B Newton's Third Law Question -- Does the Earth Do Work on Me?
When performing a press-up, the Earth exerts an upward force due to Newton's Third Law, but this force does not constitute work since it does not involve movement of the surface in contact. The mechanical work associated with the press-up originates from the muscles, which actively generate force and cause movement. The Earth simply provides a reaction force without any energy transfer, as it remains stationary during the exercise. While one could calculate the upward force of the Earth against the body's center of mass, attributing work to the Earth is misleading since it does not actively contribute to the movement. Ultimately, the energy expended in the exercise is entirely due to the body's muscular effort.
paulb203
TL;DR Summary
Does the Earth 'do' anything when it pushes up on me?
When I do a press-up I consciously push down on the ground, my muscles tense, I breathe harder, I sweat, etc. When the Earth pushes back up on me (Newton's 3rd Law) is it 'doing anything', or does it push back up on me merely by virtue of it being there?
It's the latter. The Earth is not a spectacularly inefficient machine like the human body is. It doesn't have to "do anything" but be in the way to push you up.
paulb203 said:
Newton's Third Law Question -- Does the Earth Do Work on Me?​
Force is not work. Force is related to momentum transfer, which doesn't imply energy transfer.
The mechanical work done by the Earth on the bottom surface of your shoes when you jump is approximately zero. This is because the bottom surface of your shoes does not move while the force from the Earth is acting.
If you look for the source of the mechanical work that is done, you will find that it originates in your muscles. Obviously.
If you look at the forces from each muscle on each of its attachment points and multiply each force by the parallel motion of the associated attachment point, the total will be a positive number. That is the mechanical work done by the muscles.
One can multiply the upward force of the Earth on one's body by the upward motion of the body's center of mass and arrive at a similar number. But it is hard to credit the Earth with "doing" this [center of mass] work when it was just sitting there passively the whole time. Better to give credit where credit is due.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
