Newtons Law of Cooling applied to hot Neon and Hydrogen gas
In summary, both gases take about 53 seconds to cool to 120 Kelvin. For Neon, it takes about 198 seconds.
morrobay
1,479
1 mole of Hydrogen gas at 300 Kevin is contained in a thin walled copper container.
In container #2 there is 1 mole of Neon gas also at 300 Kevin.
The volume= 22.4 liters and surface area ,A = .476 m^2
The surroundings are at 100 deg Kelvin.
The specific heat of H2= 5 cal/mole (K) Specific heat for Neon = 3cal/mole (K)
The thermal conductivity (k) H2 = .0433 cal/sec For Neon = .0116 cal/sec
How many seconds for each gas to cool to 120 Kelvin ?
Since the heat transfer equation , Q/t = -kA (T2-T1)/L
is with T2 at a fixed temperatue and in the above problem T2 , the temp of the gases,
are changing. I am applying k to the solution to Newtons law of cooling .
T(t) = T surr. + (Tgas - Tsurr)e^-kt
120K (t) = 100K + 200K e^-kt
So 20K/200K= e^-kt
2.3 = kt
For Hydrogen t = 53 seconds ,
For Neon t = 198 seconds
note I originally put this problem in the physics section but it should qualify for chemical
thermodynamics. Hopefully the chemists here can be of more help !
Check your units: if [itex]kt[/itex] is dimensionless (which it must be to take the exponential), [itex]k[/itex] must have units of s-1. And why do your thermal conductivity values have units of power?
The units are in power since I converted Watts to calories.
This k value is for: Q/t = -kA (T2-T1)/L
So there is a unit problem in appling it in the Newtons Law of Cooling solution.
The question now is are there tables of k values that can be used with Newtons solution,
or can it only be obtained by taking temperatures at t0 ,t1,t2 and solving for k. ?
Or since the thermal conductivity (k) above in Q/t = -kA (T2-T1)/L in units
(cal/sec)/meter^2)C deg/meter
And (k) in units 1/sec here: T(t) = Tsurr + (T initial - Tsurr) e^-kt
Are both related to heat transfer for a specific material can there be a conversion ?
But thermal conductivity should have units of power length-1 degree-1...
Agree : Watts/(Kelvin ) (meter) multiplied by (delta T) ( Area m^2) divided by Length (m)
The units in post #3 were copied from a text, it is a confusing copy.
So with 1 watt = .238 cal/sec.
Thermal conductivity should be: cal/sec / kelvin * meter ( T2-T1) ( m^2) / m
Thats as in : Q/t = -kA (T2-T1)/L
With k itself in power/ degree * length
In Newtons law of Cooling: dT/dt = -k (T initial- T surr.)
With this k in 1/sec
And both of these constants are related to heat transfer in a specific material . Is There a conversion factor from the thermal conductivity k
to the law of cooling k ?
Not without more information, such as the thickness of the copper, or the convection coefficient on both sides. I don't see how the problem is solvable from the information given in post #1.
You cannot really solve this kind of problem just with Newton's law of cooling.
Even for a solid body, with no convection, it is a little more difficult than that.
The rate of heat transfer to the medium depends on the temperature difference between the surface of the material (your gas) and the temperature of the medium. But the evolution of the surface temperature depends on how fast can heat be transported from the inner volume to the surface.
You can imagine some extreme cases to see the point.
If the thermal conductivity is very high, then the temperature in the volume of the object is almost uniform and the whole material cools down as a whole. In this case you can find the solution just by using Newton's law of cooling. It probably works reasonably well for metals.
The other extreme is a very good (ideal) insulator. In this case the outer layer cools down to outside temperature but there is very little heat being transported from the inside to compensate for this. The inner volume stays at the same (initial temperature).
In real cases you are somewhere in between. There is a temperature gradient through the material. The question "how long it takes to cool down" is not even well defined.
FAQ: Newtons Law of Cooling applied to hot Neon and Hydrogen gas
1. What is Newton's Law of Cooling?
Newton's Law of Cooling is a mathematical equation that describes the rate at which an object cools down when placed in a different temperature environment. It states that the rate of change of temperature of an object is directly proportional to the difference between its initial temperature and the temperature of its surroundings.
2. How is Newton's Law of Cooling applied to hot Neon and Hydrogen gas?
When hot Neon and Hydrogen gas are placed in a cooler environment, they will both cool down according to Newton's Law of Cooling. The rate of cooling will be determined by the difference between the initial temperature of the gas and the temperature of the surroundings.
3. What factors can affect the rate of cooling for hot Neon and Hydrogen gas?
The rate of cooling for hot Neon and Hydrogen gas can be affected by several factors, including the initial temperature of the gas, the temperature of the surroundings, the surface area and volume of the gas, and the thermal conductivity of the container holding the gas.
4. How can Newton's Law of Cooling be used in practical applications?
Newton's Law of Cooling can be used in various practical applications, such as in refrigeration systems, heating and cooling of buildings, and in the study of thermal properties of materials. It is also used in weather forecasting and in the study of climate change.
5. Are there any limitations to Newton's Law of Cooling?
While Newton's Law of Cooling provides a good approximation for the cooling of hot Neon and Hydrogen gas, it does have some limitations. It assumes that the rate of cooling is constant, which may not always be the case. It also does not consider other factors, such as radiation, that can affect the cooling process.
