Newton's 2nd Law confusion: mass times acceleration is not a force?
Newton's second law, expressed as F=ma, is often misunderstood, leading to confusion about whether mass times acceleration is a force. The caution in physics literature emphasizes that while F and ma can have the same value, they represent different concepts; F is the net force acting on an object, while ma describes the object's response to that force. The discussion highlights that acceleration results from forces acting on a mass, and it is more accurate to express the law as a=F/m to clarify that acceleration is the outcome of applied forces. Additionally, fictional forces complicate this understanding, as they do not adhere to Newton's third law. Ultimately, the distinction between the mathematical equality of F and ma versus their conceptual differences is crucial for a proper grasp of Newtonian mechanics.
Peter7799
Grateful if someone could explain why, if Newton's 2nd law says F=ma, I've read warnings and cautions in several physics books that mass times acceleration is not a force. Is it because the equals sign does not mean equals as in 2+2=4, perhaps?
Can you give a specific quote or reference?
This from Sears & Zemansky's University Physics, 12th edition. Page 118
Here's another is of the same type and from the same book
I would take these examples as good, practical advice. The point is that acceleration is the result of a force acting on a massive object in an inertial reference frame. And, if we measure all those quantities in consistent units - SI units, for example - then we have an equality between those two vector quantities.
I don't think you want to get bogged down in the mathematical subtleties of ##\vec F = m \vec a##. And how you might arrange that formally in terms of vector spaces.
Likes ohwilleke, Lnewqban and weirdoguy
If you think ma is a force, than what force is it? What acts on a body with this force? Why? 2nd law just shows the connection between the geometry of a movement (acceleration) and the forces acting on a body. There are plenty of those type of relationships in physics.
Likes sophiecentaur
The resulting force.
I find this text really confusing. But perhaps the idea behind it is that one should better write Newton's second law as ##a = \frac{F_{res}}{m}## to stress that acceleration is the result of force, not the other way around. Or maybe people try to identify ##m\cdot a## as an independent force apart from the forces which add up to ##m\cdot a##.
Anyway, I wouldn't phrase it that way.
Likes ohwilleke and Lnewqban
Welcome, Peter!
Newton's 2nd law says that
acceleration = net force / mass
Don’t worry about those sentences, the book is just trying to teach you how to properly do free body diagrams, which should only include forces and moments acting on a mass.
The acceleration, if any, comes after all those forces and moments start acting on a body.
Likes Peter7799, ohwilleke and PeroK
haushofer said:
Or maybe people try to identify m⋅a as an independent force apart from the forces which add up to m⋅a.
As I understand OP, this is the case OP is talking about, i.e. asks why it's not the case.
A force (##\vec{F}##) is a rate of transfer of momentum from one body to another due to an interaction other than an exchange of mass. One usually avoids getting that technical an introductory chapter. Instead, we just talk about how hard one pushes or pulls on something.
By contrast, ##m\vec{a}## is the rate of change of momentum of a single point mass (or of a rigid and non-rotating body). We might sometimes generalize to non-rigid or multi-body systems with ##\vec{F} = d\vec{p}/dt##
Newton's second law says that the rate of change of the momentum of a body is equal to the net rate at which you transfer momentum to it. When you say it that way, it is a way of stating that momentum is conserved.
Likes jack action and berkeman
All,
Many thanks for taking the time to offer your explanations. Putting them all together has enabled to grasp the principal that you've all been driving at.
Kind regards,
Peter
Likes sophiecentaur, berkeman, weirdoguy and 1 other person
The force F in F=ma is the net force acting on a body; ma does not apply to each individual force.
Likes pines-demon and sophiecentaur
My understanding that the F-side of Newton's second law contain forces stemming from interactions. Things like pushing, friction, gravitational pull and so on. These are also governed by Newton's third law. The ma-side connects interactions to change in momentum of a body. Fictional forces do not obey Newton's third law, so if they are included, they should probably be on the ma-side of the equation. I would not call the resultant force a force either, since it is not based on an interaction. At least some care should be taken when the concept it is introduced first time. After basic understanding of Newton's laws, then maybe the laws can be interpreted more deeply.
Why don’t friction forces obey Newton’s 3rd law?
If you accept that force is a vector quantity, then the sum of two forces is also a force.
@Pikkugnome is talking about fictitious forces.
I have no idea what you mean here.
1) You can bring any term to either side of the equation.
2) The whole point of introducing fictional forces is to make the Fnet = ma (2nd Law) hold in non-inertial frames, when you include those fictional forces in Fnet, as if they were normal forces.
See, newton's second law is approved by evidences. Acceleration is the increase in velocity of the body as a result of application of force. Acceleration is not a force.
a = (v-u) /t
acceleration = (final velocity - initial velocity) /time
If we reorder F = ma, we get
F/m = a
And putting general acceleration formula into Newton second law of motion
F = ma
F = m x (v-u) /t
F = (mv - mu) /t
Hence, proved that acceleration is not a force and F = ma equation is absolutely right. Here is another proof
F = dp/dt is the generalized version of newton's second law
p = m x v
F = dp/dt
F = dmv/dt
F = m(dv/dt)
F = m (v/t) Velocity divided by time is acceleration
F = ma
Peter7799 said:
.... mass times acceleration is not a force....
L Drago said:
.... acceleration is not a force ....
Spot the difference.
So let me prove that mass time acceleration is a force.
According to generalized version of newton's second law,
F = dp/dt
We know that
P = m x v
F = dmv/dt
F = m (dv/dt)
F = m ( v/t)
We know that v/t = a
F = ma ( Hence proved)
F = dp/dt
We know that
P = m x v
F = dmv/dt
F = m (dv/dt)
F = m ( v/t)
So, why do you think Sears and Zemansky, in their textbook, caution against treating mass times acceleration as a force? That was the whole point of this thread.
But in Newton's book Philosophiae Naturalis Principia Mathematica, the second law must have been described with equational proof as Issac Newton, the greatest physicist ever wrote it and gave three laws of motion.
The second law is a law/postulate/axiom on which Newtonian mechanics rests. You can't prove it as such.
In any case, the question is more subtle and was discussed earler in the thread. It might be worthwhile thinking about why the authors wrote what they wrote.
I believe that Newton is right. Please prove that f is not equal to product of m and a. I don't mean to be rude. Just want proof..
This is what this thread was discussing. I gave my thoughts in post #5.
Then read the question and the already given replies properly, instead spamming the thread, while completely missing the point.
But kindly give mathematical equational proof to describe what you claim that force is not equal to the product of mass and acceleration.
Okay thanks I accept the suggestion
The fact that a force is mathematically equal to the product of mass times acceleration - i.e. have the same values - doesn't mean they are the same thing.
Going further with that equation, we get ##E = mc^2##. This is called more appropriately the mass-energy equivalence because the equation doesn't mean mass and energy are the same thing. And one could extrapolate that this is true because we based this on ##F=m\frac{dp}{dt}## which is also an equivalence and not an equality. (Outside the mathematical sense, that is.)
I was never saying they were thee same thing we were saying they are equal and e = mc² is Einstein's equation of special relativity and here we are talking about force not energy.
  • #31
After being asked to read the thread and try not to miss the point...
Continuing to miss the point...
  • #32
Yes you did:
F = dp/dt
We know that
P = m x v
F = dmv/dt
F = m (dv/dt)
F = m ( v/t)
All you did was prove they have the same value (being equal), not that they are the same thing:
https://en.wikipedia.org/wiki/Equality_(mathematics) said:
In mathematics, equality is a relationship between two quantities or expressions, stating that they have the same value, or represent the same mathematical object.
Now you changed the statement from "mass times acceleration is a force" to "mass times acceleration equals a force". Nobody ever said they weren't equal.
Again, nobody ever claimed that in this thread. What @PeroK said was that Newton stated that ##F=ma## based on his observations. We cannot prove it. The only reason we think it is true is that we cannot think of an experiment where this statement wouldn't be true, thus proving it to be wrong.
  • #33
Force, mass and acceleration are measurable physical quantities. If we measure these in consistent units, then there is a mathematical equality between the quantities ##\vec F_{net} = m\vec a##. Sears and Zermansky emphasise the difference between this mathematical equality and things being the same measurable quantity. As I said in post #5, this seems like good practical advice in terms of understanding physics.
Another good example is ##V = IR##. Voltage equals current times resistance. But, that's different from saying that current times resistance is a voltage.
Likes renormalize and jack action
  • #34
Most of the responses here are lacking explanations - mostly just arrogant gibberish. When a rocket (unpowered) slingshots off a planet by the pull of it's gravity, it leaves the vicinity of the planet with greater speed that when it approached. How did the rocket obtain higher speed if no force acted upon it?
  • Sad
  • Skeptical
Likes L Drago, berkeman, weirdoguy and 1 other person
  • #35
In the Newtonian model it obtains a higher speed due to the force of gravity.
This thread is not a dispute about whether ##\sum F = ma##. It is (if anything) about drawing a distinction between the numeric quanty ##ma## and the physical concept of a force.
It seems to me that you have imagined some sort of straw man here. Maybe you think that someone is claiming that ##\sum F \ne ma##. Or that gravity is not a force. It is hard to be sure since you have not quoted the point that you wish to rail against. Nor have you made a reasoned argument for an opposing point.
Likes L Drago and PeroK
  • #36
Because it's the sum of all the forces.
Law II tells us that the mass of a particle, times its acceleration, equals the sum of all the forces acting on that particle.
  • #37
Prove it. Because I see none.
  • #38
Yeah. You are right. If someone wants us to prove a point. He should mention it.
  • #39
StandardsGuy said:
... gravity ... no force acted ...
Weird
  • Haha
Likes L Drago and jack action
  • #40
This is weird. You first need to describe what do you think is right. Just as my perspective was chagen as now I understand that mass times acceleration is not the same as force, it is just an equivalence which is described by Newton's second law. A big thanks to @PeroK for changing my perspective. Now I realise what was describe in the book which cautioned against stating the product of mass and acceleration the same as force.
Likes DrClaude and PeroK
