NFC/RFID devices -- How do they transmit data?
In summary, NFC/RFID technology uses a primary coil to emit a magnetic field and a passive secondary coil to receive and convert data into a modulation signal. The passive device modulates the carrier field by adjusting the load resistance on the secondary, which allows for data transmission back to the initiator device. In contrast, an active device has its own antenna to generate a field for data transmission. The load impedance on the secondary is "felt" by the primary coil, enabling data transfer. This technology may be confusing for those with a background in physics rather than electrical engineering or system design.
H Smith 94
Hi all,
I am designing an NFC device but am still a little unsure about the principles behind NFC/RFID. From what I understand:
  1. A primary coil constantly emits a 'carrier frequency' magnetic field.
  2. This field induces an e.m.f. on a passive secondary coil which is in a secondary circuit.
  3. The secondary circuit comprises a system that converts data into a modulation signal, which is realized by a modulating impedance in the second circuit.
  4. This impedance causes something in the primary circuit to change, thus receiving data.
It is step 4. that I am most confused by. Sources I've read simply say the load impedance is "felt" by the primary coil, whatever that means.
Also, what is the function of having a separate transmit and receive antenna?
As a physicist I have very little prior exposure to electrical engineering or system design!
A passive device modulates the carrier field by adjusting the effective load resistance on the secondary (the passive device pickup coil). A simple example would be a 1:1 transformer (power side–channel) circuit. A 1.0 mA current draw on the secondary means a 1.0 mA draw on the primary, if we drop the current draw on the secondary to 0.5 mA we now have a 0.5 mA current on the primary. If we quickly alternate the load currents with 1.0mA as a binary 1 and 0.5mA as binary 0 we have a means to transmit data back to the initiator device.
A active device will have it's own antenna to generate a field to send back to the initiator device.
Likes H Smith 94 and berkeman
Related to NFC/RFID devices -- How do they transmit data?
1. How do NFC/RFID devices transmit data?
NFC/RFID devices use radio frequency waves to transmit data between two devices. The devices must be in close proximity, usually a few centimeters, for the data transfer to occur.
2. Do NFC/RFID devices require a power source to transmit data?
No, NFC/RFID devices do not require a power source to transmit data. They use electromagnetic induction to power the chip and send data to the reader device.
3. What is the difference between NFC and RFID technology?
NFC (Near Field Communication) and RFID (Radio Frequency Identification) are both forms of wireless communication, but they differ in their range and functionality. NFC has a shorter range and is used for contactless payments or data sharing, while RFID has a longer range and is used for tracking and identification purposes.
4. Can NFC/RFID devices transmit large amounts of data?
No, NFC/RFID devices are designed for small data transmissions, usually less than 1 kilobyte. They are not capable of transferring large amounts of data like Wi-Fi or Bluetooth devices.
5. What is the security level of NFC/RFID devices?
NFC/RFID devices have a relatively low security level compared to other forms of wireless communication. They use a simple encryption method and are vulnerable to hacking and data interception. However, newer NFC/RFID technologies have implemented stronger security measures to protect against these threats.
  • Electromagnetism
  • Electrical Engineering
  • Computing and Technology
  • DIY Projects
