New to astrophysics, don't have a good physics foundation, need some help
In summary, the time it takes for a radio signal to travel from Earth to a starship traveling at 0.8c is 6 months, and the time it takes for a radio signal to travel from the starship to Earth is 1.5 years.
Aurealis
Hi everyone,
So I have always been interested in space, and when my college offered an intro to astrophysics course with no prerequisites, I jumped at the opportunity. I had already had a lower level astronomy/physics course, and physics and astronomy in high school, so I thought I'd be fine, but am now finding that everything is a much bigger struggle than presupposed! I learn quickly and just need to find access to some basic concepts, as my grasping at remenants from high school physics is not really getting me anywhere.
Here is a problem that I understand loosely how to set up, but I don't quite know which formula to use or which values to put where:
An astronaut in a starship travel to a Centauri, a distance of approximately 4 ly as measured from Earth, at a speed of u/c=0.8.
d.) A radio signal is sent from Earth to the starship every 6 months, as measured by a clock on Earth. What is the time interval between reception of one of these signals and reception of the next signal aboard the starship?
In previous parts of the problem I solved that the trip to "a Centauri" takes 5 years, as measure by a clock on Earth, 3 years, measured by the pilot, and the distance between the two measured by the pilot was 2.4 ly.
Now, I realize that I need to figure out how long it will take a radiowave to the starship at distance A, then how far the starship travels in 6 months, then how long it will take a radiowave to travel distance B. Radiowaves travel at the speed of light, and the starship is traveling at a speed of u/c=0.8. I believe I need to use some manipulation of the formula:
y=1/(sqrt(1-(u^2)/(c^2))) (excuse the "y" instead of the appropriate symbol, working with a keyboard, you know how it goes)
But I am just not sure how to manipulate, or what exactly to put where...and I'm sure it's an extremely intuitive problem, I'm just messing up/not seeing little things. Any help would be appreciated! Also if anyone has any helpful facts about online astrophysics tutoring, or anything, please let me know!
Astronomy news on Phys.org
Aurealis said:
Hi everyone,
Hi Aurealis
If you draw a Minkowski diagram for the ship and the Earth reference frames, then the answers appear graphically. The y-axis is Earth-time, the x-axis is space, and light moves in lines at 45 degrees to the y-axis. To move at 0.8c the ship-line rises 5 units for every 4 along the x-axis. An even number of ticks up the y-axis marks the six-month Earth time-steps, 10 in total. The first one at six months leaves when the ship is at 0.8*0.5 light years out, assuming instant acceleration. To work out their intercept let's look at the two lines, light and ship.
Light moves with a slope of 1, and the first pulse's origin is at x=0, y=0.5 (in light-years & years.) Thus y = x + 0.5
Ship moves with a slope of 1.25, thus...
y = 1.25x
They intercept at where the equality holds true...
x + 0.5 = 1.25x
i.e. x = 2, and so y = 2.5
...and so forth for the rest of the pulses. One problem is that some pulses won't be received until after the ship has arrived and presumably stopped moving with respect to Earth (approximately so since Alpha Cen moves w.r.t. Earth.) In that case the ship's time returns to being a vertical line, but 4 light years away from the Earth axis and starting at y = 5.
The ship board clock (y') measures the ticks to arrive at 0.6 times the Earth clock time-span, thus the first arrives after (0.6*2.5) = 1.5 years, the next at x = 4, thus y' = 3 years. Back on Earth, the year 3 time-pulse from the ship's clock wouldn't arrive until 9 years after the ship set out. The so-called "Twin Paradox" isn't apparent until the ship and Earth have returned to each other's proximity, at y=10 & y'=6 if the ship returned to Earth immediately after arrival at Alpha Centauri at the same speed. Then the mismatch becomes apparent.
If we naively derived the ship's average speed by dividing the distance to Alpha Centauri by the time-pulses received by the ship from Earth, then the speed would be 4 times lightspeed. But this is an unphysical "speed", akin to the super-luminal pulses seen emitting from some Quasars.
Thank you!
So, another question. I need to determine photons/m^2, and I have wavelength and flux. exact problem reads:
Using the peak emission wavelength of Sirius A as an estimate of the average wavelength and assuming that the flux is reduced by a factor of two due to atmospheric absorption, determine the number of photons/m^2
Any help is EXTREMELY appreciated!
Depends on the luminosity of Sirius assumed and the distance one is computing the number of photons/m^2. What figures do you have?
Shoot, I had...flux, absolute bolometric magnitude, and luminosity i think? I think I ended up dividing wavelength by the speed of light, and then multiplying the...flux by that time I think? Yes. Is that right? It was for a take home test that I already turned in, but I still want to know how to actually do the problem, since I'll have to do more like it later!
If you know the flux (J/m^2) then you need to know the energy per photon (E = hc/λ) and then divide the flux by the photon energy, after you work out the peak wavelength (λmax = b/T) where b is the Wien's displacement constant (2.898E-3 m.K) and T is the temperature of the emitting source (Sirius A in this case.) Sounds like you've come close, but Planck's constant is needed somewhere in the mix.
Thank you, that was very helpful!
FAQ: New to astrophysics, don't have a good physics foundation, need some help
1. What is astrophysics and why is it important?
Astrophysics is the branch of astronomy that focuses on the physical properties and processes of celestial objects and phenomena. It is important because it helps us understand the fundamental laws of physics and how they apply to the universe, allowing us to gain a deeper understanding of the cosmos and our place in it.
2. What are some key concepts I should know before diving into astrophysics?
Some key concepts to have a good understanding of before starting astrophysics include classical mechanics (Newton's laws of motion), electromagnetism, thermodynamics, and special relativity. Having a strong foundation in these areas will make it easier to grasp the principles of astrophysics.
3. What resources are available to help me learn about astrophysics?
There are many resources available for learning about astrophysics, including textbooks, online courses, videos, and scientific journals. You can also attend lectures and workshops, join astronomy clubs or societies, and participate in research projects to gain practical experience.
4. How can I improve my physics foundation for astrophysics?
The best way to improve your physics foundation for astrophysics is to start with the basics and work your way up. You can begin by reviewing fundamental concepts and equations, and then move on to more advanced topics. It's also helpful to practice problem-solving and critical thinking skills, as they are essential in astrophysics.
5. Are there any common misconceptions about astrophysics?
Yes, there are some common misconceptions about astrophysics. One is that it is only for extremely intelligent people or geniuses, when in reality it is a subject that anyone can learn with dedication and effort. Another misconception is that astrophysics is all about studying black holes and galaxies, when in fact it covers a wide range of topics such as the formation of stars, the structure of the universe, and the behavior of matter and energy in space.
