Newtons law of gravity problem
In summary, two identical rocks of mass 2 kg drifting through space at a distance of 30 cm from each other will experience a gravitational force of 2.96 x 10-9 N. This can be calculated using the formula F = G (m1m2/r2), where G is the gravitational constant, m1 and m2 are the masses of the rocks, and r is the distance between them. The incorrect answer given in the conversation was F = 2.96 x 103 N, but the correct magnitude is F = 2.96 x 10-9 N.
BrainMan
279
Two identical rocks of mass 2 kg drift through space far from any planet or star. If they pass one another at a separation of 30 cm, what is the magnitude of the gravitational force of one rock on the other at this instant.
F = G (m1m2/r2)
(4/.32)(6.673 x 10-11) = F
(4/.09)(6.673 x 10-11 = F
44.444444444444(6.673 x 10-11 = F
F = 3.804 x 10-8 N
the actual answer is F = 2.96 x 103 N
F = G (m1m2/r2)
F = 3.804 x 10-8 N
The "actual answer" is not correct, but it is the order of magnitude that is wrong not the mantissa of the number. Perhaps you misquoted the power of ten?
Regarding your solution attempt, your formula is fine but your math is not right. Recheck your calculation.
Likes 1 person
OK I see my mistake and the answer I put was a typo it is actually 2.96 x 10-9 N
Related to Newtons law of gravity problem
1. What is Newton's law of gravity?
Newton's law of gravity is a fundamental law of physics that describes the force of gravitational attraction between two objects. It states that the force of gravity between two objects is directly proportional to the product of their masses and inversely proportional to the square of the distance between them.
2. How does Newton's law of gravity apply to real-life situations?
Newton's law of gravity applies to all objects in the universe, from the motion of planets and galaxies to the fall of an apple from a tree. It is also used in engineering and space exploration to calculate the trajectories of objects in motion.
3. What is the equation for Newton's law of gravity?
The equation for Newton's law of gravity is F = G * (m1 * m2) / r2, where F is the force of gravity, G is the universal gravitational constant, m1 and m2 are the masses of the two objects, and r is the distance between them.
4. How does the distance between two objects affect the force of gravity?
According to Newton's law of gravity, the force of gravity decreases as the distance between two objects increases. This means that the farther apart two objects are, the weaker the force of gravity between them.
5. What is the difference between Newton's law of gravity and Einstein's theory of general relativity?
Newton's law of gravity is a simplified version of gravity that works well for most everyday situations. However, Einstein's theory of general relativity is a more accurate and comprehensive theory that explains gravity as the curvature of spacetime caused by the presence of mass and energy.
