Newton Law Gravitation - Multiple choice question?
In summary, Newton's law of gravitation can be applied to the Earth-Moon system and the correct answer to the multiple choice question is B. This is because the gravitational force between the Earth and the Moon is proportional to the inverse of the square of the separation of the two bodies. The value of G, the gravitational constant, remains constant at the surface of both the Earth and the Moon. The mass of the Moon also affects the orbital time of the Moon around the Earth.
jsmith613
614
Newton Law Gravitation - Multiple choice question??
Newton’s law of gravitation can be applied to the Earth-Moon system. Which of the
following statements is not correct?
A The value of G at the surface of the Moon is the same as that at the surface
of the Earth.
B The gravitational force between the Earth and the Moon is proportional to the
square of the separation of the Earth and the Moon.
C The gravitational force between the Earth and the Moon is proportional to the
mass of the Moon.
D The orbital time of the Moon about the Earth is independent of the mass of
the Moon
Lets go through all the options:
A: G is constant so option A is is not the answer
B: F = GMm/r2 so option B is is not the answer
C: using the same equation as above, option C is is not the answer
D: T = 4∏2r3 /GM where M = mass of Earth so option D is not the answer
The answer turns out to be B. Why?
oh of course its an inverse relationship
SMACK!
B. Note that since [itex]\displaystyle{g=\dfrac{G\cdot m\cdot M}{r^2}}[/itex], the force is proportional to the inverse of the square of the radius, or inversely proportional to the square of the radius.
EDIT: Oops, a bit late. Never mind.
cheers anyway :)
Because the gravitational force between the Earth and the Moon is actually proportional to the product of their masses, not the square of their separation. The correct answer would be "The gravitational force between the Earth and the Moon is proportional to the product of their masses."
Related to Newton Law Gravitation - Multiple choice question?
1. What is Newton's law of gravitation?
Newton's law of gravitation states that every particle in the universe attracts every other particle with a force directly proportional to the product of their masses and inversely proportional to the square of the distance between them.
2. What is the formula for calculating the gravitational force between two objects?
The formula for calculating the gravitational force between two objects is F = G * (m1 * m2) / d^2, where F is the force of attraction, G is the universal gravitational constant, m1 and m2 are the masses of the two objects, and d is the distance between them.
3. What is the relationship between mass and gravitational force according to Newton's law of gravitation?
According to Newton's law of gravitation, the force of attraction between two objects is directly proportional to the product of their masses. This means that as the mass of one or both objects increases, so does the force of gravitational attraction between them.
4. How does distance affect the gravitational force between two objects?
The force of gravitational attraction between two objects is inversely proportional to the square of the distance between them. This means that as the distance between two objects increases, the force of attraction decreases.
5. How does the value of the universal gravitational constant affect the gravitational force between two objects?
The universal gravitational constant, denoted by G, is a fixed value that determines the strength of the gravitational force between two objects. A higher value of G means a stronger force of attraction, while a lower value of G means a weaker force of attraction.
