Nichrome wire overheating failure in standard air heater
In summary, the conversation discusses using an Omega Engineering AHP 7561 air heater to produce bursts of hot air, raising its temperature from ambient to 1500F. The heater is rated for up to 240v and can maintain a 20 cfm flow at 1000F while pulling about 10A at 220v. The discussion also considers the safety and potential damage to the nichrome wire and heater in this type of operation. Different suggestions are made, such as using a constant flow and diverting the hot air when not in use, or using a benchtop kiln for metalworking instead. Overall, it is recommended to consult the manufacturer for more information on the heater's capabilities and potential failure modes.
situationiste
Am experimenting with an Omega Engineering AHP 7561 standard air heater rated for up to 240v. Specs include ability to keep a 20 cfm flow exiting @1000F while pulling about 10A @220v.
Nichrome melts around 2400F. I'd like to produce small bursts (lasting a few seconds) of very hot air, like 0.03 cu.ft./sec. (about a liter/sec.), raising its temperature from ambient to 1500F.
If I energize the heater with essentially no air flow, it takes about 30 secs to bring the wire from room temp to cherry red (roughly 1400F). At that point several liters of air will exit the heater at about 1000F, rising from ambient to that temperature in a few seconds.
How long can I safely heat the nichrome under these conditions before melting it and opening the circuit? I do not want to disassemble the system to replace the air heater so playing on the safe side makes sense; still, I need to raise output temps.
What do you think? Any ideas about a safe schedule for longer times, gradually creeping up on the output temps required? By how much will the service life of the heater be reduced under this kind of regime? How valid an estimate of nichrome coil temp can be made from eyeballing its color?
What I have placed in bold seems to be contradictory. My opinion would be that doing something like this may only be good for a couple of times. The heater is not designed for this type of use repeatedly. All the manufacturer is concerned with is safety so if the heater safely destroys itself so the further use is prevented that is probably good enough for the manufacturer. The nichrome wire is not the only thing being stressed in this type of operation.
Likes berkeman
I don't know how to determine the effects of the repeated stress of overheating the nichrome wire. You need to talk to the manufacturer.
A safe way is constant flow and diverting the output. But I don't know what solenoid valve handles 1000F air well.
Thanks for the thoughtful responses. Indeed there is a tension between getting the system function required and not breaking the equipment too quickly (it's a test rig), and that prompted the posting. I'm hoping someone has insight into general nichrome wire failure due to overheating but, as suggested, there are other potential failure modes e.g., thermal stress cracking of the ceramic core carrying the nichrome coils.
BTW, the air control valve is on the cold side of the heater.
I was saying that a safe way to operate is to divert the hot output air when you are not using it, rather than turning off the input. That way the heater is always getting air flow and running in spec, and the response (hot air availability) is instantaneous. You can do it with a simple baffle arrangement at the output.
This seems like a good idea. Will take some rework of the test rig - things are pretty close-coupled. Thanks!
It seems like you need hotter air. You might consider using baffles and air from a ceramics kiln?
Thanks. Sounds like the right temperatures but a minimum of portability is required.
Benchtop kilns exist for the metal (jewelry) working. I don't know if they get hot enough though.
Related to Nichrome wire overheating failure in standard air heater
1. What is nichrome wire overheating failure in standard air heater?
Nichrome wire overheating failure in standard air heater refers to the process in which the nichrome wire, which is used as a heating element in the air heater, reaches a temperature that is beyond its maximum operating limit, causing it to fail or break down.
2. What causes nichrome wire overheating failure in standard air heater?
There are several factors that can lead to nichrome wire overheating failure in standard air heater. These include excessive current flow, poor ventilation, inadequate wire gauge, and prolonged use at high temperatures.
3. How can nichrome wire overheating failure in standard air heater be prevented?
To prevent nichrome wire overheating failure in standard air heater, it is important to ensure proper ventilation and use the correct wire gauge for the desired temperature. It is also recommended to monitor the current flow and avoid prolonged use at high temperatures.
4. What are the signs of nichrome wire overheating failure in standard air heater?
The most common signs of nichrome wire overheating failure in standard air heater include discoloration or burning of the wire, reduced heating efficiency, and in some cases, a complete breakdown of the wire.
5. Can nichrome wire overheating failure in standard air heater be repaired?
In most cases, nichrome wire overheating failure in standard air heater cannot be repaired. It is best to replace the wire with a new one to ensure safe and efficient operation of the air heater.
  • Electrical Engineering
28K
