inkliing
- 25
Sorry, but this will be a long post.
This isn't homework, I'm reviewing physics after many years of neglect.
Halliday & Resnick, 4th Ed., section on variable mass and rockets, refers the interested reader to an article, "Force, Momentum Change, and Motion," Martin S. Tiersten, Am. J. Phys., Jan. 1969. I'm trying to apply Tiersten's methodology (which seems to me to be more straightforward than other methods) to 2 problems.
The usual representations of Newton's 2nd law for open mass systems:
[tex]M\frac{d\vec{v}}{dt} = \sum\vec{F}_{ext.} + (\vec{u}-\vec{v})\frac{dM}{dt} = \sum\vec{F}_{ext.} + \vec{v}_{rel.}\dot{M}, (1)[/tex]
[tex]\frac{d}{dt}(M\vec{v}) = \sum\vec{F}_{ext.} + \vec{u}\frac{dM}{dt} = \sum\vec{F}_{ext.} + \vec{\phi}_{\text{net mom.in}}, (2)[/tex]
where M = system mass, [itex]\vec{v}[/itex] = system velocity, [itex]\vec{u}[/itex] = velocity of incoming/outgoing mass at time t.
Please note:
1. Tiersten helpfully points out: (let the sums be taken over all of the particles in the system at time t)
[tex]\vec{v} = \frac{\vec{p}}{M} = \frac{\sum m_i\vec{v}_i}{M}\mbox{. M not constant implies, in general, }\vec{v}\neq\vec{v}_{cm} = \frac{d}{dt}\vec{x}_{cm} = \frac{d}{dt}(\frac{\sum m_i\vec{x}_i}{M})[/tex]
[tex]\vec{a} = \dot{\vec{v}} = \frac{d}{dt}(\frac{\vec{p}}{M})\mbox{. In general, }\vec{a}\neq\frac{\sum m_i\vec{a}_i}{M} = \frac{\sum\vec{F}_{ext.}}{M}\mbox{ and }\vec{a}\neq\vec{a}_{cm} = \frac{d^2}{dt^2}\vec{x}_{cm}[/tex]
2. For rockets, [itex]\vec{v}_{rel.}\dot{M}[/itex] is usually called momentum thrust. (1) is Galilean invariant simply because [itex]\vec{u}-\vec{v}[/itex] is a relative velocity and therefore clearly invariant in any inertial frame (M, [itex]\dot{\vec{v}}, \sum\vec{F}_{ext.}[/itex] are clearly invar.).
3. (2) is frame dependent (clearly [itex]\dot{\vec{p}},\phi[/itex] are frame dependent), though [itex]\dot{\vec{p}} - \vec{\phi}[/itex] isn't.
The examples given in the article are explained well, but there are 2 from other sources which are confusing me.
Ex. 1. A force lifts a length L mass m uniform chain at constant speed, v, vertically from a pile. Let N = normal force, F = lifting force, x = length of chain already lifted at time t.
1. Let S = the system = the entire chain = closed. [itex]\sum F_{ext} = F+N-Mg = \dot{p} - \phi = \frac{d}{dt}((m/L)xv) - 0 = (m/L)v^2\Rightarrow F+N = (m/L)v^2+Mg = constant[/itex]. It seems clear that (a) system closed [itex]\Rightarrow\sum F_{ext} = \dot{p}[/itex] in all frames and therefore [itex]\dot{p}[/itex] is frame invariant and (b) system closed [itex]\Rightarrow\phi = 0[/itex] in all frames.
2. Now let S = just the pile = open system. [itex]N-(m/L)(L-x)g = \dot{p} - \phi = 0 - 0[/itex] gives, when combined with the above result, the expected [itex]F = (M/L)(v^2+xg)[/itex]. Here's where the confusion begins. [itex]\dot{p} = 0[/itex] because we are observing the system from the pile's restframe and therefore [itex]v_{pile} = 0 \ and \ \dot{v}_{pile} = 0. \ \phi = 0[/itex] because I intuitively know that the rising chain applies no thrust to the pile, i.e., [itex]\phi \ (= u\dot{M})[/itex], when combined with [itex]-v\dot{M}[/itex] (= 0), should give zero thrust. But this seems mathematically insatisfactory because mass leaves the pile at speed u = v, suggesting that [itex]\phi = u\dot{M}\neq0[/itex]. I suppose we could reason this away by observing that the mass doesn't actually leave the pile at any speed, rather it simply disappears, and therefore the speed of the disappearing mass will always be zero relative to the pile. But let us now keep the same open system = just the pile, but observe it from another inertial frame, say the restframe of the rising chain. Now [itex]\dot{p}[/itex] seems to be [itex]\neq0[/itex] since [itex]v_{pile}\neq0[/itex], i.e., [itex]\dot{p} = -v\dot{M}[/itex]. And if we remain consistent, insisting that the speed of the disappearing mass is zero relative to the pile in all inertial frames, then [itex]\phi[/itex] still = 0, giving N-(m/L)(L-x)g = [itex]-v\dot{M}[/itex], which is incorrect.
We can't have it both ways. Either the speed of the disappearing mass relative to the pile is zero in all frames ([itex]\Rightarrow\phi = 0[/itex] in all frames [itex]\Rightarrow\sum F_{ext} = N-(m/L)(L-x)g = \dot{p}\neq0[/itex] in all frames other than the pile's restframe) or the speed of the disappearing mass relative to the pile is not zero in all frames ([itex]\Rightarrow u_{\text{disappearing mass}}\neq0[/itex] in the pile's restframe [itex]\Rightarrow\phi\neq0[/itex] in the pile's restframe [itex]\Rightarrow\sum F_{ext} = N-(m/L)(L-x)g\neq0[/itex] in the pile's restframe). Either way implies [itex]\sum F_{ext}\neq0[/itex] in some inertial frame.
Ex. 2. Halliday & Resnick, 4th ed., ch.9, problem 55. "To keep a conveyor belt moving when it transports luggage requires a greater driving force than for an empty belt. What additional driving force is needed if the belt moves at a constant speed of 1.5 m/s and the rate at which luggage is placed on one end of the belt and removed at the other end is 20 kg/s? Assume that the luggage is dropped vertically onto the belt; persons removing luggage grab hold of it and bring it to rest relative to themselves before lifting it off the belt."
The intuitive and correct answer is [itex]2v\dot{M}[/itex] since if no mass ever left the belt, the driving force would = [itex]v\dot{M}[/itex]. Halliday & Resnick evidently agree, since the answer provided in the back of the book is 60N. But I can't see the exact steps in deriving this solution.
And forcing this example to conform to the constraints of [itex]\sum F_{ext} = \dot{p} - \phi[/itex] is giving me the same trouble as Ex. 1. I prefer to think of this problem as sand instead of luggage, since finer particles make it easier to define the system. Therefore assume sand falls vertically onto the belt, moves a certain distance at constant speed, then hits a vertical wall, which stops the sand while it's still on the conveyor belt. But the sand doesn't accumulate in a pile, rather it falls vertically through a hole.
1. Let S = a closed system = a fixed # of sand grains for a time interval [itex]\Delta t[/itex] during the belt's steady state operation. Assume the system boundaries extend a negligible hight above and below the sand on the belt. Therefore the force exerted by the belt-sand on the still-falling input sand, which accelerates the falling sand from 0 to v, and the reaction force of the falling sand on the belt-sand comprise an internal action/reaction force pair. Similarly for the force of friction between belt and belt-sand. Therefore the external forces on the system are the driving force which moves the belt (call it [itex]F_d[/itex]) and the stopping force of the vertical wall ([itex]F_s[/itex]). Assume the fixed # of sand grains comprise a small amount of still-falling sand, call this [itex]\Delta[/itex]m', + the sand on the belt, m, + a small amount of falling output sand, [itex]\Delta[/itex]m". At time t, [itex]\Delta[/itex]m' is still falling and therefore has no horizontal momentum, m+[itex]\Delta[/itex]m" is on the belt moving with speed v. At time t+[itex]\Delta[/itex]t, [itex]\Delta[/itex]m' has already fallen onto the belt, so that m+[itex]\Delta[/itex]m' is moving on the belt at speed v, and [itex]\Delta[/itex]m" has now fallen through the hole at the end and is falling vertically with no horizontal momentum. Steady state [itex]\Rightarrow\Delta[/itex]m'=[itex]\Delta[/itex]m"[itex]\Rightarrow p(t)=p(t+\Delta t)\Rightarrow\dot{p}=0[/itex]. System is closed [itex]\Rightarrow\sum F_{ext} = F_d - F_s = \dot{P} = 0.[/itex]
2. Now let S= sand on belt + negligible height above and below = open system with sand flowing in and out. [itex]\dot{M}=0 \ and \ \dot{v}=0\Rightarrow\dot{p}=0[/itex] in all frames. But [itex]\phi = \dot{m}'_{in}v_{x,in}-\dot{m}'_{out}v_{x,out}\neq0[/itex] in any frame other than the ground frame.
So I need some helpful suggestions on how to apply [itex]\sum F_{ext}=\dot{P}-\phi[/itex] consistently in every inertial frame for these 2 examples, and a well as something more than hand-waving to justify getting from [itex]\sum F_{ext}=\dot{P}-\phi \ to \ F_d=2v\dot{M}[/itex] in ex.2.
This is nonrelativistic, non-Lagrangian, simple Newtonian physics. Please do not overcomplicate anything.
Please note:
