Newbie Questions on Band Gap and Fermi Level
In summary, the conversation discusses various concepts related to solid state physics and band gap diagrams. It is stated that crossing the Fermi line in a 1-dimensional band gap diagram indicates a metallic substance. The band gap can be calculated by measuring the energy difference between the closest approach of the bands in the conducting and non-conducting zones. There is a grey zone between non-conducting and wide-gap semiconductors, and the behavior of a system may vary depending on its band gap. It is not always true that a system with a lower Fermi level allows for charge migration. The conversation ends with a request for recommendations for an easily read primer on the topic.
mzottola
I am new to solid state physics, having been in computational chemistry (quantum mechanics) for the larger part of my career. Hence have a lot of newbie like questions that are not easily answered by google/wikipedia searching.
1)In viewing a 1-dimensional band gap diagram, crossing the Fermi line from from either the conducting to non conducting zone or vice versa, is indicative of a metallic substance. Is this correct?
2) In band gap diagrams where there is no crossing of the Fermi line/level, the band gap can still be calculated by measuring the energy difference between the closest approach of the bands in the conducting and non-conducting zones?
3) Are there generally accepted band gaps that one can say a system is either conducting/semiconducting/nonconducting?
4) If the Fermi level for a system changes from a positive value to a negative value, is it a reasonable conclusion that the the system with the lower Fermi level would be more likely to allow charge migration, i.e. a current flow?
Any help and recommendations for an easily read primer are also greatly appreciated.
1) yes
2) yes
3) There is a grey zone between non-conducting and wide-gap semiconductors in the range 3-5 eV. Diamond is usally seen as a pretty good insulator, but in some applications it is used and treated like a semiconductor. Similarly, if there is a very small band gap, smaller than kT, then the system may behave like a "bad metal".
4) not always. Think of an electron-doped semiconductor. You would have to increase the Fermi energy to increase the number of carriers. For a hole-doped semiconductor it is the opposite, of course.
Thanks - I appreciate your timely and clear response.
my pleasure
Related to Newbie Questions on Band Gap and Fermi Level
1. What is a band gap?
A band gap is the energy range in a material where no electronic states are allowed to exist. This means that electrons in the material cannot have energies within this range, resulting in a gap in energy levels.
2. How does the band gap affect the conductivity of a material?
The band gap affects the conductivity of a material by determining whether it is a conductor, insulator, or semiconductor. Materials with a smaller band gap are typically better conductors, while those with a larger band gap are insulators.
3. What is the Fermi level?
The Fermi level is the highest energy level in a material that is occupied by electrons at absolute zero temperature. It is a measure of the thermodynamic properties of a material and is used to describe the distribution of electrons in a material.
4. How does the Fermi level change with temperature?
The Fermi level changes with temperature due to the thermal energy of the electrons in the material. As the temperature increases, the electrons gain more energy and can occupy higher energy levels, causing the Fermi level to shift upwards.
5. Can the band gap and Fermi level be manipulated?
Yes, both the band gap and Fermi level can be manipulated through various methods such as doping, alloying, and applying external electric fields. These techniques can alter the electronic properties of a material and are often used in the design of electronic devices.
  • Atomic and Condensed Matter
13K
