Newton's Second Law and Rotation
In summary, the disk has angular acceleration while the block has linear acceleration. The disk has no linear acceleration because the axle is fixed, so the sum of the forces acting on it is zero. The tension in the string causes a torque on the disk, giving it the same tangential acceleration as the hanging mass. The force on the suspension holding the disk is somewhere between the weight of the block and the weight of the block plus the weight of the disk, depending on whether the string is cut or the disk is locked. The tension in the string is equal to the force on the suspension minus the weight of the block.
whoareyou
162
A 0.70-kg disk with a rotational inertia given by MR^2/2 is free to rotate on a fixed horizontal
axis suspended from the ceiling. A string is wrapped around the disk and a 2.0-kg mass hangs
from the free end. If the string does not slip, then as the mass falls and the cylinder rotates,
the suspension holding the cylinder pulls up on the cylinder with a force of:
A. 6.9N
B. 9.8N
C. 16N
D. 26N
E. 29N
Newton's second law for rotating bodies
I was able to get the acceleration of the disk + the mass by myself following the solution below. It's probably pretty obvious but I just can't seem to figure out how he got T = mg + M(g-at), specifically the M(g-at) part assuming that the suspension holding the cylinder pulls up on the cylinder with a force equal to the sum of the weights of the pulley and the block.
This is the solution I am trying to make sense of:
The suspension holding the cylinder pulls up on the cylinder with a force of
T = mg + M(g-at), where m - disk, M - 2kg mass, at - the acceleration of a 2.0-kg mass. At the same time that is the tangential acceleration of the disk. Let's find it.
J dω/dt = M(g-at) * R,
mR²/2 * 1/R dV/dt = M(g-at) * R, where at dV/dt = at.
m at/2 = M(g-at)
at = 2g/(m/M+2) = 2*9.8/(0.7/2 + 2) = 8.34 m/s²
T = mg + M(g-at) = 0.7*9.8 + 2*(9.8-8.34) = 6.86 + 2*1.46 = 9.8 N
A. 6.9N
B. 9.8N
C. 16N
D. 26N
E. 29N
Draw free body diagrams. The forces acting on the axle must sum to 0 since the axle is not accelerating. The forces acting on the falling mass M must add to Mat.
The forces acting on the axle are the tension in the axle support, Tx (upward), mg (downward) and the tension in the string (downward). The forces acting on the falling mass are: Mg (downward) and the tension in the string, Ts(upward).
So:
Tx - mg - Ts = 0
and
Mg - Ts = Mat
These reduce to:
Tx = mg + Mg - Mat
AM
By axle, do you mean the disk, or the thing that's supporting the disk+mass to the ceiling? Also (assuming by axle you mean the disk) how come it isn't accelerating? Isn't there a net torque caused by the tension in the string causing angular acceleration in the disk?
You state that the disk is free to rotate about a fixed axis suspended from the ceiling. I appeared to me that this axis passed through the centre of the disk (radius R). So it appears to me that the disk rotates on a fixed horizontal axle through its centre of mass. How else would it rotate?
The centre of mass of the disk does not accelerate because the axle is fixed. What you want to determine is the upward force on that axle.
AM
Andrew means it doesn't have linear acceleration (it does have angular acceleration)
Your assumption is incorrect or perhaps you need to think about the "weight of the block M". The mass M is accelerating downwards so the suspension isn't carrying it's full weight (eg it's not Mg).
Consider..
If the disc was locked so that mass M was just hanging there then the force on mass M would be Mg and the force on the suspension would be mg + Mg.
If mass M was somehow in total free fall (eg the string had been cut) then then force due to mass M would be zero. In that case the force on the suspension would be just mg + 0
So in your problem the force on the suspension is going to be somewhere between these two.
What is the tension in the string?
OK, so to summarize:
- the disk has angular acceleration and the block has linear acceleration
- the disk has no linear acceleration, so by Newton's Second Law (not for rotation), it has no (linear) acceleration so the sum of the forces = 0
- the tension in the string causes a torque on the disk so it has the same tangential acceleration as the hanging mass
Hmm, I think those are the key ideas to take away. Am I missing something. I think in the end, once I realized that why the disk is not accelerating, the whole solution became much more clear.
Related to Newton's Second Law and Rotation
What is Newton's Second Law and how does it apply to rotation?
Newton's Second Law states that the net force acting on an object is equal to the mass of the object multiplied by its acceleration. When it comes to rotation, this law applies by stating that the net torque acting on an object is equal to the moment of inertia of the object multiplied by its angular acceleration.
What is the difference between linear and angular acceleration?
Linear acceleration refers to the rate of change of an object's velocity in a straight line, while angular acceleration refers to the rate of change of an object's angular velocity around a fixed axis. Linear acceleration is measured in meters per second squared, while angular acceleration is measured in radians per second squared.
How does torque relate to rotational motion?
Torque is the rotational equivalent of force. It is a measure of the twisting force that causes an object to rotate around an axis. The greater the torque, the greater the object's angular acceleration and the faster it will rotate.
What is moment of inertia and how does it affect rotation?
Moment of inertia is a measure of an object's resistance to changes in its rotational motion. It is affected by an object's mass and distribution of mass relative to its axis of rotation. Objects with a larger moment of inertia will require more torque to achieve the same angular acceleration as objects with a smaller moment of inertia.
Can Newton's Second Law and rotation be applied to non-rigid bodies?
Yes, Newton's Second Law and rotation can be applied to non-rigid bodies as long as the object's mass and distribution of mass are known. In these cases, the object's moment of inertia may vary as the object rotates, and the equations for torque and angular acceleration may be more complex.
