MHB Newline spacing left by 'theorem' environment
  • Thread starter Thread starter mathbalarka
    Theorem
The discussion revolves around formatting issues in LaTeX when using the amsthm package to define theorem environments. A user seeks to eliminate unwanted indentation in the output following a theorem declaration. The solution provided is to set the paragraph indentation to zero with the command \setlength{\parindent}{0pt}, which effectively resolves the issue for regular text. However, the same solution does not apply to the Abstract section. Users suggest using \noindent for the Abstract to achieve the desired formatting. Additionally, the tcolorbox package is recommended for designing theorems, as it offers enhanced customization options, including the newtcbtheorem feature.
mathbalarka
I am using amsthm package in LaTeX, and defined the theorem environment as
Code:
\theoremstyle{plain}
\newtheorem{theorem}{Theorem}
in the usual way. Now if I compile the code
Code:
\begin{theorem}
Some text
\end{theorem}
More text
The output is
Note the spacing appeared in line #2. Is there anyway to remove this?
Do you want to remove indentation from all paragraphs ?
ZaidAlyafey said:
Do you want to remove indentation from all paragraphs?
Yes.
Write the following code preamble.
Code:
No kidding, that works great!
Thanks, Zaid.
PS : I see it doesn't work for the Abstract. Have any ideas on that?
Thanks, Zaid.
Honestly, I was just trying to do the same for abstract but it didn't work. After a search it seems that
Code:
\noindent text
works fine .
Okay, that works well, thanks.
When designing theorems, you should check out the package tcolorbox. It has the option newtcbtheorem.
12K
