Newton's Law Homework Question
In summary: F=ma and John's force...F=mj. So Peter has a force of 3.0kgN on John and John has a force of 2.5kgN on Peter. Sarah's resultant acceleration is: 15.0m/s^2
anti_physical
Newton's Law Homework Question!
Question: Peter and John are playing a game of tug-of-war on a frictionless, icy surface. Peter weighs 539 N and John weighs 392 N. During the course of the game, John accelerates toward Peter at a rate of 3.0m/s^2.
a) What is the magnitude of the force that Peter exerts on John?
b) What is the magnitude of the force that John exerts on Peter?
c) What is the magnitude of Peter's acceleration toward John?
d) Sarah decides to john the game as well. Now Peter pulls on Sarah with a force of 45.0 N [E], and John pulls on her with a force of 25.0 N [N]. What is Sarah's resultant acceleration if she weighs 294 N?
--I just don't seem to understand what they're actually asking me to look for in parts a-c. What exactly does magnitude mean? Would I simply see the difference of their forces (by subtraction?)
--Also, because its tug-of-war, that would mean that we could assume one is pulling towards the W and the other the E, correct? Why would Peter accelerate TOWARD John then??
F=ma
Think in terms of Newton's 3rd Law: If A exerts a force on B, then B exerts a force on A of equal magnitude and opposite direction.
Hi anti_physical, welcome to PF.
I'm sure you're familiar with the everyday sense of the word magnitude, meaning the degree or extent of something, its amount, its greatness (or smallness). The magnitude of something could be a measure of the strength of its effect or perhaps of its proportions.
In physics, many quantities are vector quantities. This means that they have to be described using two numbers: a magnitude and a direction. Forces are an example of a vector quantity. They have both a magnitude (which describes how strong or weak the pulling is) and a direction (which describes in what direction the pulling is occurring). A force of three Newtons would be greater (in magnitude) than a force of two Newtons.
So, based on what I've said, I think you can see that an equivalent way of stating the question in part a would be, "with how much force (in Newtons) is Peter pulling on John?"
You are correct that because it is a tug of war, Peter and John are pulling in opposite directions. The reason why Peter is accelerating towards John is because John is *winning.* ;)
That being said, would I simply use subtraction to show that Peter has 147 N of magnitude of force on John??
I'm not sure how I'd complete the magnitude of force of John on Peter though. Negative value of force?
Sorry everyone! Physics proves to be quite difficult for me! Thanks so much though!
(1) No subtraction needed.
(2) Why would you subtract their weights? You need the force with which they pull on the rope, which hasn't much to do with their weights. (They pull horizontally; weight acts vertically.)
Hint: Use Newton's 2nd law to find the force.
Don't forget Newton's 1st law.
F=ma
A) with what force is john pulled by peter
B) with what force is peter pulled by john
C) What is peters acceleration towards john
Magnitude would imply that it's an average as a tug of war does not produce a constant acceleration as the two pull in different sequences. Just answer them as above...
The second question ... no sexual attraction definitely. But one of them is the standpoint so their acceleration is not measured relative to the ground but relative to one another. Because they both exert a force they both feel an acceleration.
I think I figured it out!
I changed their weight in N into kg (mass) and used their masses to find out their individual forces. Peter's force is 165 N and John's is 120 N.
For part c) the only thing I can think of is that Peter doesn't have an acceleration because he isn't moving. He will have a negative acceleration if anything, but I'm not quite sure how that would be calculated.
Both are moving because it is a frictionless icy surface. :P
Still in disagreement to things said above Peter is still winning :P
You are given John's acceleration. Don't assume both have the same acceleration. (But Newton's 1st law will tell you something about the forces.)
Imagine that you are pulling a car on ice. Both of you are moving but you are moving faster as you are the lighter one.
Related to Newton's Law Homework Question
What is Newton's first law?
Newton's first law, also known as the law of inertia, states that an object at rest will remain at rest and an object in motion will continue in motion at a constant velocity unless acted upon by an external force.
What is Newton's second law?
Newton's second law, also known as the law of acceleration, states that the acceleration of an object is directly proportional to the net force acting on it and inversely proportional to its mass.
What is Newton's third law?
Newton's third law, also known as the law of action and reaction, states that for every action, there is an equal and opposite reaction. In other words, when one object exerts a force on another object, the second object exerts a force of equal magnitude and opposite direction on the first object.
How do you calculate force using Newton's second law?
The formula for calculating force using Newton's second law is F=ma, where F is force in Newtons, m is mass in kilograms, and a is acceleration in meters per second squared.
What are some real-life applications of Newton's laws?
Newton's laws have many real-life applications, such as explaining the motion of objects on Earth and in space, designing and predicting the behavior of machines, understanding the forces involved in sports and other physical activities, and developing safety features in vehicles.
9K
