Newton's method to approximate critical point
In summary: But I will show you what I have tried so far. I made the partial derivatives of ##x## and ##y## as the new functions I need to evaluate using Newton's method. I reason that by getting the roots for these functions, I would be getting the value for the critical point.So for ##f_x##, $$z-z_0=f_x(x-x_0)$$By setting ##z=0##, $$x-x_0=\frac{-z_0}{f_x}$$Hence, $$x_{k-1}=x_{k}-\frac{z_0}{f_x}$$
toforfiltum
341
Let ##F(x,y)=4sin(xy)+x^3+y^3## Use Newton's method to approximate the critical point that lies near ##(x,y)=(-1,-1)##
I have a problem here because the derivative is not a square matrix. Hence, I can't find the inverse needed for the form $$x_{k}=x_{k-1}-[Df(x_{k-1})]^{-1}f(x_{k-1})$$
In this case, the derivative is zero, not the function, so I think the form above must be modified?
If derivative is zero, I get a form which doesn't make sense, which is ##z-f(x_o,y_o)=0##
Any hints?
You can use symmetry to reduce the problem to a one-dimensional problem.
The more textbook-like solution: calculate the first and second derivatives, then find the simulateous minimum of the first derivatives.
You could take it in turns to move in directions parallel to the x and y axes.
step 1 take a Newton step parallel to the y-axis towards the point near (-1,-1) on the line ##x=x_0=-1## where ##F_y(x_0,y)=0##. Label the landing point of that step ##(x_{1},y_{1})##
step 2 take a Newton step parallel to the x-axis towards the nearby point on the line ##y=y_{1}## where ##F_x(x,y_1)=0##. Label the landing point of that step ##(x_{2},y_{2})##
step 3 take a Newton step parallel to the y axis...
Any hints?
You CAN use Newton's method to solve the two equations ##f_x(x,y) = 0## and ##f_y(x,y) = 0##. You end up with the problem of inverting a 2x2 matrix at each step. See, examples in
https://www.math.ohiou.edu/courses/math3600/lecture13.pdf or
http://www.seas.ucla.edu/~vandenbe/103/lectures/Newton.pdf .
Just Google "Newton's method for system of equations".
But I just don't get it. Newton's method is used to get the root of an equation, whereas this is to get a critical point where the derivative is zero. Can the above form apply here?
Yes, it applies to the univariate problem of finding the root of the derivative.
However, in this case you have TWO equations in the TWO unknowns x and y, because you need to set TWO partial derivatives to zero in order to find the stationary point. So, you need to use the multivariate version of Newton's method that I gave you links for in my previous response. Have you read them, or parts of them at least?
Yes I've read them but I still have no idea on how the links you gave me can be applied to this problem. Sorry.
Is this a correct approach?
NO. As I stated very explicitly in post #4, and stated again in post #6, you have two equations ##F_x(x,y) = 0## and ##F_y(x,y) = 0##. Here, ##F_x = \partial F/\partial x## and ##F_y = \partial F/ \partial y##. The question is asking you for stationary (or critical) points of ##F##, and those are the points where both partial derivatives vanish.
So, to repeat: you have two nonlinear equations in two unknowns and cannot, therefore, just use the simple 1-variable version of Newton's method; you need the multivariate version as in the links.
Ah, I think I've got it. Here are my first steps:
Let ##g(x,y)=(4y \cos(xy)+3x^2, 4x\cos(xy)+3y^2)##. The 2 functions there are the partial derivatives ##F_x## and ##F_y## respectively. By taking derivative of the function, I can get an invertible 2x2 matrix. And from here I can proceed to use Newton's method, where setting ##g(x_0)+Dg(x_0)(x-x_0)=0## makes sense.
I'm quite sure I'm right this time.:smile:
I think technically it is not necessary. You want to find the point where both partial derivatives are zero - you can find the point where their product is zero, which leads to the classical problem of finding a root of a R^2 -> R function.
Related to Newton's method to approximate critical point
1. What is Newton's method to approximate critical point?
Newton's method is an iterative algorithm used to find the roots of a differentiable function. In the context of critical points, it can be used to approximate the values of x where the derivative of a function is equal to 0.
2. How does Newton's method work?
Newton's method involves choosing an initial guess for the critical point, and then repeatedly using the formula xn+1 = xn - f(xn)/f'(xn) to update the guess, where f(x) is the function and f'(x) is its derivative. This process is repeated until the updated guess is close enough to the actual critical point.
3. What are the advantages of using Newton's method?
Newton's method is a fast and efficient way to approximate critical points, as it typically converges to the correct value in a small number of iterations. It also allows for more accurate approximations compared to other methods, such as the bisection method.
4. What are the limitations of Newton's method?
Newtons's method may not always converge to the correct critical point, especially when the initial guess is far from the actual value. It also requires the function to be differentiable, which may not always be the case for all functions.
5. How is Newton's method used in real-world applications?
Newton's method is commonly used in optimization problems, such as finding the maximum or minimum values of a function. It is also used in engineering and physics to find solutions to complex equations and systems of equations.
  • Calculus
