miniradman
- 196
The temperature of an object has been lying at rest and cooling for sometime had been found to be 31oC. An hour later, the same object was found to be 30oC. The room was also What was the initial temperature of the object, assume Newton's law of cooling applies.
[itex]\frac{dT}{dt}[/itex] = k (T - Ts) where:
Ts = ambient temperature
T = the temperature at anytime
k = constant of proportionality
Ok, normally when I do a Newtons law of cooling question, I start off with the inital temperature followed by a temperature at an "X" time. And then I would convert the formula into it's exponential form i.e. y = Aekt+c. then I would use the initial temperature (or the temperature when t=) to cancel out one of the variables. However, I'm trying to find the inital temperature, so this method won't work for me anylonger and I'm not sure how to proceede
Thanks guys/gals, any help will be greatly appreciated
