Newton's Third Law Problem [Checking Solution]
In summary, two stationary hockey players, A and B, with masses of 85kg and 110kg respectively, shove each other on the ice. As a result, player A ends up with a velocity of 1.5m/s [W]. To find the final velocity of player B, we can use the conservation of linear momentum formula, which states that mass multiplied by velocity is constant. By substituting the formula for player B into the formula for player A and solving for the final velocity of player B, we get a result of 1.2m/s [E]. This calculation is based on the assumption that the acceleration is constant over the entire collision.
oMovements
28
Two hockey players are standing stationary on the ice facing one another. Player A has a mass of 85kg and Player B is 110kg. They shove each other and player A ends up with a velocity of 1.5m/s [W]. Find the final velocity of Player B.
Solution
Fa=Maaa
Fa=(85)(1.5-0/t)
Fb=Mbab
Fb=(110)(1.5-0/t)
Sub Fb into Fa
(110)(Vfb-0/t) = (85)(1.5-0/t)
110Vfb=127.5
Vfb=1.2 m/s [E]
Your answer is correct but what you are really doing is a calculation due to conservation of linear momentum
linear momentum = mass x velocity.
so 110*Vfb = 85*1.5
oMovements said:
Fb=Mbab
Fb=(110)(1.5-0/t)
I think you meant Vfb rather than 1.5 here.
Sub Fb into Fa
110Vfb=127.5
Vfb=1.2 m/s [E]
What you have written is correct in the result, but you should not, and need not, assume that the acceleration is constant over the entire collision. So it would be more correct to say that:
Fa on b = mbdvb/dt = -Fb on a = -madva/dt
Since [itex]v_a = \int_0^t \frac{dv_a}{dt} dt[/itex] by integrating both sides of the above equation you see that:
mbvb = -mava
which is just conservation of momentum, as rock.freak has pointed out.
AM
FAQ: Newton's Third Law Problem [Checking Solution]
1. What is Newton's Third Law Problem?
Newton's Third Law Problem, also known as the Action-Reaction Problem, states that for every action, there is an equal and opposite reaction. This means that whenever an object exerts a force on another object, the second object will exert an equal and opposite force back on the first object.
2. How do you check the solution to a Newton's Third Law Problem?
To check the solution to a Newton's Third Law Problem, you can follow these steps:
  • Identify the objects involved and the forces acting on each object.
  • Draw a free body diagram for each object, showing all the forces acting on it.
  • Apply Newton's Third Law by writing out the action and reaction forces for each object.
  • Ensure that the magnitude and direction of the action and reaction forces are equal and opposite.
  • Check for any errors or inconsistencies in your solution.
  • If everything checks out, your solution is correct.
3. What happens if the action and reaction forces are not equal and opposite?
If the action and reaction forces are not equal and opposite, then the objects involved will experience an unbalanced force. This can result in acceleration or a change in motion for the objects.
4. Are there any real-life examples of Newton's Third Law in action?
Yes, there are many real-life examples of Newton's Third Law. Some common examples include walking (your foot pushes against the ground, and the ground pushes back with an equal and opposite force, propelling you forward), paddling a boat (the paddle pushes against the water, and the water pushes back, propelling the boat forward), and a rocket launching (the rocket's engines push hot gases out the back, and the gases push the rocket forward).
5. How does Newton's Third Law contribute to our understanding of the world?
Newton's Third Law is a fundamental principle of physics and helps us understand how objects interact with each other. It explains why objects don't just float away or collapse into each other, but rather exert forces on each other in equal and opposite directions. This law is crucial in fields such as engineering, astronomy, and mechanics, and has allowed us to make advancements in technology and space exploration.
