akerkarprashant
- 74
- 10
- TL;DR Summary
- F=m*a equation
Why F=m*a i.e product or multiplication and not F=m+a? i.e addition or summation?
Because Newton's first law says that ##a = 0##, when ##F = 0##.akerkarprashant said:Summary:: F=m*a equation
Why F=m*a i.e product and not F=m+a? i.e addition?
Because it predicts that a 9.81 kg mass would float in midair if released at a point near the Earth's surface where the acceleration of gravity is -9.81 m/s2. Don't try this at home.akerkarprashant said:Summary:: F=m*a equation
You can mutiply pretty much any two quantities. If they are both vectors you need to use the dot product or the cross product.akerkarprashant said:Thanks.
So we can add Scalar + Scalar, Vector + Vector but not Scalar + Vector quantity?
While Scalar * Scalar, Vector * Vector and Scalar * Vector quantity is possible?
Indeed. What is one second more than one kilogram? It doesn't make sense. But one second times one meter per second gives you one meter, the distance traveled in the time.PeroK said:You can only add quantities that have the same units. E.g. if both have units of mass; or, if both have units of mass times length divided by time squared. Etc.
Is this the infinite monkey theorem applied to theoretical physics?akerkarprashant said:[...]
F=m^a
F=m/a
It reminds me of the old Sidney Harris cartoon ##\dots##jbriggs444 said:Is this the infinite monkey theorem applied to theoretical physics?
Because force is proportional to mass: If you have twice as much mass, you have to push twice as hard to accelerate it at the same rate.akerkarprashant said:Why F=m*a
With that, we will close this thread. Thank you everybody for trying to help the OP.vanhees71 said:The answer is that Newton was after figuring out how nature works and not after writing down mathematical expressions which don't make any sense!
Newton's second law of motion states that the acceleration of an object is directly proportional to the net force acting on it and inversely proportional to its mass. In other words, the greater the force applied to an object, the greater its acceleration will be, and the more massive an object is, the less it will accelerate.
The formula F=m*a represents the mathematical relationship between force, mass, and acceleration as described by Newton's second law. The letter "F" stands for force, "m" stands for mass, and "a" stands for acceleration. By multiplying the mass of an object by its acceleration, we get the force required to produce that acceleration.
This is because force and acceleration are not simply additive quantities. In other words, adding mass and acceleration together does not give us a meaningful result. Instead, we multiply mass and acceleration to get force, as this reflects the true relationship between these variables as described by Newton's second law.
Yes, the formula can be rearranged to solve for any of the three variables. For example, if we divide both sides of the equation by mass, we get a=F/m, which allows us to solve for acceleration. Similarly, if we divide both sides by acceleration, we get m=F/a, which allows us to solve for mass.
Newton's second law can be applied to a wide range of real-world situations, from the motion of objects on Earth to the movement of celestial bodies in space. It is used in fields such as engineering, physics, and biomechanics to understand and predict the behavior of objects under the influence of forces. It is also the basis for many important technologies, such as rockets, airplanes, and cars.
