Newton´s second law: Force definition? (Philosophy matter).
Newton's second law is a relation found by Newton between three previously defined things: force, momentum, and time. In summary, Newton's second law is a relation between force, momentum, and time, which defines the change of movement in a body and is based on the three laws of motion.
Luis Babboni
Hi people!
A may be philosophical question, in fact my doubt comes from epistemology class:
Newton´s second law is a definition of force based on 2 previously defined things: momentum and time or is a relation found by Newton between 3 previously defined things: force; momentum and time?
Thanks.
Likes Delta2
Science news on Phys.org
As I see it, Newton's first law defines force as quantity which is necessary, in the sense of a cause, to change the movement of a body. Newton's second law states, that the change of movement is proportional to the force and of the same direction. So a body and its movement are the two quantities, which are previously defined. We identify body with mass (and volume) in this context and it is simply matter, which might be the philosophical part of it, because it refers to something material. Also movement is taken from real life experiences but is better measurable than body as the ratio between change of location in a period of time. Therefore from an epistemological point of view, we need matter, location and time. For a physicist time is what a clock measures, location what can be pointed at, and matter as mentioned above, something with mass and volume. These are measurable quantities for physicists, and subject to existential questions for philosophers. In this sense Newton used very fundamental concepts which are experienced in every day life to deduce the concept of force.
Likes Luis Babboni
The three laws of motion are Newton's definition of force. This definition was required to avoid confusions with other concepts of force (e.g. from Aristoteles).
Likes Luis Babboni
Related to Newton´s second law: Force definition? (Philosophy matter).
1. What is Newton's second law of motion?
Newton's second law of motion states that the acceleration of an object is directly proportional to the net force acting on the object and inversely proportional to its mass.
2. How is force defined in Newton's second law?
Force is defined as any push or pull that causes an object to accelerate. It is measured in Newtons (N) and is calculated by multiplying an object's mass by its acceleration.
3. What is the relationship between force, mass, and acceleration in Newton's second law?
The relationship between force, mass, and acceleration can be summarized by the equation F=ma, where F is force, m is mass, and a is acceleration. This means that the greater the force applied to an object, the greater its acceleration will be, and the greater the mass of the object, the smaller its acceleration will be.
4. How does Newton's second law relate to the concept of inertia?
Newton's second law is closely related to the concept of inertia, which is the tendency of an object to resist changes in its state of motion. Inertia is directly related to an object's mass, so the greater the mass of an object, the greater its inertia will be, and the more force will be needed to change its motion.
5. Can Newton's second law be applied to objects in space?
Yes, Newton's second law applies to all objects, regardless of their location or environment. It is a fundamental principle of physics and is used to explain the behavior of objects in space, such as planets orbiting around the sun.
  • Thermodynamics
  • Classical Physics
  • Mechanics
  • Classical Physics
  • Mechanics
  • Thermodynamics
