Is the Collision Formula Provided Accurate for Low-Speed Vehicle Impacts?
  • I
  • Thread starter Steve Max
In summary, the formula S1' (post impact) = (1 + e) X ((S2 - S1) / (1 + W1 / W2)) + S1, where S = speed in mph, W = weight of vehicles 1 (bullet) and 2 (target), and e = restitution, originates from conservation of momentum and is used to calculate the post-impact speeds of vehicles involved in a rear-end collision. However, it requires specific information such as the masses and coefficient of restitution to be able to solve for the post-impact speeds accurately.
Steve Max
Can someone help me clear up where this formula originates and if it is correct?
Has to do with a low speed in line bullet vehicle front end impacting the rear of a stopped target vehicle.
S = Speed in mph
W = Weight of vehicles 1 (bullet) and 2 (target)
e = restitution (a decimal value from 0 to 1)
Welcome to PF;
The equation originates from wherever you got it from... I sort-of know what you mean, but in order to answer your question properly, we need to know where you saw it.
It is likely that the equation comes from conservation of momentum and a bunch of experiments in which cars were crashed into each other.
The equation tells me that vehicle 2 hits vehicle 1 from behind, and bounces off.
If #1 is "stopped" then put S1=0. For cars, "e" is something you'd have to estimate (it is determined empirically.)
Likes berkeman
Thank you for the help. You are indeed on the right track.
The formula was offered by a biomechanical engineer and I don't fully understand it.
I believe its origin is from a momentum-energy-restitution approach to solving for post impact speeds of vehicles involved in a rear end impact.
Veh 1 is the bullet at speed. Veh 2 is the stopped (no brakes) target. Veh 1 front strikes veh 2 rear.
In this scenario, veh 1 (4760 lbs) is at 10 mph when its front strikes the rear of a stopped veh 2 (4967 lbs).
I'm trying to understand the methodology and know if it is appropriate.
This is what I received:
I think you need to be specific - I do not understand what you want to calculate.
Try just using your normal language instead of attempting to use the jargon.
Initially it sounded like "a vehicle" as in an automobile colliding with another one as both travel along the road ... OR, a moving automobile colliding with a stationary one... NOW it sounds like a stationary one has been shot.
What you are hoping to use the information for is also important for what we tell you.
Right now your question has been answered.
I'll give you a couple of examples of how these equations get derived:
1. A bullet m speed u collides with a stationary vehicle M and is embedded in it.
##mu = (M+m)v## ... this is conservation of momentum. Conservation of energy is usually not useful in macroscopic collisions.
The speed of the two after the collision is: ##v=mu/(M+m) = u/(1+(M/m))##
2. A bullet m speed u collides with a stationary vehicle M of coefficient of restitution e, bounces directly back ...
##mu = Mv-mu'## ... by definition: ##e=(v+u')/u## so ##u' = eu - v## so
The speed of the vehicle after the collision is: ##v=mu(1+e)/(M+m) = (1+e)u/(1+(M/m))## ... the speed of the bullet would have m/M instead of M/m.
I appreciate and value your help, but I am a little confused with your symbol use.
can S1 be the pre-impact speed of veh1 (Bullet). S1 = 10mph
can S2 be the pre-impact speed of veh2 (Target). S2 = 0mph
S1' = post impact speed veh1
S2' = post impact speed veh2
Looking for S1' and S2' first off.
Fair enough: I'll do this in two parts ...
The equation you have been given has object 1 and object 2 are the target and the bullet respectively, with primed symbols representing the post-impact quantities. Using that W2'=W2 tells you that the post-impact weight of the bullet is the same as the pre-impact weight.
Then: S1=0, S1'=v, S2=u, S2'=u', W1=Mg, W2=mg.
... where I write two symbols together as in "mg" I imply a multiplication - in this case "mass times gravity".
This is the standard way to do physics.
So for example 1: the bullet strikes a stationary target and sticks to it:
conservation of momentum: (W2/g)×S2 = (W1/g)S1' + (W2/g)S2'. After some algebra this means: S1' = W2×S2/(W1+W2)
I would write that as $$v=\frac{mu}{m+M}=\frac{u}{1+\frac{M}{m}}$$ ... see how that looks tidier?
So this would be backwards from the equation you were given.
So: "no", you cannot use the equations like that.
Using (from example 2 above) $$v = \frac{mu(1+e)}{m+M}$$
... then v is the post-collision speed of the target: one of the things you want to find.
u=10mph
You need to know m (mass of bullet), M (mass of target), and e (coefficient of restitution), as well.
So m=4760lbs and M=4967lbs ... still need ##e##.
So there is not enough information to complete the calculation.
Again: what do you want to know these things for?
FAQ: Is the Collision Formula Provided Accurate for Low-Speed Vehicle Impacts?
1. What is the meaning of "newbie"?
"Newbie" is a slang term commonly used to refer to someone who is new or inexperienced in a particular activity, field, or community.
2. How should I ask a question as a newbie?
As a newbie, it is important to do some research and familiarize yourself with the community and its guidelines before asking a question. Make sure to be clear and specific in your question, provide any relevant information or context, and be respectful in your language.
3. Is it okay to ask basic questions as a newbie?
Yes, it is perfectly fine to ask basic questions as a newbie. Asking questions is a great way to learn and improve your understanding. However, make sure to do your own research first and avoid asking the same question that has already been answered.
4. How can I get help as a newbie?
There are several ways to get help as a newbie. You can reach out to more experienced members of the community, join forums or discussion groups, or consult online resources and tutorials. It is also helpful to be specific in your request for help and provide any relevant information.
5. What should I do if I receive negative responses as a newbie?
If you receive negative responses as a newbie, do not take it personally. Remember that everyone was once a newbie and it takes time to learn and improve. Stay positive, take constructive criticism, and use it to improve your skills and knowledge.
