Newton's Second law: Tension on Cable
In summary, the homework statement asks for the tension in a cable that is accelerating a watermelon by 2.0 m/s2. The attempt at a solution states that Fcable = m.a, which is incorrect because Newton's second law states Fnet = ma. The solution provides an expression for the net force as the sum of all the forces acting on the watermelon, and solves for Fcable to be 59N.
aatari
73
Hey guys is my solution correct for the question below?
1. Homework Statement
Consider a 5.0 kg watermelon that is being accelerated at 2.0 m/s2 [up] by a cable. Find the tension in the cable.
Fcable = m.a
Fcable = m.a
= 5.0 kg(2.0)
= 10N
Your solution is incorrect. Newton's second law says Fnet = ma. Fnet is the sum of all the forces acting on the watermelon, not just the force from the cable.
Ok I am confused now. I thought Fnet = m.a
Or in this situation should it be Fcable +Fgravity
Yes, it should be as you say. Can you finish the problem now?
Fcable = 10 N
Fgravity = -49N
Fcable + Fgravity = 10N - 49N
= 39 N [down]
Is this correst?
How do you figure Fcable = 10 N? It seems that you multiplied the acceleration by the mass and called that Fcable. We agreed that mass times acceleration is the net force. Write an expression for the net force as the sum of all the forces, set it equal to mass times acceleration and solve for Fcable.
I think I get it now.
So Fnet = Fcable + Fgravity
10N = Fcable - 49N
10N + 49N = Fcable
Fcable = 59N
Yes, you got it. :smile:
Likes aatari
Thanks for your help.
Related to Newton's Second law: Tension on Cable
What is Newton's Second Law?
Newton's Second Law states that the force acting on an object is equal to the mass of the object multiplied by its acceleration. It can be written as F=ma, where F represents force, m represents mass, and a represents acceleration.
How does Newton's Second Law apply to tension on a cable?
In the case of tension on a cable, the force acting on the object is the tension force, which is the force that the cable exerts on the object. This force can be calculated using Newton's Second Law by multiplying the mass of the object by its acceleration.
What factors affect the tension on a cable?
The tension on a cable is affected by the mass of the object being pulled, the acceleration of the object, and the angle at which the cable is pulling on the object. The greater the mass or acceleration, the greater the tension on the cable. Additionally, a larger angle of pull will result in a greater tension on the cable.
How is tension on a cable related to the weight of an object?
The tension on a cable can be thought of as the force needed to lift an object against the force of gravity. This means that the tension on the cable is directly related to the weight of the object. The heavier the object, the greater the tension on the cable will need to be to lift it.
What is the difference between tension and force?
Tension and force are often used interchangeably, but they have slightly different meanings. Force is a general term used to describe any push or pull on an object, while tension specifically refers to the force exerted by a stretched object, such as a cable or rope. In the case of Newton's Second Law and tension on a cable, the force is the tension force.
