Newb question about relativistic mass
In summary: So relativistic mass is just another term for "excess energy".It's just another term for "excess energy".
Involute
Based on my limited understanding of special relativity, as an object's velocity increases with respect to an observer the object undergoes spatial contraction (making it appear to the observer to get thinner in the direction of travel) and time dilation (so the observer would view the object's clock tick more slowly than the observer's, if he could see it). The object also gains relativistic mass, though, and I was wondering how, if it all, this would manifest to the observer?
The concept of relativistic mass is not used any more in physics. It just leads to misconceptions.
"Gains relativistic mass" is just another way to say it gains energy, with the usual effects.
Einstein predicts that things have higher kinetic energy than Newton predicts for the same speed. The extra bit used to be attributed to an "increase in mass", which sometimes let's you use Newtonian formulas with this revised mass. These days that's (by most physicists) regarded as a silly way of looking at it, especially as there are several different relativistic masses that need to be used in different places, and several places where you can't use any kind of relativistic mass in that naive way (notably, gravity). So the concept has largely gone out of fashion.
In terms of effects, a faster moving object will hurt more when it hits you. More according to Einstein than Newton.
Likes FactChecker and Nugatory
One way is with collisions. Momentum is conserved in collisions between particles, so for example in a one-dimensional two particle collision the momentum lost by one particle equals the momentum gained by the other. The momentum equals ##\gamma mv## where ##m## is the ordinary mass. The factor ##\gamma## increases with the particle's speed. So if you want you can call ##\gamma m## the relativistic mass and say that it's the thing that increases with speed. But regardless of whether or not you do this, momentum will not be conserved if you instead use the Newtonian value for momentum ##mv##.
Thus the answer to your question, the way this would manifest itself is that you wouldn't be able to predict or understand what's happening to particles in these collisions.
This is not correct. The "increase in mass" is the mass equivalent of all the kinetic energy (i.e., all excess energy over the rest energy), not just the part that's larger than the Newtonian prediction.
Fair enough. The extra momentum predicted by relativity is due to the increase in mass - the energy is different.
Just one example of why relativistic mass is a bad idea.
I'm not sure what you mean by this. If ##m## is the rest mass, then energy is ##E = \gamma m c^2## and momentum is ##p = \gamma m v##. Both of them have the factor ##\gamma m##, which is "relativistic mass" and shows the same "increase in mass" in both cases. So I'm not sure what is "different" about energy.
The "extra mass" is ##(\gamma-1)m##. The difference between the relativistic and Newtonian momenta is ##(\gamma-1)mv##, which is the Newtonian momentum which would be associated with the extra mass. So in a "relativity is simpler if you pretend it's Newton plus relativistic mass" kind of way, the "extra" momentum is attributable to the "extra" mass. That line of argument doesn't apply to energy, as you point out, because the relativistic formula doesn't look like the Newtonian one with relativistic mass dropped in.
I don't think this is completely rigorous.
Ibix said:
The difference between the relativistic and Newtonian momenta is ##(\gamma-1)mv##, which is the Newtonian momentum which would be associated with the extra mass...That line of argument doesn't apply to energy, as you point out, because the relativistic formula doesn't look like the Newtonian one with relativistic mass dropped in.
Ah, I see. Got it.
(##c = 1##)
Unfortunately, the enthusiastic killing off of "relativistic mass" wasn't accompanied by an equally enthusiastic inclination to express momentum in terms of energy.
If you'd asked a physics student forty years ago for the equation for "relativistic momentum," I bet they'd respond with ##\mathbf{p} = m_r \mathbf{v}##. Ask one today, and I bet they'll respond with ##\mathbf{p} = \gamma m \mathbf{v}##, which is a less complete answer!
Three cheers for ##\mathbf{p} = E \mathbf{v}##, which applies even in the massless case.
That depends of course entirely on your definition of ##m_r##. If you define it as ##E## then yes, but if you define it as ##\gamma m## then not.
If that physics student of 40 years ago had asked his professor (the very one who taught him about ##m_r##) if a photon has mass, the answer would be "No" more often than yes. Followed by a confused discussion of whether it was okay to equate the photon's energy to its mass and a clarification by the professor that he meant rest mass. (And then the student might respond that photons can never be at rest, but I digress.)
Perhaps this is what Einstein meant when he cautioned against its use, saying that "no clear definition can be given" for relativistic mass. And that was way more than 40 years ago!
True.
But still, ##\vec{p}c = E \vec{\beta}## is nice, eh?
Likes Mister T
SiennaTheGr8 said:
True.
Yes. I agree that it's great and I also agree that it doesn't get the press it deserves in introductory treatments.
Likes SiennaTheGr8
SiennaTheGr8 said:
True.
Nice, but when you get to dynamics, you see a great value for m:
F = mA in 4-vectors.
This fits nicely with P = mU, with U being 4-velocity; just take the derivative by proper time to get the former.
Energy is present here only as the time component of 4 momentum. Of course, you then have to make special cases for light. On the other hand, dynamics of classical massless particles in SR has many difficulties, so it can be argued that light should only be treated as a classical field, not as in terms massless particles.
Rest energy ##E_0## does the trick, too. :smile:
3-momentum: ##\vec p c = E \vec \beta##
3-momentum in the classical limit: ##\vec p c \approx E_0 \vec \beta##
4-momentum: ##\vec P = E_0 \vec B## (where ##\vec B## is the "normalized" 4-velocity)
3-force in the classical limit: ##\vec f \approx E_0 \dot{\vec{\beta}}## (where dot means ##ct##-derivative)
4-force: ##\vec F = E_0 \mathring{\vec{B}}## (where little circle means ##ct_0##-derivative)
Normalization need not be imposed for derivatives by proper time. In the last, the derivative is by proper time. Not sure what your t0 means. Possibly time in an MCIF. That seems conceptually inferior to proper time as an invariant, independent of frames or coordinates, applying to GR as well as SR.
m is fewer keystrokes than E0 :smile:. Also, this doesn't relieve the issue that when you get into force as well as momentum, you have to admit massless particles are problematic, and light is a special case.
Sorry, I should have mentioned that my ##t_0## is proper time, and ##ct_0## is just proper time expressed in length units (the timelike spacetime interval, if you prefer).
Yes, in SR the four-momentum is better defined in component form ##(E, \vec p c)## than in terms of the four-velocity.
As for force—is there really reason to admit the massless case in SR (for either 3-force or 4-force)?
No good reason to have theory of classical massless particles (it has been done, but it is very ugly IMO). So once you admit light doesn't work the same as particles, then 4 momentum in terms of 4 velocity for particles is extremely natural.
There is no relativistic mass, only invariant mass. There is relativistic energy of a classical system,
$$E=\sqrt{m^2 c^4+p^2 c^2},$$
In the center-momentum frame, where the total momentum is by definition 0, you have ##E_{\text{cm}}=m c^2##, and nowhere else!
Out of curiosity: does anyone know whether proponents of "relativistic mass" ever expressed kinetic energy in mass units ("kinetic mass")?
In other words, we have:
##E = E_0 + E_k = m_r c^2##
but did anyone ever introduce ##m_k \equiv E_k / c^2##? Then:
##m_r = m + m_k##
I've never seen it!
Yes sure, and high-energy theorist use Natural Units, i.e., setting ##c=1## and ##\hbar=1##. Then space and time intervals are measured in one unit (usualy femto meters) and masses, energies, end momenta (usually Giga electron Volts). In fixed-target experiments one usually quotes the kinetic energy ##E_{\text{kin}}=E-m=
\sqrt{m^2+p^2}-m## of the beam.
I understand that setting ##c=1## unifies the dimensions of mass, energy, and momentum, but that's not really what I was asking.
My question is a historical one. I'm wondering whether folks who use(d) "relativistic mass" ever went so far as to introduce a "kinetic mass" ##m_k = E_k / c^2##. Just curious.
I'm not aware of it, but who knows what the people in the very early days of relativity have come up with to make their lives difficult. The real understanding of the math of special relativity is due to Hermann Minkowski, whose original article on the subject is really very good and should be read by every physicist:
https://en.wikisource.org/wiki/Translation:Space_and_Time
Likes SiennaTheGr8
I don't. The closest I've seen to that kind of thing is the use of the term rest mass energy. To distinguish it from, I guess, "relativistic mass energy". The difference would then be the "kinetic mass energy". All silliness, of course, since I've never seen anyone use "relativistic mass energy" or "kinetic mass energy".
I would like to just interject a comment. Comments like "making it appear...to get thinner" are a pet peeve of mine. Lengths along the relative velocity direction do get shorter; how they appear depends on the position of the observer and could be shorter, longer, or the same.
Careful. Certainly how they appear (in the sense of observing them with a camera or the old Mk I eyeball) depends on where you are. But "do get shorter" isn't an assumption-free statement either. It depends on using Einstein's synchronisation convention. Einstein's convention is eminently sensible, but you aren't required to adopt it and the relationship between lengths measured by observers in different states of motion depends on the convention you do adopt.
Related to Newb question about relativistic mass
1. What is relativistic mass?
Relativistic mass is a concept in physics that describes the increase in an object's mass as it approaches the speed of light. This is a result of the object's energy and momentum increasing as it gains speed.
2. How is relativistic mass different from rest mass?
Rest mass is the mass of an object when it is not moving, while relativistic mass takes into account the object's velocity and the effects of relativity. Relativistic mass is always greater than or equal to rest mass.
3. Why is relativistic mass important?
Relativistic mass is important because it helps us understand the behavior of objects at high speeds, such as in the field of particle physics. It also plays a role in the theory of relativity and has practical applications in fields like astrophysics and engineering.
4. How is relativistic mass calculated?
Relativistic mass can be calculated using the equation m = m0/√(1-v2/c2), where m0 is the rest mass, v is the velocity, and c is the speed of light. This equation takes into account the effects of relativity on an object's mass at high speeds.
5. Is relativistic mass a constant value?
No, relativistic mass is not a constant value. It increases as an object's velocity approaches the speed of light, and becomes infinite at the speed of light. This is why the concept of relativistic mass is often considered obsolete and has been replaced by the concept of relativistic energy.
