fayled
- 177
Suppose we have a cylinder of radius R, in an environment with temperature Tenv, and heat is generated in the wire at a rate P per unit volume (for example due to a current - the exact nature is irrelevant). The heat flux from the surface of the wire is A(T(R)-Tenv) for constant A (Newton's law of cooling). Find the temperature T(r).
Thermal diffusion equation,
∂T/∂t=(κ/C)∇2T+H/C
where κ is the thermal conductivity of the medium, C the heat capacity per unit volume of the medium, and H the rate of production of heat per unit volume in the medium.
In the steady state
κ∇2T+H=0
I'm assuming we want the steady state solution - however, if we had say a cup of tea and we had Newton cooling, the temperature would decay exponentially to Tenv, so the steady state would just be Tenv - is it the fact that we have some heat production P that allows a non trivial steady state?[/B]
Anyway, for some reason I believe I am supposed to convert the heat flux into a heat gained per unit volume, which is done by
-A(T(R)-Tenv)*(2πRl/πR2l)=-2A(T(R)-Tenv)/R
If correct, why am I allowed to do this - how do I know it is lost uniformly throughout the cylinder?
Then
H=P-2A(T(R)-Tenv)/R
Using the laplacian in cylindrical polars (no z or angular dependence)
(κ/r)d/dr(rdT/dr)=-H
T=-(Hr2/4κ)+Alnr+B
We need A=0 for T to be finite at r=0, and we need T(R) at r=R so B=T(R)+(HR2/4κ).
Then
T(r)=T(R)+(H/4κ)(R2-r2)
with
H=P-2A(T(R)-Tenv)/R.
However I don't really like leaving T(R) in the answer - how am I supposed to find out what this is?
Thanks for any help with the bold bits :)
