Newton's Law of Universal Gravitation
The discussion revolves around calculating the acceleration of a satellite in orbit using two formulas derived from Newton's Law of Universal Gravitation. The first formula, a=GMm/r^2, was incorrectly applied, leading to a significant discrepancy in results compared to the second formula, a=4pi^2r/T^2. Participants suggest using the correct form a=Gm1/r^2, where m1 is the mass of the planet, to obtain accurate results. The calculated acceleration for Venus using the corrected formula yielded a value of 2.784*10^-8, which aligns more closely with expected outcomes. This highlights the importance of using the appropriate equations in gravitational calculations.
rvnt
I am doing a lab-"Kepler's Laws and Newton's Law of Universal Gravitation". There is an image representing various positions, at equal intervals, of a satelitte in an elliptical orbit around the earth. A list of planets and their radi and periods are given. I have calculated acceleration using two formulas a=GMm/r^2 and a=4pi^2r/T^2
Question states: "Calculate acceleration using the two equations and compare the results. Do your results confirm Newton's law of universal gravitation?"
F=Gm1m2/r^2
Ex. of results: accleration obtained for Venus using 1st equation= 5.5407*10^24 and using 2nd equation=0.0113286
I was expecting them to be the same...please help
F=Gm1m2/r^2
a=GMm/r^2 is wrong
go back to the general equation
F=Gm1m2/r^2
m1=mass of Venus
m2=mass of satellite
F=m2a=Gm1m2/r^2
a=Gm1/r^2
compare to the one you originally had (a=GMm/r^2)
But mass of the satellite isn't given..?
Wait...so as you said to use a=Gm1/r^2...for venus I got a=(6.67*10^-11)(4.8690*10^24)/(1.08*10^11)^2= 2.784*10^-8
  • · Replies 42 ·
