental building blocks.
