Newtons Laws, Finding tension in the tow cable and foce
In summary, a rocket towing a container of trash is experiencing a force, F, that causes it to accelerate at 4.50 m/s2. The rocket has a mass of 3.00 × 103 kg and the container has a mass of 1.00 × 103 kg. Using the equation F=ma, the force is calculated to be 1.80x10^4 N. The tension in the tow cable is found using the equation Ft=mb*a, resulting in a value of 4.50x10^3 N. It is important to note that the concept of normal force does not apply in this scenario.
mjm3
Just started tension problems and having some trouble figuring out how to approach the problem. Thanks for any help in advance.
Consider a rocket that is taking off and towing a large container of trash. The
rocket’s engines exert a force, F, that causes the rocket and container to accelerate at
4.50 m/s2. The rocket has a mass of 3.00 × 103 kg, and the container has a mass of
1.00 × 103 kg. Find the tension in the tow cable and the force, F.
Start with free body diagram and show us what you get.
mass a of the rocket. FN upward is the F(RA), downward we have m(ag) and also m(bg)?
mass b of container. Upward would be F(t) and FN would be F(RB)? downward m(bg).
I have the most trouble the free body diagrams.
Work. Part 1, A= F / ma+mb. F=A(ma+mb) = 1.80x10^4 N
Part 2, Ft=mb * a = 4.50x10^3 N
What is FN? :confused:
Seems good. :smile:
Sorry I was meaning to write it as the Normal Force, NF better?
I was afraid so...there is no normal force here! Normal forces come in play when there is a body in contact with another. See: http://en.wikipedia.org/wiki/Normal_force
For normal force it is general practice to write Fn or just N.
Thanks for the help. Just clarifying Fn made this system much easier to understand.
Related to Newtons Laws, Finding tension in the tow cable and foce
What are Newton's Laws of Motion?
Newton's Laws of Motion are three fundamental laws that describe the behavior of objects in motion. The first law states that an object will remain at rest or in motion at a constant velocity unless acted upon by an external force. The second law states that the force acting on an object is equal to its mass multiplied by its acceleration. The third law states that for every action, there is an equal and opposite reaction.
How do I find the tension in a tow cable?
The tension in a tow cable can be found by using Newton's Second Law. First, determine the mass of the object being towed and the acceleration it is experiencing. Then, use the formula T = ma, where T is the tension, m is the mass, and a is the acceleration. This will give you the tension in the tow cable.
What is force?
Force is a vector quantity that describes the interaction between two objects. It can be defined as a push or a pull that causes an object to accelerate. Force is measured in Newtons (N) and is calculated by multiplying mass by acceleration (F=ma).
How do Newton's Laws apply to everyday life?
Newtons's Laws of Motion apply to everyday life in many ways. For example, the first law explains why a book stays on a table until someone picks it up. The second law explains how a car accelerates when the gas pedal is pressed. The third law explains why a person feels a force when they hit a wall while running.
What is the relationship between force and acceleration?
According to Newton's Second Law, the relationship between force and acceleration is direct. This means that if the force acting on an object increases, the acceleration of the object will also increase, assuming the mass remains constant. Similarly, if the force decreases, the acceleration will also decrease.
