Newton's 2nd Law: Why is Resistance Considered a Positive Force?
Resistance is typically considered a negative force because it opposes the direction of motion, which aligns with Newton's second law stating that the sum of forces equals mass times acceleration. In the discussed exercise, resistance was incorrectly labeled as a positive force, leading to confusion. The correct representation should reflect that the resistive force is negative, indicating its opposite direction to motion. Clarity in physics problems is essential, particularly in specifying both magnitude and direction of forces. Proper notation, such as using LaTeX for numbers, is also encouraged for better understanding.
Fakhro
An airboat with mass 3.50 3 102 kg, including the passenger,
has an engine that produces a net horizontal force of 7.70 3 102 N,
after accounting for forces of resistance (see Fig. 4.7). (a) Find the acceleration
of the airboat. (b) Starting from rest, how long does it take the
airboat to reach a speed of 12.0 m/s? (c) After reaching that speed, the
pilot turns off the engine and drifts to a stop over a distance of 50.0 m.
Find the resistance force, assuming it’s constant.
Newton's 2nd law of motion
regarding the last question.
I know that resistance is a negative force because it goes in the opposite direction to the movement of the boat. So whenever, I want to apply Newton's 2nd law of motion: the sum of forces = m a
I should write - F resit = m.a.
However, they have considered the resistance a positive force in this exercise. Why?
Are you talking about part (a) or part (c)? If it's part (a), Newton's second law says that the net force is equal to mass times acceleration, not just the resistive force. What is the net force in part (a)?
Please tell us who "they" are and exactly what "they" said. I agree that the resistive force is opposite to the motion.
Sir, when I say the last question I mean C.
the problem is not of who are. "they".
the problem lies in the exercise. In the end, the resistance force was listed as a positive force when Newton's second law was applied. the sum of forces = m a / F resit = m.a.
whereas it should be written as - F resit = m.a.
This exercise is from a physics book. They mean the authors.
As I already said, you are right in saying that the resistive is opposite to the motion. If you have a number for the resistive force, say 50 N, then a correctly phrased answer would be "the resistive force is 50 N in a direction opposite to the velocity." That says it all. If the textbook gives you just a positive number as the answer, then it is incorrect because force is a vector that has magntude and direction.
For future reference, please post numbers, especially powers of 10, sing LaTeX. If you have not used LaTeX before, click in the link "LaTeX Guide", lower left. Numbers such as 3.50 3 102 kg are hard to interpret. Thank you.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
